UPGRADING BCM 6R
Re: UPGRADING BCM 6R
govindsharma wrote: Mon Jan 15, 2018 1:39 pm Dear Good Evening
Here is the final result in my car of TPMS.I had installed all parts of TPMS today with Antenna and tire sensors.I had given power to Antenna from fuse 17 which is vacant. CAN high and low from PDC unit.
As expected after my instructions for your 6R. Great. 8)
govindsharma wrote: Mon Jan 15, 2018 1:39 pm But please tell me if air is low in any of the tire then where it indicate either in IC with low pressure indicator or in four wheel figure which is in MFD.
It will do it this way:
https://www.youtube.com/watch?v=1TnpHOz ... tu.be&t=39
iichel wrote: Mon Jan 15, 2018 1:44 pm i'm not sure about SB17, it's listed as the fuse for the windscreen washer pump.
it it can be OK. i think it should be a +30 (constant power) for the TPMS high.
You are uninformed, as usual ...always making mistakes.
viewtopic.php?f=56&t=69603&start=15#p519510
.. or do you need me to explain it to you? :evil:
very good, there is a new retrofitted +30 wire in place for this mod. all clear.
govindsharma
Drives: polo 1.2 petrol HighLine
Post by govindsharma »
Dear ciclo Sir Good Morning
Yes as per your instruction i had done all mods done with good results.Thanks a lot for your kind support and useful instructions..
Dear iichel Sir this fuse is vacant in my car and ciclo sir made this fuse extension for +30 in my car see this image.
Thankyou.
govindsharma
Saturday,13,January,2018,17:59:54:49450
VCDS Version: 16.8.0.3
Data version: 20161010 DS255
www.Ross-Tech.com
VIN: MEXD16603GTGOVIND   License Plate:
Mileage: 6340km-3939mi   Repair Order:
Chassis Type: 60 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 44 56 65 0B
VIN: MEXD16603GT082427   Mileage: 6340km-3939miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CJLA)       Labels: None
   Part No SW: 03E 906 019 AQ    HW: 03E 906 019 AQ
   Component: SIMOS11.2     H04 1968
   Revision: --H04---    Serial number:
   Coding: 00110016032400000000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12MPI02103E906019AQ 001001
   ROD: N/A
   VCID: 73E5B5AADA7402DAAD-8026
No ASAM data for: "EV_ECM12MPI02103E906019AQ" (VW25)
Readiness: 0000 0100
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 6R0 907 379 BP    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0003
   Serial number: --------------
   Coding: 60DD2763212B18C20618E46B845818000000
   Shop #: WSC 00000 000 08192
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 0D11C352DC90742ADB-8058
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Component: LENKW.SENSOR  H06 0060
   Serial number: 090465LEA0003X
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF3949EE1365FB2D2-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 41892F62D848E04AEF-8014
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 352161207
   Coding: 3AB02BBF48A3000001380FB07E8B9E905FC0616F60AC20C0200000030800
   Shop #: WSC 12345 123 12345
   VCID: 2A5B68CE453E0312DE-807E
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 311215 03  37  0059
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  020 2551
   Serial number: 13202848160111221608
   Coding: 350000
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  020 2551
   Serial number: 13202849160107223746
   Coding: 040000
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Serial number: 0111607164000748AB2B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  019 1552
   Serial number: 13102728160108150857
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  019 1552
   Serial number: 13202729160111111032
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 K    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0106
   Revision: --------    Serial number: 35821404004439
   Coding: 308001
   ASAM Dataset: EV_VW75XParkAssis4K 001004
   ROD: EV_VW75XParkAssis4K.rod
   VCID: 3A7B588EBD9EB392AE-806E
   Revision: --------    Serial number: 003GW013KE03
   Coding: 003036
   VCID: 49993742E878280A37-801C
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H03 0805
   Coding: 140A01
