Polo 6R 1600 TDI Team
Re: Polo 6R 1600 TDI Team
Ok, but you have the Scandinavian lights activated, Byte12 Bit 0 enable, in all the VCDS autoscan that I saw from your 6R.
e.g, http://forums.ross-tech.com/showthread. ... J519)-quot
What happens if you deactivate them?
- Turbodruk
- Drives: Polo 6R 1600 TDI Team
Tried enabling/disabling Scandinavian lights, didn't work. Also parking lights & city lights (?) don't work. iichell sugested I should switchT14/12 and 10 around at the BCM. I will look into that tomorrow.
Ok ... when possible for you.
hmm... you both were having a few beers when made the installation
... it's another good option when someone meets to do these car things ... hahaha.
However, it would be interesting to install the wire from T10/9 to T73b/29 to see what happens.
No but we had some great Spanish wine
Michel, install the T73b/29 wire in your 6R, once installed, activate/deactivate Byte12 Bit 0. It's very interesting to know what happens.
Will do shortly
No different effect; DRL still bright LED and parking lights still dimmed LED.
Ok, then it's perfect. Now you can have true DRLs (with the taillights off). This is great.
But you didn't answer my previous question viewtopic.php?f=56&p=528202#p528184 (without the new wire T73b/29).
Yes haha I know Fernando but I have the tail lights on on purpose.
I like this more, with the tail lights on .
Bit 12 bit 0 off changes:
No tail lights and license plate lights with bright DRL but DRL led is bright
DRL LED off with indicator (with bit 0 on it dims)
LED will go off when the handbrake is pulled in DRL mode (with bit 0 on it dims)
Yes, I know, in fact I've seen several Dutch 6R Autoscan that way, but it is not legal.
However, this is another problem solved.
So Turbodruk must install this wire when he solve the problem of the wires that reach the BCM from the LED headlights.
- Turbodruk
Switched up the cables, the right side drl’s are now working, the left aren’t. They turn on for a splitsecond and turn off.
I’ll post an autoscan when I get home.
LED headlight. Left.
From BCM 7E0 ----> to LED headlight.
T73b/5---->T14/10 (58, parking/side light)
T73b/3---->T14/12 (DRL / TFL)
I wonder... better no ask...
- Turbodruk
Done exactly that, wonder why it’s giving me the finger.ciclo wrote: Thu Dec 28, 2017 12:56 pm LED headlight. Left.
I wonder... better no ask...![]()
I’ll look into it.
Isn't today the April Fools day in Spain?
