Polo 6C BiXenon Retrofit
- Drives: 6C
Hello!
I decided to make a new topic ( hoping that it would -- maybe -- get more attention ) after reading ciclo's thread regarding this. I basically dream of having BiXenon installed on my car ... therefore I went on and bought the following:
- OEM BiXenon headlights :: 6R1941031D & 6R1941032D
- Halogen to Xenon conversion wiring :: https://www.kufatec.de/shop/en/Volkswag ... VW-Polo-6R
- Autoleveling kit ( from kufatec ) :: https://www.kufatec.de/shop/en/volkswag ... vw-polo-6r
I've bought and installed a new OEM front bumper with headlight washers, bought the whole washer system with the new cannister, secondary pump, hoses and washers.
Installed all of them ( just not the wiring, as I'm not sure what goes where )
For the time being I would be thankful to only get the headlights working .. without AFS or Auto-Leveling as I know that might require a new BCM
My car's VIN is WVWZZZ6RZFY146XXX and an autoscan can be found here: https://pastebin.com/HN6Vk5Be
Please advise if you guys need any info from me ... thanks!
Re: Polo 6C BiXenon DIY Help.
So he is LHD
AFS will work on all bcms, the bcm controls lighting for the LED DRL and xenon. That's why sometimes it needs upgrade
Autoscan:
Furthermore I'd like you to ask to keep it in one topic. This way all information is on one location. That makes it a lot easier for everyone
Autoscan:
Chassis Type: 6R (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
Mileage: 27512km-17095miles
Address 01: Engine (J000-CUSA) Labels: 04B-907-445-V1.clb
Part No SW: 04B 906 027 HW: 04B 907 445
Component: R3 1,4 DCM6.2 H07 8205
Revision: 21003001
Coding: 01114012432401080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM14TDI03004B906027 003019
ROD: EV_ECM14TDI03004B997027B.rod
VCID: 5EB3F85D41E606B1BB-800A
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 G HW: 6R0 907 379 BA
Component: ESP9.0i H03 0003
Serial number: 08503245140827
Coding: 21DD2485892733C6091610720051842491CC90080007C9098F00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 336579E99AE4FBD924-8066
Address 08: Auto HVAC (J65) Labels: None
Part No SW: 6C0 819 045 C HW: 6C0 819 045 C
Component: Heizung H02 0103
Serial number: 1405291B-1136
Coding: 201000000000000200
ASAM Dataset: EV_HZGManueHMMValeoPQ26 001001
ROD: EV_HZGManueHMMValeoPQ26_VW26.rod
VCID: 275D9DB95E3C877988-8072
Address 09: Cent. Elect. (J519) Labels: None
Part No HW: 6C0 937 089
Component: BCM PQ26 Hi4R H06 0047
Serial number: 009458017422
Coding: 000008404253005B4B8440004007038800005B0251010000000000000000
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_BCMA0 004003
ROD: EV_BCMA0_004_VW26.rod
VCID: 55A1E77134D0C5E9EA-8000
Drivers Door Control Module:
Subsystem 1 - Part No SW: 6R0 959 801 AT HW: 6R0 959 801 AT Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU001091442441673
Coding: 0400A0
Front Passengers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 802 BE HW: 6R0 959 802 BE Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU003091442468341
Coding: 1400A0
Drivers Door Rear Control Module:
Subsystem 3 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8610
Serial number: KU0KU009091442525731
Coding: 0400A0
Passengers Rear Door Control Module:
Subsystem 4 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8610
Serial number: KU0KU010091442532611
Coding: 1400A0
Address 15: Airbags (J234) Labels: 6C0-959-655.clb
Part No SW: 6C0 959 655 A HW: 6C0 959 655 A
Component: VW20Airbag00Z 001 0330
Revision: -------- Serial number: 003LM004MBGD
Coding: 88C0C000000000005C000000000800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 316973E160F8C9C956-8064
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 410 820 308 14
Component: SideSensor_Df 151 0800
Serial number: 3575H00BB15739C1930N
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 410 820 308 14
Component: SideSensor_Pf 151 0800
Serial number: 3585H00062837AA1D2AO
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 442 150 609 14
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00C31725223B22Z
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 442 150 609 14
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00C31725220B17.
Coding: 2D2D2D
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 6C0 920 741 A HW: 6C0 920 741 A
Component: KOMBI 211 0290
Coding: 472509002180000800083A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009040
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 214983A130187949C6-8074
Address 19: CAN Gateway (J533) Labels: 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H06 0047
Revision: -------- Serial number: 009458017422
Coding: 030100044F0A590071000000000000010001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_VW26.rod
VCID: 65C1D7B164B055697A-8030
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H04 0019
Serial number: 2411422172402137AD1B
Coding: 280000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 61247G58362821697892
1 Fault Found:
197175 - Control unit for battery monitoring
U1050 00 [008] - No Communication
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 47
Reset counter: 14
Mileage: 27320 km
Date: 2017.06.26
Time: 00:00:02
Supply voltage: Terminal 30: 12.5 V
Terminal 15: OFF
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 M HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3211
Serial number: PE9J0052
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: 326B7CED65FEF2D12F-8066
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-ENT2.clb
Part No SW: 6C0 035 869 B HW: 6C0 035 869 B
Component: MU-E--ER 820 6220
Serial number: 26081400010666
Coding: 02620000BE00000041110001000000001F0004840000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001017
ROD: EV_MUEnt4CGen2LGE_VW12.rod
VCID: 2A5B648D4D2EBA1197-807E
- Drives: 6C
Regarding keeping stuff in one topic, I can only agree. Though i figured it’s best to just make a separate topic on my issue hoping it would get in someone’s way hehe.
