Hi all
Just want some advice, I'm looking at a multifunctional steering wheel and a RCD510 radio, will it need a load of new/re-wiring or will it just fit and work with little messing around with. As my Polo is the SE model it's as it's in the name very basic.
Any advice is good advice
2011 SE
PoloBlueGT
- Drives: Landrover Freelander
Re: 2011 SE
Hi mate,
RCD 510 is a 10 minute fit plug and play but MFSW needs coding.
Re: 2011 SE
Cheers buddy might have to put the steering wheel on the back burner for now thanks again
Re: 2011 SE
You'll also need to make two new wires for the mfsw. There is a good guide in the DIY section.
The rcd510 will ideally need a second antenna wire for diversity AM/FM reception.
