1 Complete darkness. No lights at the sides of the road (city, villages, streetlights, etc).
2 Light switch in Auto.
3 Activated the system with the stalk (icon on the screen)
4 Higher speed of 40 Km/h.
govindsharma wrote:VW polo 6R High Beam Assist that works very charm.Its small clip because its very difficult to upload big one.
Thanks to Ciclo Sir for making my POLO so unique and only one in North India i think.
Despite the lighting circumstances and low speed is a perfect video. Thank you for sharing.
(I know it's difficult to make a good video without the right tools and conditions)
Your 6R is now safer and comfortable to drive. Enjoy it.
To install DRLs on your 6R IND with BCM Max and automatic lights, etc ... you need:
- the signal wire to activate DRLs, from the light switch to the BCM, which is already installed (included in my wiring that I sent you ).
- the wires from the BCM to the DRLs. http://www.ebay.de/itm/VW-Polo-6R-6C-Ka ... 2ed2ccbfc4
- fog lights with additional bulb for DRLs. 6C0941661, 6C0941662 ... e.g search here
- bulb carrier (4) + bulb (6) for DRLs.
Hmm... bulb, search for 'w21w white Led error free (osram, philips)'
Dear Sir Good Morning tell one thing that if i will deploy new fog light with drls and static cornering light, then i have to remove present fog light harness and install new one or new harness is separate for DRLS.
govindsharma wrote: Tue Aug 29, 2017 4:25 am
Thank you.
New harness is separate for DRLS
All you have to do is connect the wiring from the BCM to the new daytime running lights, and install your new foglamps with DRLs.
The original wiring for the fog lights/cornering lights remains intact.
New BCM coding is required, but you know this is not a problem for us.
Dear Sir I had purchased fog lights with static cornering lights and day time running lights 6C0941661 and 6C0941662. Now tell me in which bcm connector wire must be connected and coding for it.
