How much boost on gti 6c.
panosvet
Drives: Vw polo gti 6c
Post by panosvet »
Recently I configured the android app called torque through my obd. Good pulls read 0,6 -0,8 bar on the virtual barometer. Are these numbers real? I am trying to see if there is accuracy on the boost readings. If this is true this has to be the cleanest installation of boost readings 😎
Thanks in advance
Re: How much boost on gti 6c.
Sounds about right, +0.8 bar
panosvet
Post by panosvet »
Great thank you for the confirmation!. Vacuum readings are quite the same (-0.8 bar)
