Yes, I think so. But for me it's ok like this :-)
Sure, I'm with you (always), my good and dear friend.
I told you because you have the ASSISTANS menu activated.
You did a great job when installed the Side Assist system, Hmm ... I would have preferred that you had installed the original isolation relay for the CAN lines instead of the two relays. Do you remember our email conversations?
However, it was a good idea. 8)
You even have a special label in my mailbox ;-)
RekinPoznan
Drives: 6R
Post by RekinPoznan »
When BCM controls the can relay ? when you push the Side assist button to activate it ? , or this is automaticaly sellected above 40km/h ? then BCM set + to the can relay ?
When Side Assist working witheout correct ABS unit is not possible to brake on specified situation.So must be ABS instaled from 6C or from T5 , or T6 ?
I planned mount this set nex week , I`am on the way to collect the parts .
Chriss
My set is activated by push button, but maybe you can find a set that will activate via the MFA+?
RekinPoznan
Drives: 6R
I think it is not necessary to connect the CAN lines to work as an indicator of lane capacity,(Stand alone can work beacose is only led indicators) but if there was an ABS pump that works with it, it would be possible to brake the vehicle in a specific situation. I wonder because ESP is still waiting (retrofit) for me or not to install a pump that Would it work if any would fit?
IIchel your set working below 40km/h ? when is activated via button ?
I wonder about the laser burning of the Side Assist logo in the mirror so as to remove the reflective layer , or mayby is plug&Play mirror insert with this logo from another car with this function.
numberior
Drives: Polo GTI 6r
Post by numberior »
Hi Ciclo,
I'm from Singapore (we drive on the same side as the British) and after reading your posts I have embarked on the project to retrofit xenon headlamps to my Polo GTI 6R that came with halogen headlamps. I have the BCM High p/n: 6R0 937 087 H.
Monday,02,October,2017,10:58:44:27502
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZBY312116   License Plate: 2OCT2017
Mileage: 99610km-61894mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBY312116   Mileage: 99610km-61894miles
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAVE)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 027 AR    HW: 03C 906 027 AR
   Component: 1.4l R4 TSI   H15 9971
   Revision: L2H15---    Serial number: 00000000000000
   Coding: 00250012002400000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
   ROD: EV_ECM14TSI01103C906027AR.rod
   VCID: 71E99E02A0C274CE75-8024
Readiness: 1110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 050 K    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2669
   Revision: 00043014    Serial number: CU501309027085
   Coding: 0000020
   Shop #: WSC 00046 000 00000
   VCID: 31695E02AB4234CE35-5106
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 230248E3416E02B4C42612E382D740811700
   Shop #: WSC 00788 648 00255
   VCID: 071DD0DAB2465A7ECB-8052
   Part No SW: 6R0 907 044 E    HW: 6R0 907 044 E
   Component: Climatronic   H09 0609
   Revision: V0000000
   VCID: 35616A129C2A18EE69-8060
   Part No SW: 6R0 937 087 H    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0230
   Revision: BF046001    Serial number: 0394 106112048
   Coding: 3CB02BBF08A10000083808403C290CD020C041CF60060000200000000000
   VCID: 428B01CEDDE4BF56DC-8016
   Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  007 1611
   Serial number: KU0KU024031100012688
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  007 1611
   Serial number: KU0KU016031100015781
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 591 A    HW: 7P0 959 591
   Component: J245 PS72.015  H05 0006
   Serial number:     WOO1165901/
   Coding: 081001
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0050759
   Coding: 830000
   Subsystem 5 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Serial number: KU0KU011041100017315
   Coding: 08BC32
   Subsystem 6 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  007 1611
   Serial number: KU0KU011041100013053
   Coding: 08BC32
   Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
   Component: VW10Airbag01E H09 0020
   Revision: --------    Serial number: 003GZ000HCNK
   Coding: 003145
   VCID: 4C972FF6E7A0792626-8018
   Serial number: 3575HRB40550HJHG9ON%
   Serial number: 3585HRB40590HJHG919A
   Serial number: 3515RRB405B0I4AG6OGL
   Serial number: 3525RRB404R0H4DUHPLR
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 870     HW: 6R0 920 870
   Component: KOMBI         H21 0320
   Coding: 140A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   VCID: 72EB910EA5C44FD68C-8026
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 002300
   VCID: 70EF9B06A3C87DC67A-8024
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 130
                    Mileage: 98655 km
                    Time Indication: 0
                    Date: 2012.02.11
                    Time: 12:43:42
   Component: IMMO          H21 0320
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADB896E8D14871634-803E
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 31414
   VCID: 2F6D587AEA76223E23-807A
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:08)--------------------------
I have purchased from Kufentec:
1) xenon adaptors: https://www.kufatec.de/shop/en/volkswag ... vw-polo-6r
2) Autoleveling kit: https://www.kufatec.de/shop/en/volkswag ... vw-polo-6r
I have purchased separately the following:
3) Xenon headlamps with cornering lamps
4) BCM Max p/n:7E0937090B
5) Ballasts for xenon headlamps
I have already received the Kufentec merchandise and have started installing the xenon adaptor kit.
