I tried a lot to source only dimmer switch but didn't got it so took with combination of headlight range control which was easily available at vw India service center and will be useless as I installed bixenon headlights
Thanks a lot ciclo for your exceptional support
Thanks a lot govind for helping me to source dimmer switch
Mean while I edited eeprom of amarok cluster which was installed earlier and pending to support to my vento
Successfully edited it to suit it to vento following changes were done after editing eeprom
1) wheel circumference value was changed to 1843 mm from 2350mm
2) Truck logo in mfd display was changed to sedan
3) Brake oil light error was removed
4) Fuel tank characteristics was changed to 55 lit from 80 lit
Thanks a lot Firegrafics , Madwarlock & Benji for providing all information related to eeprom...
Sent from my Pixel 2 using Tapatalk
