Retrofit golf mk7 steering wheel on polo mk5
Re: Retrofit golf mk7 steering wheel on polo mk5
firebulletz
Drives: Polo comfortline 1.6 tdi 90cv
Post by firebulletz »
iichel wrote:how to post a VCDS autoscan :) --> http://forums.ross-tech.com/showthread. ... -Auto-Scan
I can't do it now. I have not the cable and the program [emoji21] these are not good?
Inviato dal mio SM-G935F utilizzando Tapatalk
Hahaha..... because I know that you're a very funny guy and not familiar with these Autoscan matters. The Autoscan you'd post is the best VCDS autoscan in the history, ... in all forums I know ...
Thanks for that (sincerely), these things always are the best. Image
Those Golf MFSW buttons are installed correctly, but we need to see the full autoscan.
For example, this is the last autoscan from my 6R:
Wednesday,07,February,2018,11:46:50:32438
VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180122 DS285.1
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: W-Test
Mileage: 29360km-18243mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77
VIN: WVWZZZ6RZDY0CICLO   Mileage: 29360km-18243miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   VCID: 6A8D3FD44CF80237D61-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 025D77745448FA777E1-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5038420709E971A9-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3829D59C425460A7905-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 122170091
   Coding: 3CB02FBF48E32400B3380F916CEB9FDCDAC0672F600D30D0200000030800
   VCID: 2B03FAD08302DB3FED7-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000A3
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E25C38460F05E975A9-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F542C38E237F61-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H04 0805
   Coding: 140E01
   Shop #: WSC 00233 572 00000
   VCID: 47CBA6603F2A1F5FE9F-8012
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002200
   VCID: 688945DC52743027C05-803C
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2E05F3C4B090AE17CA9-807A
   Component: IMMO          H04 0805
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2A0DFFD48CF8C237161-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5274
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 372BD6A04F4A6FDF99F-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA71FC1F-807A
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77AB16A00F4AAFDF59F-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 40000000050821
   ROD: EV_RDKBERU30_005.rod
   VCID: 372BD6A04FCA6FDF99F-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B23CA9073E24BBF7D7-806E
End----------(Elapsed Time: 01:59, VBatt start/end: 14.0V/14.0V)-----------
Tell your electrician to give you the autoscan in a TXT file and post it here.
To sum up:
- Those MFSW buttons (and none) are not compatible with your IC without MFA+.
- They are not compatible at all for the CCS.
- Neither are compatible with stalk buttons for DIS (display information system). :arrow: (2015)
- Once you have the correct combination of IC, MFSW buttons, and stalks, you may have to configure the buttons functions on your big radio. (as seen in the videos that I post previously)
... end of story.
firebulletz
Tomorrow i will go on my electrician.
In future i will change the instrument cluster with mfa+, but for now I'll have to leave what I have for quite some time.
Two others questions:
1- there is a way to install these buttons without changing bcm or buttons with 1k8?
2- [I don't know if this is a verifiable thing]
My actual bcm is compatible with coming/leaving home, folding mirrors, instrument cluster mfa+, automatic lights, rain sensor (for the windshield wipers and to have the windows automatically closed in the event of rain) and anti-glare mirror? If not, with what is compatible my bcm with things written before?
I apologize if I ask too many questions and if I am heavy sometimes, but I would like to do many things and unfortunately I do not know anyone able to do them. I thank you for everything already now. I'm sorry [emoji23][emoji23]
The way they are installed ... some things will work and others will not. :)
(NO), folding mirrors (maybe), instrument cluster mfa+ (YES), automatic lights (NO), rain sensor (for the windshield wipers (YES) and to have the windows automatically closed in the event of rain (maybe)) and anti-glare mirror (YES)? If not, with what is compatible my bcm with things written before? :lol:
firebulletz
ciclo wrote:1- there is a way to install these buttons without changing bcm or buttons with 1k8?
(NO), folding mirrors (maybe), instrument cluster mfa+ (YES), automatic lights (NO), rain sensor (for the windshield wipers (YES) and to have the windows automatically closed in the event of rain (maybe)) and anti-glare mirror (YES)? If not, with what is compatible my bcm with things written before? [emoji38]
Ok, to have coming/leaving home and automatics lights i have to change bcm.
6r0937088f or 6r0937087t are good also for steering wheel buttons? Or is only 7e0937090 compatible?
