Thanks in advance
How much boost on gti 6c.
Recently I configured the android app called torque through my obd. Good pulls read 0,6 -0,8 bar on the virtual barometer. Are these numbers real? I am trying to see if there is accuracy on the boost readings. If this is true this has to be the cleanest installation of boost readings
Thanks in advance
Thanks in advance
Re: How much boost on gti 6c.
Sounds about right, +0.8 bar
Great thank you for the confirmation!. Vacuum readings are quite the same (-0.8 bar)