   Shop #: WSC 17218 938 12345
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 479D317AFE6CDE7A21-8012
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002300
   VCID: 68DFD2C69BB2F10208-803C
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 040401E200000000000000
   VCID: 2E5364DE71D66F3202-807A
   Component: IMMO          H03 0805
   VCID: 6ADBA8CE8DBEC3121E-803E
Address 44: Steering Assist (J500)       Labels: 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000001000000
   ROD: EV_SteerAssisNSK_VW12.rod
   VCID: 41892F62D048E04AEF-8014
Address 56: Radio (J503)       Labels: User\6RD-035-187.lbl
   Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
   Component: MIB2-S-R-CN   025 0210
   Revision: -----001    Serial number: 12765GD0082357
   Coding: 00000440000000
   Shop #: WSC 00081 790 00184
   VCID: 45813B72CC60CC6AD3-8010
   Serial number: 30000000060895
   ROD: EV_RDKBERU30_VW36.rod
   VCID: 377D41BA8E8CAEFA51-8062
End-------------------------(Elapsed Time: 03:02)--------------------------
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Stunning! 8)
govindsharma
Dear all Indian Members GOOD NEWS how have polo with electric fold side mirrors they may make them auto fold with remote without cutting any wire or void warranty(OEM) Ciclo sir made this possible in my polo i will be very thankful to him for giving me such a kind support.I am sharing video of it and will post autoscan soon in one more day. Ciclo sir explain rest of it.
Thank you .
Thanks to you, in reality you, and only you were who be able to find the correct encodings with some basic instructions that I gave you.
The secrets of all this is in the reference number of the WRMs and their codings, therefore we'll have to wait for you to post the autoscan. :lol: The important thing is that it has been achieved in a 6R RHD IND. OEM.
I start to have a special affection for your 6R.
Thanks for sharing the video. 8)
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Congratulations!!!! what a nice mod!
btw, if i understand correctly, the side mirror will fold automatically by locking the car. and it will then unfold automatically by ignition on? Can the unfold process enable when unlocking the door?
as i’m looking forward for the foldable side mirror installation, i will want to install side mirror doorpuddle leds. if the unfold process is not during the unlocking process, it would be awkward to see the doorpuddle lights switch on while the side mirror is folded. [emoji848] any idea?
benzinkopf wrote: Wed Jan 24, 2018 5:51 pm Congratulations!!!! what a nice mod!
Yes, only. That's already an achievement in a 6R RHD IND.
Puddle lights unfolding with remote. :mrgreen:
VK70
Drives: VW Vento 1.2 TSI Highline
Post by VK70 »
govindsharma wrote:Dear all Indian Members GOOD NEWS how have polo with electric fold side mirrors they may make them auto fold with remote without cutting any wire or void warranty(OEM) Ciclo sir made this possible in my polo i will be very thankful to him for giving me such a kind support.I am sharing video of it and will post autoscan soon in one more day. Ciclo sir explain rest of it.
Thank you .
Nice.I have been trying to enable this on my Vento TSI.Can you please explain how you managed to do this?Was it through coding alone?
Sent from my ONEPLUS A5000 using Tapatalk
Subsystem 2 - Part No SW: 6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU021021440523980
Coding: 1400B3
Subsystem 3 - Part No SW: 6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU004101300011381
Coding: 0400B3
... and all the functions will work like a charm!... auto folding mirror function too.Image
govindsharma
Dear sir autoscan of car
VIN: MEXD16603GOVIND
   ROD: N/A
   Coding: 01
   Revision: V0000000
   Coding: 0728DD
   Coding: [b][color=#FF0000]1400B1[/color][/b]
   Coding:[b][color=#FF0000] 0400B3[/color][/b]
   Coding: 240000
   Coding: 308001
   Coding: 003036
   Coding: 140801
   Revision: B9081001
   Coding: 002300
   Revision: AA001001
End-------------------------(Elapsed Time: 03:06)--------------------------
Coding: 1400B1
Coding: 0400B3
