RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
... have you installed the new Dimmer on your Sedan? :lol:
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
ciclo wrote:... have you installed the new Dimmer on your Sedan? :lol:
Not yet..
I am about to get dimmer switch in another one week.
I will definitely share here first as soon as I get dimmer switch
Licence plate light wiring done last week
In licence plate light connector pin no 2 was +ve searched the common wire of both connectors and connected wire to bcm.
Perfect.
.... I keep waiting to code your BCM with all the possible options in your Sedan. :wink:
smg_shardul
Drives: Polo 6R
ciclo wrote:Maybe, ...show me a fuse box picture and an autoscan from that Polo Sedan.
Here is the pic of fuse box
Scanned report is shared you on mail unable to upload here
It is necessary to add this wire (SB49b to T73b/11) and a 15 Amp fuse in your friend's Sedan, apart from the two wires mentioned above for the cornering lights (foglights).
From the autoscan data,
Thursday,25,May,2017,18:17:16:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWJ13601ET0xxxxx License Plate:
Mileage: 62438 Repair Order: 25052017
Chassis Type: 60 (6RU)
Scan: 01 03 08 09 10 15 17 19 25 44 56
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CLNA) Labels: None
Part No SW: 03L 906 023 NT HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9971
Revision: --H33--- Serial number:
Coding: 00110016030500080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM16TDI02103L906023NT 003012
ROD: EV_ECM16TDI02103L906023CR_VW25.rod
VCID: 8501F79F04D47D36275-80D0
Readiness: 0000 0000
Address 03: ABS Brakes (J454) Labels: None
Part No SW: 6W5 907 37< GF HW: 6W5 907 37< DQ
Component: AGV9.0 fwjnt H04 0054
Serial number: -((-----((----
Coding: 60D82A63212504C40311F470845920070500
Shop #: WSC 00000 640 08352
ASAM Dataset: ESZBrake4DBS90BJVCH 056017
ROD: N/A
VCID: 9521A7DF7474CDB6D75-80C0
No ASAM data for: "ESZBrake4DBS90BJVCH" (VW25)
Part No SW: 6R0 907 044 L HW: 6R0 907 044 L
Component: Climatronic H12 0612
Revision: V0000000
VCID: 3C77D27BBF9E7CFE88B-8069
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6RU 937 086 M HW: 6RU 937 086
Component: BCM IM M+4 H40 0432
Revision: BY040001 Serial number: 0200 258150063
Coding: 3A904ABF08A10000003800002C0B04900000414F60040000200000000000
Shop #: WSC 12469 483 00190
VCID: 6BD521278A702B46511-803E
Subsystem 1 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5520
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Coding: 010000
Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Coding: 240000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361317300143
Coding: 108002
Shop #: WSC 00793 648 00255
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E73D873A1826EEEA6F-806B
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00M0RR+
Coding: 003036
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4999BBAFE84CD95603D-801C
Part No SW: 6RF 920 860 K HW: 6RF 920 860 K
Component: KOMBI H02 0204
Coding: 150800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04718
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 52AB9CC3051A9A8E727-8007
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 086
Component: GW-K-CAN TP20 H40 0432
Revision: BY040001
Coding: 002300
VCID: 19392BEF106C69D673D-804C
Component: IMMO H02 0204
Serial number:
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-44.clb
Part No SW: 6RF 909 144 K HW: 6RF 909 144 J
Component: EPS_ECU H44 0401
Coding: 0000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK.rod
VCID: 54A79ADB3F0E94BE60B-8001
Address 56: Radio (J503) Labels: None
Part No SW: 6RD 035 187 HW: 6RD 035 187
Component: Radio 517 5122
Revision: RB101000 Serial number: VWZZZ4Q5006273
Coding: 00000400040005
Shop #: WSC 00078 790 00236
VCID: 04076A9B87EEC43EB0B-8051
End ---------------------------------------------------------------------
ROD: N/A
What the h... is th., sorry, what is this? :lol:
I do not know if this Sedan has the Steering Angle Sensor (G85) like this viewtopic.php?f=56&t=69603&start=15#p520005 (with inspection window).
This sensor is necessary.
Take a picture of the buttons above the radio.
I suppose it does have the steering angle sensor, otherwise the power steering probably woudn't work? Or does it have its own sensor?
The power steering on the Polo here didn't function when the ABS was having a bad day (so the G85 wouldn' t communicate)
smg_shardul
Drives: Polo 6R
ciclo wrote:It is necessary to add this wire (SB49b to T73b/11) and a 15 Amp fuse in your friend's Sedan, apart from the two wires mentioned above for the cornering lights (foglights).
ROD: N/A
Revision: V0000000
Coding: 010000
Coding: 010000
Coding: 240000
Coding: 020000
Coding: 020000
Coding: 108002
Coding: 003036
Coding: 150800
Revision: BY040001
Coding: 002300
Serial number:
Coding: 0000
ROD: N/A
He is going to install steering angle sensor with stalk...
smg_shardul
Drives: Polo 6R
iichel wrote:I suppose it does have the steering angle sensor, otherwise the power steering probably woudn't work? Or does it have its own sensor?
Thanks iichel for the reply
He is going to install steering angle sensor along with stalks ...
smg_shardul wrote: Tue Nov 07, 2017 5:12 pm
Okay. All solved for your friend.
iichel wrote: Tue Nov 07, 2017 5:09 pm I suppose it does have the steering angle sensor, otherwise the power steering probably woudn't work? Or does it have its own sensor?
http://forums.ross-tech.com/showthread. ... &styleid=2
iichel, you must study before making comments with assumptions. :lol:
smg_shardul
Drives: Polo 6R
Yes all problems solved
Will update once installation is finished
smg_shardul
Drives: Polo 6R
I have one question regarding BCM operated Fog lamps
Can we connect fog lamp to Bcm instead of direct connection from switch ?
Yes, this is definitely possible. It is the same way the OEM static cornering lights in fog lights operate
smg_shardul
Drives: Polo 6R
iichel wrote:Yes, this is definitely possible. It is the same way the OEM static cornering lights in fog lights operate
Cornering lights are in bixenon headlamps
Any option when bixenon installed ?
Then it is not possible
iichel wrote: Fri Nov 10, 2017 11:10 am Then it is not possible
+ 1
