Removing Plastic trim around the stereo POLO SEL 6C
richards_owen
Drives: SEL 1.2 TSI 2016
Post by richards_owen »
I have recently purchased some genuine OEM plastic trim from an SE DESIGN to replace my plain matt black trim from the factory. I presumed that removing the current trim would be a very easy job although having begun trying, I am struggling...! I know that you need to remove the trim around the infotainment display first as that partially holds the others in and I can see two slits beneath which I thought might be the place to begin. I don't have removal tools although other forums suggest you don't really need them. I've been using a flathead screw driver covered in cloth not to scratch anything. I can't really find any tutorials for the 6C and the ones for the 6R make it look really easy which i'm not finding!
Getting to the point...
Is it just me being pathetic? Do I need removal tools? Has anyone else removed the faceplate on a 6C and know where to start?! Let me know - I'm probably doing something very wrong/stupid!
Re: Removing Plastic trim around the stereo POLO SEL 6C
start at the bottom ;) there will be two rectangular holes, about the size of your car key (metal part). i always use the car key to remove it...
richards_owen
I was being too gentle!! Got is sorted now :) Thanks for your help -
richards_owen
So I was able to remove these two no problem although I struggled to find the correct area to pry off the trim around the vents - this comes off with the button unit right? Any help for that panel would be much appreciated!
richards_owen
What I managed! Image
CNK
Drives: 6R
Post by CNK »
A little old picture:
richards_owen
Thank you - so there's clips at the top and sides and then the panel of button comes off from the bottom too... :)
Sent from my F8331 using Tapatalk
CNK
Drives: 6R
Post by CNK »
Yes, but you can pull out all at once:
:arrow: http://workshop-manuals.com/volkswagen/ ... tre_vents/
Good luck! ;)