BCM Max has not arrived yet.
Together with the headlights, I will also replace my GTI bumper with the original Polo R bumper. So my final setup is without foglights and I'm looking to replace my switch as well.
My question is:
For the xenon headlights to work perfectly i.e. high beam works without low beam on, DRL dims with signal etc, do I need customized harness that you used to make?
I understand that you have stopped producing harnesses.
Thanks for your assistance!
numberior wrote: Tue Oct 03, 2017 2:57 pm
My question is:
Hi numberior, welcome.
Yes. Open a new topic in 6R/6C forum section with the information (images) we need to help you. :wink:
:arrow: Example
I think the Kufatec xenon adapter harness is already good for the headlights. You just need the wiring for BCM Max
numberior
Drives: Polo GTI 6r
Post by numberior »
Thanks Ciclo and iichel,
I will open a new topic as soon as I take the pics.
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
wow! long time no see. great success ciclo and everybody! i saw iichel already way successful with the keyless entry!!! congratulations!!!
Glad to see you here :D . Have you installed the Bixenon? and Light Assist?
Fabio_89
Drives: Beetle 2.0 TSI
Re: New Member. R-line 1.2 TSI 90hp 119gr.
Post by Fabio_89 »
ciclo wrote: Tue Aug 27, 2013 8:43 pm New mod:
Rear footwell lights
Hi Ciclo,
First, Congratulations for you Polo, amazing car!
Well, see if you can help me.
I own a Beetle 2.0T TSI with 06R 937 088F BCM
I wanna to install footwell lights (front and rear, but mostly in front) but i don't know if it is supported by that BCM and where to Pin it.
Do you have that information ? I saw in you post about rear positions (positive 65A and negative 4A, right?), but how about front lights ?
Hope you can help me
(sorry about my english, i'm from Brazil)
Thank you
benzinkopf
ciclo wrote:Glad to see you here :D . Have you installed the Bixenon? and Light Assist?
Yeah. the wiring ready. Just got my hands on the original bixenon. its 2nd hand without the ballast and xenon which i need to buy soon. The china replica for my testing last time works fine except the quality of light distribution really bad.
On the light assist, No way i can proceed with that coz im still searching for the highline cluster and learning proper tool to do the swap. worst case now, no more new cluster from aliexpress. i’m stuck there for now. [emoji27][emoji17]
Fabio_89 wrote: Fri Oct 06, 2017 6:23 am
Hi Ciclo,
Thank you
Hi Fabio_89, welcome.
I hope you understand the following diagram:
My recomendation.
- Uses LED lamps.
- Connect to any point on the indicated wires (never near of the BCM connectors). The challenge to overcome is that these two wires are the same color for the Beetles.
The reference to follow are the pins of the dome lights.
In this way, by connecting the power to the wire going to T73a/65 and ground to the wire going to T73a/4 your footwell lights will work when opening the door.
The diagram is from the Beetle. (except my horrible sketch)
Locked