By any chance can you PM me with ciclo’s email, or maybe nudge him directly so he can take a look as well ? Hopefully he’s interested in a side project like this or maybe he has any friends who might have dealt wih this ... I can only hope
And yes, I am a Romanian ( LHD here ).
Best regards!
Best regards!
I will not send you his email. From what I've heard, he's busy enough as it is and whenever he can help, I'm sure he'll answer in the topic.
- Drives: 6C
Sure, understood. Will just wait then, thanks!
- Drives: 6C
Re: Polo 6C BiXenon Retrofit
OK so, after 2 months of research and getting better at retrofiting ( ) I've figured out how I can ( finally ) fully retrofit the AFS / BiXenon on my own ( of course, with the knowledge acquired from many, like DV25, iichel, ciclo ( big thanks for the car's diagrams )
Basically, I just bought 2 T14 connectors and some terminals, since there are no new cables that I'm aware of, needed. ( aside AFS as I'm not detailing that now )
So, I went on and split the following:
- 5 to 5 and 7 ( groundings )
- 6 to 6 ( main beam )
- 8 to 11 ( dip beam screen motor ) Though I guess this is not needed since AFS is taking control of headlights ?
- 9 to 9 ( turn signal )
Then it's 3 more slots towards which I redirected the cables from the front bumper as follows:
- 10 <- DRL ( got the DRL wire from the bumper )
- 12 <- Side light ( also known as parking light ) - got the "old" wire from the 10 pin connector, as it had parking lights under PIN 10
- 14 <- Static Cornering ( got the fog lights cable -- which also acts as cornering in my case )
Did the coding to change from Halogen to Xenon with AFS, also changed Low beam bulb type to HID instead H7 ( under byte 5 ), so we got:
-- low / high beams working ( shutter )
-- static cornering lights into the headlight
The only issue is, DRL does not work ... I know the LED module within the headlight gets PIN 10 ( normal DRL from bumper ) and PIN 12 ( former side light ) but ... I still get errors in the dashboard regarding the lack of DRL and Side lights ( on both sides ).
QUESTIONS:
1. Are there other changes/codings I need to do ? I'm sure there is no cable issue since it was just a matter of rearranging the cables on the connector end, nothing changed BCM side.
2. Since the static cornering lights are active via the fog lights, I connected these to the headlight. Is it supposed to work like this ? ( having static cornering and fog lights inside the headlight ? ). Or is there some setting to separate there two. Didn't see "different" slots in the BCM terminals but there is some confusion in the schema.
Basically, the static cornering lights show t46b/7 and t46b/42 as connectors, but these are for Right / Left headlight main beam bulb -M30-, terminal 56a. So I guess .. there must be a setting to separate cornering from fog lights, so then I can have the fog lights, separate, in the front bumper ? ( made wiring for that as well ).
OLD ( 10 PIN connector schema ): https://i.imgur.com/2w2GLox.png
NEW ( 14 PIN connector schema ) : https://i.imgur.com/aDgbvk7.png
I'll test the cables from the DRL for voltage and see what they get .. maybe something's wrong there. Any way I can test the LED module ?
Thanks for taking time to do such a long read ..
QUESTIONS:
Did you fit the dayrunning light pins in the T46B slot 6 and 43?
- Drives: 6C
I just routed the DRL wires from the bumper to T14/10, so I'm sure the wires are fine .. then I've placed the parking light ( from old headlight ) into T14/12 ... so I'm not sure if the DRLs should work just like that, or need some kind of coding ?
- Drives: 6C
By any chance, you guys out there who went from halogen to xenon, did you have to do any adaptation channels coding in order to get the DRL working ? Given the old parking light is such a small consumer, I tend to think adaptation channels might need some change to the "load_type" ( watts ) on that wire ?
Please let me know as my DRLs are not working just by plugging the old wires in.
Hello,
I have Sharan 7n 2011 and i need to retrofit from Halogen to Bi-xenon , I have both the OE Bi-xenon and both a wires from KUFATEC
I have made some coding and the Low and High beam are working fine , the DRL led is not working at all
Any advice , thanks in advance
- Drives: 6R 1.2 TSI
Its the coding. For Polo 6R it is:MITKO82 wrote: ↑Fri Feb 19, 2021 1:51 pm Hello,
Byte 11 to D1
Byte 21 bit 0 set to 1
Byte 22 bit 4 set to 1
Byte 23 to 41
Don't now what bcm is in a Sharan 7n.
Probably 5K0 BCM so not even remotely related to the Polo
