Fitting Pioneer SPH-DA120 to 2012 Polo 6R
Roh4nms
Drives: 2012 Volkswagen Polo 1.2 6R
Re: Fitting Pioneer SPH-DA120 to 2012 Polo 6R
Post by Roh4nms »
Would these fit?
alexperkins
Site Admin
Post by alexperkins »
Yep then add a HID kit
alexperkins
Site Admin
Roh4nms
Post by Roh4nms »
Ok awesome. Thanks for all the help! When I get around to fitting my pioneer sph-da120 I'm certain I'll run into a bunch of problems so i may have to ask a few more Qs regarding that over the weekend. Thanks for all the help!
Roh4nms
Post by Roh4nms »
Hi all,
Today I am fitting my pioneer sph-da120 and I've already hit a problem.
It was mentioned by Alex I will need to attach the red cable to a live ignition wire, the orange to an illumination cable and the Arial to an the pioneer loom... so I've attached the quad lock adapter to the original look and I don't know where to go from here... any help in locating ignition live and illumination cable would be greatly appreciated.
Thank you
Roh4nms
Post by Roh4nms »
alexperkins
Site Admin
Aerial cable there's a terminal on the pioneer loom that says system remote which you can use
Red cable needs to go to something live with the ignition on. You can probably pillage that on the back of the heated window switch above
Same for illumination. That's the grey cable with the blue stripe on the same switch
Are you capable of tapping those wires into the car loom? You'll need a multimeter and a soldering iron or splice connectors to do it
Roh4nms
Post by Roh4nms »
alexperkins wrote:Aerial cable there's a terminal on the pioneer loom that says system remote which you can use
Quite a complicated task then [emoji28]
Roh4nms
Post by Roh4nms »
Also I have noticed there are only 2 cables coming out of the adapter loom when there are 5 going in from the car... (left side of loom)
alexperkins
Site Admin
Correct. There are additional power feeds and the CAN wires
Might be wise to call on a local garage or dare I say your nearest Halfords to help you fit it
This was part of the reason why I suggested the more expensive adapter as it doesn't need any tapping in
Roh4nms
Post by Roh4nms »
Ok thanks for the help I'm going to get some help from my girlfriend's dad who is an auto electrician so fingers crossed he'll be able to give me hand..
thanks for all the help Alex much appreciated
alexperkins
Site Admin
Sorted then :)
Use the heated mirror switch for the feeds and you'll be away
Roh4nms
Post by Roh4nms »
Quick update. Had it fitted last week and love it! Car play works a treat.
Splash screen
Apple Car Play
Home screen
alexperkins
Site Admin
Excellent :) thanks for updating us
