Bow to spacewalker, the man posting above here. He did the difficult part of learning the keys.
retrofitting kessy to the Polo 6R
Re: retrofitting kessy to the Polo 6R
hello, i saw your post with the following fault code:iichel wrote: Tue Feb 28, 2017 7:28 pm updated VCDS coding
result with normal ignition lock:Code: Select all
Tuesday,28,February,2017,13:53:50:62066 VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare) VCDS Version 17.1.3.0 Data version: 20170203 DS267.2 www.Ross-Tech.com Workshop Code: 123 12345 012345 VIN: License Plate: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 6R (7E0) Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56 61 69 6C 77 0B VIN: Mileage: 0km-0miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 2B-Steer. Col. Lock -- Status: Malfunction 0010 2E-Media Player 3 -- Status: OK 0000 37-Navigation -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 47-Sound System -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J000-CFWA) Labels: 03P-906-021-CFW.clb Part No SW: 03P 906 021 B HW: 03P 907 425 Component: R3 1.2l TDI H06 9978 Revision: 12005001 Serial number: Coding: 00114036033401080000 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_ECM12TDI03103P906021B 001041 ROD: EV_ECM12TDI03103P906021AA.rod VCID: 2757FDE35E1F667988-8073 No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: None Part No HW: 6R0 907 379 AF Component: ESP8.2i front H05 0001 Revision: -------- Coding: Shop #: WSC 00788 648 00255 VCID: 55AB872B38F324E9EA-8001 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb Part No SW: 5K0 959 434 E HW: 5K0 959 434 Component: VWKESSYPQ35GP 092 1202 Revision: 00092000 Serial number: 0346244897 Coding: 000F0F Shop #: WSC 01342 020 12345 ASAM Dataset: EV_KESSYPQ35G A02717 ROD: EV_KESSYPQ35G_VW01.rod VCID: 37772DA38EBFF6F918-8063 1 Fault Found: 1057799 - Antenna for Keyless Entry System in Trunk B1173 11 [008] - Short to Ground Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 153 Mileage: 0 km Date: 2017.02.28 Time: 01:41:03 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb Part No SW: 6R0 907 044 H HW: 6R0 907 044 H Component: Climatronic H12 0812 Revision: V0000000 VCID: 38752E9F8BA1F98111-806D No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 HW: 7E0 937 090 Component: BCM PQ25 Max4 H80 0733 Revision: B9080001 Serial number: 0771 092150183 Coding: 3CB02FF828CB2400933806E2FFEB9FD080A073EFE08D78D020E050032800 Shop #: WSC 12345 123 12345 VCID: 68D5BEDF9B81A90141-803D Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB Component: RLS 140415 03 37 0059 Coding: 0714DD Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB Component: J386__TSG_FT 003 8611 Serial number: KU0KU011111300010103 Coding: 0200A3 Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB Component: J387__TSG_BT 003 8611 Serial number: KU0KU007111300016463 Coding: 1000AB Subsystem 4 - Part No: 1K8 951 171 A Component: DWA-Sensor 00 001 0103 Coding: 000000 Subsystem 5 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Coding: 000000 Subsystem 6 - Part No: 1K8 951 171 A Component: DWA-Sensor 00 001 0103 Coding: 000000 Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442 Component: E221__MFL-DC1 H03 0103 Serial number: 27140002547420014516 Coding: A4FFFF Subsystem 8 - Part No SW: 6R0 959 811 B HW: 6R0 959 811 B Component: J388__TSG_HL 002 0803 Serial number: KU0-KU008.06.0910897 Coding: 08BC32 Subsystem 9 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B Component: J389__TSG_HR 002 0803 Serial number: KU0-KU004.06.0913330 Coding: 08BC32 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb Part No SW: 7E0 919 475 L HW: 7N0 919 475 Component: PARKHILFE 8K H06 0106 Revision: -------- Serial number: 28231422402620 Coding: 318001 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_VW75XParkAssis8K 001003 ROD: EV_EPHVA18VW250GPCS.rod VCID: 3B7F3193B297D299FC-806F No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 5K0-959-655.clb Part No SW: 6R0 959 655 K HW: 6R0 959 655 K Component: VW10Airbag01M H10 0020 Revision: -------- Serial number: 003GX0142TCE Coding: 00314D Shop #: WSC 01383 785 00200 ASAM Dataset: EV_AirbaVW10BPAVW250 A01001 ROD: EV_AirbaVW10BPAVW250_VW25.rod VCID: 4A916457ED4D7B1177-801F Crash sensor for side airbag: driver side: Serial number: 3575HRB40650BI7U48C8 Crash sensor for side airbag: front passenger side: Serial number: 3585HRB405J09RECEOUJ Crash sensor for side airbag: rear: driver side: Serial number: 3515RRB405T0BTBEF9G7 Crash sensor for side