Franciswat's Polo 6R 1.6 Bifuel
Re: My polo 6r bifuel
Franciswat wrote: Tue Oct 03, 2017 5:36 pm Maybe I have to write on search box the pin number directly? :wink:
It is not possible, I just checked. :)
Franciswat
Drives: 6R 1.6 Bifuel
Post by Franciswat »
Ok after some searches I found wires sized. :roll:
Looking at the wiring diagram t6/3 of dimmer should go to t73b/1 so I suppose elsa refers to a 7H0 bcm instead of a 7E0.
:arrow: car selected was polo 1.6 bmt highl 66 - 6r142v.
On the contrary I sould see t73b/4 instead of t73b/1 in the wiring diagram, shouldnt I?
I ask just becouse I saw t73b/4 and t73b/1 have different terminals so I want to be sure about wiring! :wink:
Thank you :!:
PS I changed my mind and decided to install a 7E0.
Franciswat wrote: Wed Oct 04, 2017 12:23 am
t73b/4
Franciswat
Hi guys, I finally started working on wirings!
I got this crimper but for some reasons I am not able to use on terminals. :cry:
That tool is FOR INSULATED TERMINALS, it is clearly written on the label attached to it.
Franciswat
Omg you are damn right!!! :oops:
I'll check for right crimper. Thank you mate! :wink:
Franciswat
Hi i completed the bcm installation. Ive some problems because car does not recognise keyfog. I found procedure but It did not work. Can you explain It? Thank you!
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Hi Franciswat! nice mod! i thot i was looking at ciclo’s photos!! Cool.
btw. one interesting thing i found:
did you retrofit just the button set for this steering wheel? or it comes from factory like this?
ive friends who want to install the button set like below to the original steering with only left side button. Not sure its going to fit or not and how can i install the paddle shifter as well.
Franciswat
Guys i do not know What happened but the right headlight is always on (even with car Locked) and left headlight does no longer switch on.
Autoscan (whenever a new problem arises). The installation you have made depends largely on the coding.
I wonder why it is so hard to understand this. :?
Franciswat
You are right mate, I'll provide you more details:
VCDS Version: Release 15.7.1 Running on Windows XP x86
Data version: 20150904
www.Ross-Tech.com
Thursday,02,November,2017,00:52:50:05031
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 25 44 56
VIN: WVWZZZ6Rxxxx   Mileage: 63360km-39370miles
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 210224E3217100B5842524E484D700401300
   Shop #: WSC 00788 648 00255
   VCID: 0008182F9710A43E5D-8054
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
                    Fault Status: 00100101
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 162
                    Mileage: 63369 km
                    Time Indication: 0
                    Date: 2012.03.25
                    Time: 00:00:06
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3023
                    Hex Value: 0x1497
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7FF9
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 397EB5CBB04A35F65A-806C
Address 09: Cent. Elect. (J519)       Labels: None
   Revision: B9080001    Serial number: 0771 060161479
   Coding: 3CB02BBF08E10600923808006D2B0CD100C0412F60860000200000000000
   Shop #: WSC 02737 534 00190
   VCID: 68D8208F9B607C7EF5-803C
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0037
   Coding: 820000
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 08BC32
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 122
                    Mileage: 63369 km
                    Time Indication: 0
                    Date: 2012.03.25
                    Time: 06:48:33
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 K    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0106
   Revision: --------    Serial number: 20251528901029
   Coding: 100001
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_VW57XParkAssis4K 001004
   ROD: N/A
   VCID: 3A7CAAC7BD4C3EEE53-806E
No ASAM data for: "EV_VW57XParkAssis4K" (VW25)
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX011W0JJ
   Coding: 003232
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 4A9CFA07EDACAE6EC3-801E
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB4059124B2F99H
   Crash sensor for side airbag; front passenger side:
   Serial number: 3585HRB4061131GQCOUS
   Crash sensor for side airbag; rear; driver side:
   Serial number: 3515RRB405P0VC0I5P0W
