Bixenon headlights with AFS For polo gt Tsi 2015
hmthakur
- Drives: Polo gt tsi 1.2 dsg
Re: Bixenon headlights with AFS For polo gt Tsi 2015
master ciclo,
will this receiver and valve sensors work with tpms of my car.
IC software = 0705 or higher
BCM = 7E0 937 090B or higher
TPMS unit = 3AA 907 273 F
Sensors/valves = 3AA 907 275 F
have installed gti cluster 6RD920870A, ic software:-0805
Already posted latest vcds scan
as far as I can see, that should work
I'm not 100% sure about the part number for the TPMS module, I think 3AA 907 273 H and higher have component protection
Yeshmthakur wrote: Mon Jan 01, 2018 2:54 pm master ciclo,
hmthakur
Headlight connector in my car driver side
I don't need the pics from headlights connectors. Thanks anyway.
Pictures from:
Relay carrier
Original Light Switch connector, both sides.
Dimmer connector
... and some pic of your 6R, current headlights, foglights, etc...
Pictures from:
Relay carrier
Dimmer connector
hmthakur
My gt tsi front
My car back
Interior
Thanks for the images.
Still to be published:
Relay carrier.
Dimmer connector.
The trick in the wires is for the reversing light, right?
Your Dimmer is on its way from Germany.
Relay carrier.
Dimmer connector.
hmthakur
Fuse Box
Headlight switch
Dimmer switch
Headlight switch
Dimmer switch
hmthakur
Relay carrier
Fog lamp connector
Fog lamp connector
hmthakur
Many thanks for the pictures.
Your new Dimmer arrives on Wednesday 10th to my VW dealership.
Waiting for ...
As you are going to install Bixenon headlights which include the static cornering lights, it is necessary that you install a new wiring for the fog lights.
Wait a moment please, I'm going to find the link to purchase this wiring ...
https://www.ebay.de/itm/VW-Polo-6R-Kabe ... 2eb91b124a
Waiting for ...
hmthakur
Ordered the bixenon headlights today will be receiving them in 10- 15 days
hmthakur
ciclo wrote:Many thanks for the pictures.
Waiting for ...
Ciclo will i need fuse holder and fuse also??
If you install this wiring through the fuse box - slot 54 = SB54 - you only need the fuse.
Instead of connecting it to the light switch (not is possible with Auto switch) you must connect it to the red connector according to your installation guide (pg 10, where it says 8 yellow/white -->3 red connector).
Very easy, from fog lights to SB54b---SB54 (15A)---SB54a and from here the wire to slot 3 red connector.