airbag: rear: passenger side: Serial number: 3525RRB405R0BTBEKPFQ No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 6R0 920 870 A HW: 6R0 920 870 A Component: KOMBI H04 0709 Serial number: 00000000000000 Coding: 140E01 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723 ROD: EV_Kombi_UDS_VDD_RM09_A04_VW25.rod VCID: 336F19B39AC71AD924-8067 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: None Part No SW: 7E0 909 901 HW: 7E0 937 090 Component: GW-K-CAN TP20 H80 0733 Revision: B9080001 Coding: 042201 Shop #: WSC 12345 123 12345 VCID: 68D5BEDF9B81A90141-803D No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels: 8S0-857-511.clb Part No SW: 7E0 857 511 G HW: 7E0 857 511 E Component: FLA H10 0003 Revision: AA001001 Coding: 040C00E200000000000000 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_HighBeamAssisAU316 001004 ROD: EV_HighBeamAssisAU316.rod VCID: 2E5908C771E537314B-807B No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H04 0709 Serial number: 00000000000000 Coding: 000007 Shop #: WSC 09402 015 1048576 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: 6AD1C4D78D8D9B1157-803F 2 Faults Found: 9456681 - Key B104C 29 [009] - Implausible Signal Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Mileage: 0 km Date: 2017.02.28 Time: 01:41:06 10493440 - Function Limitation due to Missing Enable from OCU/VTS B201E 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 1 Mileage: 0 km Date: 2017.02.28 Time: 01:41:05 ------------------------------------------------------------------------------- Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb Part No SW: 5K0 905 861 B HW: 5K0 905 861 B Component: ELV-PQ35 H20 0240 Revision: 00000000 Serial number: 11000256123005 Coding: 4100000000000000 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_ELVMarquMPVW36X A01001 ROD: EV_ELVMarquMPVW36X.rod VCID: 2F6715C376EF3E3940-807B 2 Faults Found: 1048838 - Terminal 15 B1148 12 [137] - Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 4 Reset counter: 113 Mileage: 0 km Date: 2017.02.28 Time: 01:37:56 ELV State: 04 Information Clamps: 67 20 CoCo State: B0 01 WFS State: 10 1A Vehicle speed: 0.00 km/h Voltage: 68 1048840 - Terminal 15 Redundancy B11D6 12 [137] - Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 4 Reset counter: 113 Mileage: 0 km Date: 2017.02.28 Time: 01:37:56 ELV State: 04 Information Clamps: 67 20 CoCo State: B0 01 WFS State: 10 1A Vehicle speed: 0.00 km/h Voltage: 68 ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl Part No SW: 5N0 035 342 G HW: 5N0 035 342 G Component: SG EXT.PLAYER H19 0770 Revision: A1001003 Serial number: 7666620365 Coding: 010100 Shop #: WSC 12345 123 12345 VCID: 2B5F01D34AF742196C-807F No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 1T0-035-680.clb Part No SW: 1T0 035 686 E HW: 1T0 035 686 H Component: RNS-MID H26 6276 Coding: 00070002010000A10001 Shop #: WSC 12345 123 12345 VCID: 366920A781B50FF103-8063 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V14 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: Redir Fail! Part No SW: 7E0 907 566 B HW: 4L0 907 566 A Component: J0769 SWA MasterH14 0120 Revision: 00H14000 Serial number: 6PZ 009 014-07 Coding: 0010161 Shop #: WSC 02757 790 00000 VCID: 2F6715C3BEEF3E3940-807B Subsystem 1 - Part No: 7E0 907 568 B Component: J0770 SWA Slave H09 0110 Subsystem 2 - Serial number: 6PZ 009 014-27 Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ÿ Subsystem 4 - Serial number: H21982ÿ No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 6Q0-423-156.clb Part No: 6R0 423 156 B Component: LenkhilfeTRW V277 Coding: 11220 Shop #: WSC 00788 VCID: 2F6715C3EAEF3E3940-807B No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (R12) Labels: 5K0-035-456.clb Part No SW: 5C6 035 456 C HW: 5C6 035 456 C Component: KonzernAmp10K H08 6831 Revision: -------- Serial number: EAA098C0000052 ASAM Dataset: EV_AudioVerst10KanalSTT4 001001 ROD: EV_AudioVerst10KanalSTT4.rod VCID: 2855FEDF5301690181-807D No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb Part No SW: 6R0 907 357 HW: 6R0 907 357 Component: LWR-ECU H02 0070 Revision: -------- Serial number: -------------- Coding: 0192000001000000 Shop #: WSC 00788 648 00255 ASAM Dataset: EV_HeadlRegulVWLWRPt 001004 ROD: EV_HeadlRegulVWLWRPt_VW25.rod VCID: 77F7EDA3CE3F36F9D8-8023 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 686 E HW: 1T0 035 686 H Component: RNS-MID H26 6276 Revision: AB001001 Serial number: VWZ6Z7P1950254 Coding: 00070002010000A10001 Shop #: WSC 