2011 SE
Dan6r
Drives: 2011 se
2011 SE
Post by Dan6r »
Hi all
Just want some advice, I'm looking at a multifunctional steering wheel and a RCD510 radio, will it need a load of new/re-wiring or will it just fit and work with little messing around with. As my Polo is the SE model it's as it's in the name very basic.
Any advice is good advice
PoloBlueGT
Drives: Landrover Freelander
Re: 2011 SE
Post by PoloBlueGT »
Hi mate,
RCD 510 is a 10 minute fit plug and play but MFSW needs coding.
Dan6r
Drives: 2011 se
Re: 2011 SE
Post by Dan6r »
Cheers buddy might have to put the steering wheel on the back burner for now thanks again
Re: 2011 SE
You'll also need to make two new wires for the mfsw. There is a good guide in the DIY section.
The rcd510 will ideally need a second antenna wire for diversity AM/FM reception.
