Amarok Oem Bixenon retrofit
Re: Amarok Oem Bixenon retrofit
yes, most of them, but not all. for example, be sure it is the right frequency for central locking 433/433 or 315mhz
No iichel, precisely you know that not all BCM Max work for a certain model of Bixenon headlights or LED headlights.
Amarok Bixenon headlights work like the LED headlights for 6R/6C or T6. (with two modules)
With the best of my intentions:
Sometimes I do not know what you're thinking about, to get to this ref. number (color) 7E0937090C ZKK took me 15 minutes checking all PR codes
for the LED headlights, I completely agree. PR 8IT is needed for the PWM signal to the DRL/parking light LED module of LED headlights
But for the bi-xenon + LED headlights, on amarok, it's Amarok gas discharge headlights = PR 8IH
http://www.oemepc.com/vw/part_single/ca ... 725/lang/e
PR 8IH is needed.
http://www.oemepc.com/vw/part_single/ca ... 256/lang/e
--> 4G0907697F
long story short, yes, you cannot use any 7H0 BCM.
PR 8IH is needed.
--> 4G0907697F
Yes, but the ETKA assumes that you know the equipment that is installed in a specific car model, so it does not show all the PR codes.
The ETKA is not designed so that we can make improvements to the cars, so we must use the knowledge acquired to find the right part for an improvement.
Good point.
Impossible to know without knowing the equipment of the donor car.
georgenis
- Drives: Amarok
So the donor car must have led daylight? This BCM is from a 2016 T6 Multivan.
From T6 is right, but must have LED headlights.georgenis wrote: Thu Feb 08, 2018 6:30 pm So the donor car must have led daylight? This BCM is from a 2016 T6 Multivan.
georgenis
- Drives: Amarok
One more question, I hope You don't mind: any 7H0937090D BCM will work (from whatever car is,T5, T6, Amarok,...)?
No will not work
georgenis
- Drives: Amarok
So I will buy 7H0937090D Z4R with Pr codes 8K0,8K1,7L3,8IH and 9PR,9AD. This BCM should work with my light system and Bixenon with led, and also Climatic? It is not so expensive new.
