Cheers m8... just wish i had bought one from ECP when i drove there to collect the other stuff i neededGroovyCarrot wrote: The thing you've labelled "What's this?" in the first picture is the water pump.
PETE
Hey if the Haynes says it's OK then they probably lifted it straight out of the dealer technical info - I just know when I di the LC head gasket it specifically states in one sweep for 180 deg and it's hard to do it on your own - mind you it also said use mineral oil to lubricate the threads not synthetic (apparently it makes a difference to the torque settings - believe me at over £600 for head gasket and bolts I wasn't about to do anything except by the book)LogIK wrote:bstardchild, the Haynes states after stage 2, you angle tighten either two 90 deg turns or one 180 deg turn. I did it in two 90 deg turns, but I can't see how it would matter.
bstardchild wrote:believe me at over £600 for head gasket and bolts I wasn't about to do anything except by the book)
Yeah, same placeLogIK wrote: Did yours leak oil from the corner near the alternator, where the main oil gallery is?
Coz it seemed to be jammed around the waterpump sprocket & was annoying me shall we say at that moment in time, lolLogIK wrote: Can I ask why you had to break the cam cover?!
Couldn't find anything in the haynes relating to thisLogIK wrote:Also, I may be stating the obvious here and it is too late now, but remember when loosening off head bolts, do them in reverse sequence order, starting with number 10.
there's a picture in the section on doing the head gasket. are you saying you just undid them in any old order? you could've warped the head doing that.
The loosening sequence should be the reverse of the tightening sequence which is given in the haynes.
bstardchild wrote:Correct but although it might be too late - you can warp a head (esp alloy ones) if you don't undo the bolts in the same sequence as they are to be done up - always follow the sequence doing up or undoing
0.1 mm maximum distortion.pete69zx wrote:Whats the tolerances for the 'head' ?