   Crash sensor for side airbag; rear; passenger side:
   Serial number: 3525RRB40510VC0IA9B9
   Part No SW: 6R0 920 871 A    HW: 6R0 920 871 A
   Component: KOMBI         H03 0505
   Coding: 140A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 346084FF9F28C89E89-8060
   Revision: B9080001
   Coding: 002200
1 Fault Found:
            000 -  -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 63369 km
                    Time Indication: 0
                    Date: 2012.03.25
                    Time: 06:48:01
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_DVD_RM09 A03009
   ROD: N/A
   VCID: 6ADC5A878D6C4E6EE3-803E
No ASAM data for: "EV_Immo_UDS_DVD_RM09" (VW36 *)
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6A8B93EA0EEB46F4-807A
1 Fault Found:
01288 - Terminal 30; Steering Assist
            07-10 - Signal too Low - Intermittent
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RD 035 187     HW: 6RD 035 187
   Component: Radio         517 5124
   Revision: RB101000    Serial number: VWZZZ4Q5034465
   Coding: 00000400040005
   VCID: 0400143F8708B81E79-8050
4 Faults Found:
00874 - Treble Speaker Front Left (R20)
            011 - Open Circuit - Intermittent
                    Fault Status: 00111011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 63369 km
                    Time Indication: 0
                    Date: 2012.03.25
                    Time: 06:25:49
00875 - Treble Speaker Front Right (R22)
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 63369 km
                    Time Indication: 0
                    Date: 2012.03.25
                    Time: 06:25:49
00876 - Treble Speaker Rear Left (R14)
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 63369 km
                    Time Indication: 0
                    Date: 2012.03.25
                    Time: 06:25:49
00877 - Treble Speaker Rear Right (R16)
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 63369 km
                    Time Indication: 0
                    Date: 2012.03.25
                    Time: 06:25:49
End-------------------------(Elapsed Time: 02:49)--------------------------
I have a stupid question about wirings: every fuse has 2 pins with unique number, when I have to replace original 34b, 39b and 59b wires with new one which pin I have to replace? :roll:
I have already copied coding from 09-Central Electronics module and 19-CAN Gateway and restored original installation list.
These are some problems occurred:
- Instrument panel and engine switch on but no longer off (neither removing key)
- Headligts do not work properly
- Light dimmer no longer works
- Impossible to set up remote controllers because channel's value doesn't change (image attached)
http://wiki.ross-tech.com/wiki/index.ph ... l_Matching
(I copy and paste here)
Channel 001: Remote Control Matching
Start Matching new/additional Remote Controls by entering 0, then Test and Save the New Value.
Press and hold the Unlock button for at least one second on the Remote Control you want to add, the Blinkers will light up to confirm the Adaptation Process of each Remote Control.
So...
1st remote control ..... 01 Channel .... 0 ... test ... save ... process
2nd remote control ..... 01 Channel .... 0 ... test ... save ... process
and so on... 3rd, 4th, etc, remote controls.
Note: Do not worry, It's not a matter of understanding languages, many English speaking people also have difficulties to understand what is written in the ross-tech link.
(IMHO) I think that who wrote the text of the ross-tech link is a genius, I don't think it can be better explained.
Because some things will change when doing this remote controls adaptation process, report again of the permanent failures with a new autoscan.
What wiring have you installed so far?
- Bcm adaptation wiring :?:
- Bixenon wiring :?:
- Automatic lights wiring :?:
The new BCM coding depends on it.
Franciswat wrote: Thu Nov 02, 2017 12:22 am
Really? ... at this point of your installation?
Are you telling me that you don't know what to do if you expand/enlarge (to infinity and beyond... :lol:) the WL2 image of the following link?
https://drive.google.com/file/d/0B2nv91 ... dDUlE/view
expand/enlarge :arrow: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Franciswat
I am Sorry ciclo i thought i could effort it correctly.
I Will check It again. :oops:
I am sad i am taking you so much time.
