Posts: 8982 Joined: Sun Feb 24, 2013 10:20 am
Post
by ciclo » Tue Jan 30, 2018 6:34 pm
benzinkopf wrote: Tue Jan 30, 2018 5:39 pm
ciclo wrote:
Not is recommend having a unit installed (e.g the 55 address) without the sensor/s that make it work correctly.
Yes. donot do this at home
[emoji23]
This is what happen when there’s part missing in action - No bracket still!
federicodrdpro
Posts: 117 Joined: Sat Jan 30, 2016 4:22 pm
Drives: White Polo 6R TDI
Post
by federicodrdpro » Tue Jan 30, 2018 6:58 pm
Now I tried the car on the road and the heating don't work. AC start but only cold air goes out. Any idea?
Posts: 6695 Joined: Fri Nov 14, 2014 2:14 pm
Post
by iichel » Tue Jan 30, 2018 7:04 pm
is the engine warm? usually it took my car (same engine) about 10km to get up to temperature. with the climatronic, it will use an additional electrical heater too.
federicodrdpro
Post
by federicodrdpro » Tue Jan 30, 2018 7:11 pm
Yes, I drove for 20km. Usually after 6-7km it start to produce hot air. All glass were full of condensate.
Post
by iichel » Tue Jan 30, 2018 7:17 pm
if you turn on the knob for warm/cold dair, do you hear some movement in the heating housing?
is it heavy or light to turn the knob?
what does VCDS say about the temperature of the engine coolant and oil?
federicodrdpro
Post
by federicodrdpro » Tue Jan 30, 2018 7:25 pm
I already checked the knob. It move the gear of the heating housing. I hear the same noise and it have the same weight of ever.
Coolant temperature is 79°C and oil temperature is 69°C now.
The car is stopped from about 25 minutes.
federicodrdpro
Post
by federicodrdpro » Tue Jan 30, 2018 7:35 pm
Problem solved . The knob of heating house moving the gear but not the heating house.
EDIT: iichel, could you download your parametrization zdc file of the 6R0 907 357 control unit?
federicodrdpro on Tue Jan 30, 2018 10:31 pm, edited 1 time in total.
Post
by iichel » Tue Jan 30, 2018 8:15 pm
federicodrdpro wrote: Tue Jan 30, 2018 7:35 pm
Problem solved . The knob of heating house moved the gear but not the heating house.
Sure, if you can tell me how to do so.
federicodrdpro
Post
by federicodrdpro » Wed Jan 31, 2018 7:01 pm
Who have a VCP original should ask to VCP Support to provide the file. They can provide it.
I have the zdc file of 6R0 907 357 C (Polo) and 6R0 907 357 (VW T5).
Post
by iichel » Wed Jan 31, 2018 7:46 pm
I have an original VCP cable
federicodrdpro
Post
by federicodrdpro » Wed Jan 31, 2018 7:52 pm
VW T5
6R0907357
VW Polo
6R0907357C
Can we edit the
6R0907357 file?
federicodrdpro
Post
by federicodrdpro » Thu Feb 08, 2018 7:22 pm
ciclo, which diode I have to install for HBA?
Post
by ciclo » Thu Feb 08, 2018 7:37 pm
I used this one:
It works like a charm.
