RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
New foglights wires
Terminals https://www.a4-freunde.com/showwiki.php ... uebersicht
T10/3 red connector = JPT (Junior Power Timer)
Fusebox = SPT (Standard Power Timer)
- Drives: Polo 6R
Is this right ?ciclo wrote:New foglights wires
Terminals [emoji666] https://www.a4-freunde.com/showwiki.php ... uebersicht
T73B/9 & T73B/10 are old wires removed from BCM..
Yes, it's exactly the same.
- Drives: Polo 6R
How to identify colour temperature of this bulb D3S 35W?
- Drives: Polo 6R
That I got from googleiichel wrote:put it into google [emoji1] [emoji1]
https://www.google.ch/search?safe=off&q ... 2Y_6XtnXTw
4200K
But is there any number or mark that it is 4200K?
Just for knowledge I want to know
Probably not on the bulb itself, no.
- Drives: Polo 6R
Is electric bridge fitted at right place ?
- Drives: Polo 6R
Dimmer switch yet to install
Wire to parking light yet to install
Following features not working
1) leaving home
2) drl off when indicator on
3) all switch backlights not working
4) when ignition is on tail are remaining on
5) right side cornering lamp gets on for 1 second and goes off when steering is on right side ( bixenon bulb is defused )
6 ) reverse camera not working
Scanning report I will share in sometime
Ok remember when you need help, share as much relevant information as you can. As complete as possible.
What is done to the wiring, vcds autoscan, etc
- Drives: Polo 6R
iichel wrote:Ok remember when you need help, share as much relevant information as you can. As complete as possible.
Yes sure...
Right then I'll tell you what you have to do.smg_shardul wrote: ↑Sat Oct 14, 2017 8:55 am Dimmer switch yet to install
1) leaving home ... ??? surely you mean coming home, it's a semi-automatic function. Read the links.
2) drl off when indicator on ... this is an opcional feature, will be coded.
3) all switch backlights not working ... dimmer.
4) when ignition is on tail are remaining on ....due to the coding you changed.
5) right side cornering lamp gets on for 1 second and goes off when steering is on right side ( bixenon bulb is defused ) ... these problems are inherent to your Bixenon headlamps, wiring installation or .... parts.
- Drives: Polo 6R
I am unable to take vcds scan report it’s not working properly
For cornering lamp of right side I tried to test from output test it’s working but when I steer to right side it’s goes off in 2 secs..
Any solution to this ?
Can you copy/paste the long code of the Central Electrics module?
