benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
ciclo wrote:Well, I have reviewed the diagrams of all the 6R models that I have (I do not have the diagrams of your 6R, built in South Africa plant).
It is not the same pin assignment for all 6R models, that's why you should use the multimeter to locate the pins for your front passenger door contact switch.
Yes. Exactly. I think the diagram that i have also not from South Africa. I will try with multimeter soon. But interestingly, i wonder how i have the Safelock function while the Pin7 is not connected to bcm? any idea?
Unknown to me.
sharan1988
Drives: Polo sedan
Post by sharan1988 »
if i get a flat bottom steering with paddles for my polo sedan tsi with white backlighting . can i replace just my red backlit buttons from my old steering to the new one since its the same looking steering? i want red backlighting because all my other buttons in the car are red.
Yes, if both steering wheels are exactly the same. The buttons can be replaced.
No, if the new steering wheel is a Sport model. The shape of the buttons is different.
Pics?
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
ciclo wrote:Yes, if both steering wheels are exactly the same. The buttons can be replaced.
Pics?
The steering which he has got with white backlight is with paddles and his existing steering is without paddles has red backlight can he swap lights of old steering to new ?
Sent from my Pixel 2 using Tapatalk
The buttons can be exchanged.
For example, look at the images of these buttons: http://www.cars-equipment.com/www/en/sh ... [68237]/1/
All you have to do is remove the trim with one or several plastic tools, then change the buttons, three screws on each side.
Or change the whole set. https://i.ebayimg.com/images/g/aJ0AAOSw ... -l1600.jpg
Maybe:
2H0959442
Read description :arrow: https://www.ebay.de/itm/Original-Multif ... 2513204488
paddle connector
smg_shardul
Drives: Polo 6R
ciclo wrote:The buttons can be exchanged.
Maybe:
2H0959442
paddle connector
The button without paddle don't have plugs of paddle connection
I know, that's why I show you the buttons that meet all the conditions requested by sharan1988.
Which would fit perfectly in your steering wheel.
sharan1988
Drives: Polo sedan
Does the paddles connect to the multifunction buttons ?
Yes they do
sharan1988
Drives: Polo sedan
iichel wrote: Fri Dec 22, 2017 7:11 pmYes they do
Then I can't interchange buttons with red from old steering with no paddles then
sharan1988 wrote: Sat Dec 23, 2017 1:18 am
You can, but maybe they don't have tiptronic function.
Recommendation: Buy a steering wheel from 6C, Amarok 2018 or T6 2015-2018 for lighting in red, tiptronic and leather.
Learn to use ETKA online: viewtopic.php?f=10&t=42713#p466570
Please, if you have more questions open a new topic in the forum and make there the right questions... of what you want or need, thanks.
peter_dk25 wrote: Thu Dec 21, 2017 12:50 pm
ciclo wrote: Wed Dec 20, 2017 11:24 am BTW, the hazard lights button illumination can be clearly seen in the previous video of the VIM. It's possible with (from) BCM 7E0937090B. :lol:
(viewtopic.php?f=56&t=58703&start=3330#p520980)
:wink:
You will need my help, for coding and adaptation. :)
you're going to buy yourself a new polo?
Locked