12345 123 12345 VCID: 366920A781B50FF103-8063 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V14 8477 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb Part No SW: 7E0 907 534 HW: 7E0 937 090 Component: Batt.regelung H80 0733 Serial number: 0771 092150183 Coding: 03071A5A Shop #: WSC 12345 123 12345 VCID: 68D5BEDF9B81A90141-803D Subsystem 1 - Part No SW: 6C0 915 181 HW: 6C0 915 181 Component: J367-BDM H08 0223 Serial number: 61083A44504351928092 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels: 1K0-907-383-V2.clb Part No SW: 1K0 907 383 E HW: 1K0 907 383 E Component: Anhaenger H07 0080 Revision: 3A002002 Serial number: 00000116932377 Coding: 0100000100000000 Shop #: WSC 12345 123 12345 VCID: 2F6715C37EEF3E3940-807B No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 5N0-907-441.clb Part No SW: 7E0 907 441 HW: 7E0 907 441 Component: J772__Rearview 0040 Revision: 00H08000 Serial number: 525PA8-J060533 Coding: 0030115 Shop #: WSC 12345 123 12345 VCID: 65CBB7EBAC93B4697A-8031 1 Fault Found: 03006 - Back-up Camera System not calibrated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 113 Time Indication: 0 ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb Part No SW: 3C8 035 730 E HW: 3C8 035 730 E Component: Telefon 025 0983 Revision: -------- Serial number: 35502105254406 Coding: 020100000100010000000101 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_UHVPremi 002709 ROD: EV_UHVPremi_002.rod VCID: 254BF7EB24137469BA-8071 No fault code found. End-------------------------(Elapsed Time: 05:08)--------------------------
if ignition is on, it says in the segment display 'no key'.
also, if there is something wrong with the kessy it says 'check keyless'. very neat.
Car now unlocks when ignition is switched off, instead of key removal.
Problem with the converter box/BCM wiring: http://www.uk-polos.net/viewtopic.php?f ... 80#p518773
B201E 00 [009] - -
Fault Priority: 1
Fault Frequency: 1
Mileage: 0 km
Date: 2017.02.28
Time: 01:41:05
last week i changed my cluster with kessy from white/black to 3d from new scirocco facelift. now in the new cluster i get this error message to, how did you fix this?
Adapt keys to immo, that should solve it. I'm not sure why it's fixed for me, to be honest
keys were adopted, tested on the bench, only in the car i get this error?iichel wrote: Tue Jul 18, 2017 12:00 am Adapt keys to immo, that should solve it. I'm not sure why it's fixed for me, to be honest
Error returns after you clear it? Then maybe adapt keys in the car and not on the bench?
spacewalker
- Drives: Just a VW
when you swap cluster to currently working keesy car , no need to do anything with key learn.
but when you rebuilt kessy , then must learn all ,even sometime ELV must be re-adapt
already told you what to do , but seems you waste my time and try to find other way to fix
I'm happy to report that the keyless starting is completely working. Kessy module (address) coded is 000F0F.
The keyless entry is not working currently. The coding for this must be 03C0C0. Then it gives an error for the door handle (implausible signal, short to ground, open circuit).
Remember I have four kessy door handles, parallel mounted (front to rear).
I'll have to measure and check the wiring in the coming days.
The final adaptation of the keyless start was possible due to the xhorse iscancar MM-007 and the knowledge of the PIN and CS bytes.
It was a difficult trip so far, but I'm happy it's coming to an end. My big thanks to spacewalker for the support (time, effort and use of equipment).
I'll update when the wiring of the handles is checked.
Congrats!!
Waiting for the update.
Remove front to rear door connections and all is well
Very nice
Fantastic!
Before I've even start on this project - what are the requirements to the instrument/immobilizer? I have the 'small' one from 1.6 TDI...
Electronic steering column lock
Kessy module
Cluster from donor car
Two door handles
New keys
A lot of wiring
An expert to help you out
Kessy module
Two door handles
New keys
A lot of wiring
Cluster - one of the expensive parts... how much did this project cost you? (Both time and money)
Oh I really stopped counting the time.diskoboy wrote: Mon Aug 14, 2017 6:41 am Cluster - one of the expensive parts... how much did this project cost you? (Both time and money)
Money wise a wild guess:
ELV €50
Cluster €200
Kessy module €50
Door handles €100
Connectors €100
Keys €180
External expertise so far €100
The smile on your face when it all works out: priceless
