benzinkopf wrote: Tue Jan 23, 2018 12:59 pm
I did change the channel value from 2 to 1 yesterday. Im sorry for the delay review because im still testing it to see the different. With ch37 set to 95, ch36 to 1, i feel like the activation time is pretty much the same but i do think the turn-off process (after the turning) feel faster. is the same channel 36 responsible for both activation and deactivation?
There is some adapt channels descritions below, which came from VagCanPro descriptions concerning corner lights on PQ25 BCM
31 channel
From this speed on the cornering light is available
Dimension: 1 km/h,
Allowable value limits: 0…20,
Default value: 0, that mean the corner works even if car is stopped if you make this value more than 0 it will work only while car is moving
32 channel
Until this speed cornering light is available (beware hysteresis + — 5km/h!)
Dimension: 1 km/h,
Allowable value limits: 20…80,
Default value: 40, that means coner light stop working on speed higher than 40km/h
33 channel
Activite the corner light on at this steering angle (speed influence)
Dimension: 1 degree,
Allowable value limits: 0…254,
Default value: 80, that means coner light works when steering wheel turn on 80 or more degrees
was discovered by ciclo long before
viewtopic.php?f=56&t=58703&p=517482#p517482
34 channel
Deactivite the corner light on at this steering angle (speed influence)
Default value: 30, that means corner light stops working when steering wheel turn on 30 or less degrees
35 channel
Time until cornering light gets full brightness completely
Dimension: 0,25 sec,
Allowable value limits: 0…8,
Default value: 2, that means coner light gets full brightness in a 0,5 sec
36 channel
Time until cornering light has faded out completely
Dimension: 0,5 sec,
Default value: 2, that means coner has faded out in a 1,0 sec
Maximum brightness after fadin in
37 channel
Maximum brightness of the corner light after it gets full brightness
Dimension: 1 %,
Allowable value limits: 0…100,
Default value: 80, that means coner will get only 80% max brightness
