Restoring lost abs long code with new vcds hex v2 pro
Glen
Drives: Vw polo 6r 1600tdi
Re: Restoring lost abs long code with new vcds hex v2 pro
Post by Glen »
thank you iichel for sharing all your knowledge, I do appreciate it. i am not sure when the the guy from vw will have a sedan model to scan for me, so I will try google to see if I can find a scan. vcds is able to read the abs controller at all times , I have checked all fuses and wiring. I hate trial and error.
you could have a look at whether the VINs that are stored in the ECU, in the immobiliser, gateway and instrument cluster are all the same.
Glen
Post by Glen »
thanks iichel, i will have a look and then try and see if I can get it to accept the new codes.
Glen
Post by Glen »
I read somewhere that the skoda pilot esp calculator link that ciclo posted on this forum could be used for a 10 US dollar donation, there's only one problem, when I select donate the page comes up in a foreign language, I have no clue what's written on there, if I just paid them through paypal would that esp calculator be in English? are there any other sites that you could recommend for the esp calculator ?
if your VCDS is original, maybe register at the ross tech forum and open a topic there
V40aas
Drives: Skoda fabia monte carlo
Post by V40aas »
iichel wrote: Sun Oct 29, 2017 10:41 am Done that already ;)
Hi there, i was wondered if you would be able to help me generate a long code for my skoda fabia, appreciate it if you could ?
Let's try
Any chance you could post an autoscan with the current configuration?
Paddon94
Drives: 2011
Post by Paddon94 »
iichel wrote: Mon Jul 15, 2019 8:42 am Any chance you could post an autoscan with the current configuration?
Hi, I was wondering if you could try and find my code for me.
VIN: WVWZZZ6RZBY202858
ESP 8.2i Front H05 0001
6R0 907 379 AK
I'm going to need a full autoscan please
Paddon94
Drives: 2011
Post by Paddon94 »
iichel wrote: Tue Jun 09, 2020 5:57 pm I'm going to need a full autoscan please
Not really too sure how to do it how others were doing it and I’m on this site on my phone, hope these pictures give you what you need. Thank you in advance
Press save on the window you're seeing.
Also please show me the advanced of the immobiliser and the engine please.
Paddon94
Drives: 2011
Post by Paddon94 »
iichel wrote: Wed Jun 10, 2020 1:58 pm Press save on the window you're seeing.
It came up with an error every time I tried to send the saved log, on this website when attaching it. So I’ve taken a picture of the advanced ID’s you needed and enclosed the pictures in this message
Immobiliser advanced ID
Engine advanced ID
Engine advanced ID
Please give this a try
230224DB216D00B4C42D24E784D900801700
230224DB216D00B4C42D24E784D900800700
Paddon94
Drives: 2011
Post by Paddon94 »
I just tried both of those numbers and got a message up saying
“coding rejected
Error22:conditions not correct or request sequence error”
