Arm rest wanted
hjgtiger
- Drives: Dec 2016 White Gti auto
Re: Arm rest wanted
@2015_polo
Thanks for your help. I will try to do a 'Haynes' for the installation - if I remember
Happy new year.
Happy new year.
2015_polo
- Drives: 2015 6c polo
Re: Arm rest wanted
Excellent thanks happy new yearhjgtiger wrote:@2015_polo
Happy new year.
hjgtiger
Re: Arm rest wanted
Before I order, want to check how easy it will be to fit the alloy mount casting as it appears to need to be inserted under the edge of the loosened console. I have removed cupholder and rear torx screw and can lift/bend the lhs of the console enough to give about a 30 - 35 mm gap (not enough from the Aliexpress pics), after that further movement needs releasing 'something else' on the console fixings! Any suggestions?
2015_polo
Re: Arm rest wanted
There should be a couple of torx screws under the gear stick gator try removing them might give you some extra lift failing that there should be torx screws down each side of the console in the foot wells . If it still doesn't give you the lift then you need to take the trim off round the radio and heater controls nd remove the 2 torx from below the heater controls this will allow you to pop the edges if the cup holder bit at the front ...... think you should have enough room with out doing most of that thoughhjgtiger wrote:Before I order, want to check how easy it will be to fit the alloy mount casting as it appears to need to be inserted under the edge of the loosened console. I have removed cupholder and rear torx screw and can lift/bend the lhs of the console enough to give about a 30 - 35 mm gap (not enough from the Aliexpress pics), after that further movement needs releasing 'something else' on the console fixings! Any suggestions?
2015_polo
Re: Arm rest wanted
Just looked at the pics of the holder it doesn't look that thick you might find it's not much bigger than 35mmhjgtiger wrote:Before I order, want to check how easy it will be to fit the alloy mount casting as it appears to need to be inserted under the edge of the loosened console. I have removed cupholder and rear torx screw and can lift/bend the lhs of the console enough to give about a 30 - 35 mm gap (not enough from the Aliexpress pics), after that further movement needs releasing 'something else' on the console fixings! Any suggestions?
hjgtiger
Re: Arm rest wanted
I am exchanging messages with the guy in China and have asked for casting dimension.
2015_polo
Re: Arm rest wanted
Ok keep postedhjgtiger wrote:I am exchanging messages with the guy in China and have asked for casting dimension.
hjgtiger
Re: Arm rest wanted
In the pic there are 2 pairs of torx screws, the upper black ones seem to join the lower centre console to the upper part that houses the heater controls. The lower, bright screws only seem to hold the gear change/select 'tower' to the floor.
Can't see how to post pic!!
hjgtiger
Re: Arm rest wanted
Just placed my order.
Spent all morning working out what may need to come out to fit it.
With the help of this link and our capable adviser '2015_polo' I hope I should be oK
http://workshop-manuals.com/volkswagen/ ... dle_trims/
When I start installing I'll start a new thread - if I can work out how to post pics!
2015_polo
Re: Arm rest wanted
If you reply to my thread it comes up with a tab that had a square and a paper clip etc click the square and it lets you upload that way and il be as helpful as possible I'm sure it won't be an issuehjgtiger wrote:Just placed my order.
2015_polo
Re: Arm rest wanted
hjgtiger
Re: Arm rest wanted
I do not get what you show on either my Tab S or my Win 10 laptop
All I get is a row of boxes above the text box with:
B i u Quote Code List List= [*] Img URL Font colour youtube
in them. The 'Img' icon just puts the word 'Img' in the text box, so still at a loss regarding inserting pics.
2015_polo
Re: Arm rest wanted
That's quite strange not sure on the tab etchjgtiger wrote:I do not get what you show on either my Tab S or my Win 10 laptop
hjgtiger
Re: RE: Re: Arm rest wanted
It appears that 'TapaTalk' gives the paperclip + other icons - but the attachment does not show in the posting - just the coding!2015_polo wrote:That's quite strange not sure on the tab etchjgtiger wrote:I do not get what you show on either my Tab S or my Win 10 laptop
Sent from my SM-T800 using Tapatalk
2015_polo
Re: Arm rest wanted
It's Tapatalk I use aswell it's a bit easier to usehjgtiger wrote:It appears that 'TapaTalk' gives the paperclip + other icons2015_polo wrote:That's quite strange not sure on the tab etchjgtiger wrote:I do not get what you show on either my Tab S or my Win 10 laptop
