Headlight upgrade H4 Xenon >> Dual H1/H7
doubelus
Drives: Polo 6R 2013 Style
Post by doubelus »
Hello All!
My first post!
I have a Polo 6R 2013, I wanted to upgrade the headlight assembly for sometime now,
I have finally got an assembly from https://www.sw-tuning.de/en/SW-Light-he ... 42210.html
The new assembly came with 02 Lamps (H1/H7) instead of the OEM Dual beam H4,
After installation, everything worked fine, apart from High beam flashing which is not working ..any ideas?
Thanks!
Low Beams
Low Beams
High Beams
High Beams
Re: Headlight upgrade H4 Xenon >> Dual H1/H7
credits to ciclo for the image
doubelus
Post by doubelus »
Thanks a lot iichel I will test that now!
Hello doubelus, welcome. :wink:
More info here :arrow: viewtopic.php?t=68139#p508917
It consists of adding a single wire from the light switch connector to the J331 relay, removing and isolating the existing one there.