Your current BCM is known as High (it's not Max), well, since middle 2015 all BCMs High installed in new 6Rs and PQ25 family (other markets) are compatible for the MFSW backlighting. (new models)
2017 or 2018 BCM High (6R0...) from Russia or India are perfect and cheap for your 6R (no needs extra wires) in case you decide to buy one of second hand.
Plug ... coding .... and Play.
Maybe firegrafik can help you in this matter.
firebulletz
ciclo wrote:Your current BCM is known as High (it's not Max), well, since middle 2015 all BCMs High installed in new 6Rs and PQ25 family (other markets) are compatible for the MFSW backlighting. (new models)
Ok. I need to know only what bcm i have to buy.
And if I decide not to add ch/lh and automatic lights, if i will change the buttons with 1k8 it will work with my bcm 6r0937087k with the two additional cables or i could have other problems?
firebulletz
[/quote]
VCDS?
Autoscan?
radio pics?
[/quote]
this is the vcds autoscan... i think i have a big problem :| :?
Tuesday,20,February,2018,18:53:57:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY080849   License Plate:
Mileage: 210660km-130898mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZCY080849   Mileage: 210660km-130898miles
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 MA    HW: 03L 907 425 B
   Component: 1,6l R4 CR td H33 8849
   Revision: --H33---    Serial number:
   Coding: 00114016002400080000
   ASAM Dataset: EV_ECM16TDI02103L906023MA 003004
   ROD: EV_ECM16TDI02103L906023LL.rod
   VCID: 71E8ED58A0A91BCE75-8024
Readiness: 1100 0000
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3417500B2842D14E682DA00421100
   VCID: 071CA380B22D357ECB-8052
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326A22546D2F60D64C-8066
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0251
   Revision: BF046001    Serial number: 0434 237113707
   Coding: 3CB02BBF08A10000003808006D2B0CD00080412F60860060200000000000
   Shop #: WSC 124697 483 00190
   VCID: 45806988CCA1E76EF9-8010
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU025081100010210
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU001091100015461
   Coding: 08BC30
   Subsystem 3 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160001436780076301
   Coding: B0FFFF
   Subsystem 4 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Serial number: KU0KU017081100014087
   Coding: 08BC32
   Subsystem 5 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Serial number: KU0KU030081100014426
   Coding: 08BC32
4 Faults Found:
01758 - Bulbs for Brake Lamps
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 127
                    Time Indication: 0
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 109
                    Time Indication: 0
00447 - Function Limitation due to Over-Voltage
            001 - Upper Limit Exceeded - Intermittent
                    Fault Status: 00100001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 109
                    Mileage: 210095 km
                    Time Indication: 0
                    Date: 2012.07.05
                    Time: 00:00:21
00975 - Heated Rear Window (Z1)
            012 - Electrical Fault in Circuit
                    Fault Status: 01101100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 210105 km
                    Time Indication: 0
                    Date: 2012.07.05
                    Time: 20:27:05
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00UZUX8
   Coding: 003232
   VCID: 4A9A5AB4EDBF081614-801E
   Serial number: 3575HRB40690OCUIB06N
   Serial number: 3585HRB40690OCUIDPHJ
   Serial number: 3515RRB405B0M98E4981
   Serial number: 3525RRB40650MFP6O92Q
1 Fault Found:
12854016 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [008] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 111
                    Reset counter: 95
                    Mileage: 209589 km
                    Date: 2018.02.03
                    Time: 10:57:17
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: KOMBI         H04 0206
   Serial number: 00000008663469
   Coding: 140A00
   ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
   ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
   VCID: 3A7A0A74BD5F989684-806E
2 Faults Found:
13893888 - Function Restricted due to Exessive Voltage
          U1401 00 [008] - -
                    Fault Priority: 6
                    Fault Frequency: 3
13893632 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 210095 km
                    Date: 2018.02.12
                    Time: 00:00:09
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0251
   Revision: BF046001
   Coding: 002200
   VCID: 70EEE85CA3A312C67A-8024
2 Faults Found:
            000 -  -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 128
                    Reset counter: 255
                    Time Indication: 0
01304 - Radio
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 36
                    Mileage: 202439 km
                    Time Indication: 0
                    Date: 2012.02.17
                    Time: 11:35:30
Address 25: Immobilizer (J285)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H04 0014
   Serial number:
   ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
   ROD: EV_ImmobUDSJCIPQ25.rod
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F6C2B20EA1D4D3E23-807A
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:52)--------------------------
You don't have a big problem, you have many small problems ... :lol:
Nevertheless some faults in that autoscan are intermittent or were not cleared.
It's clear that something in the electrical installation of your non-OEM radio was not or is not connected correctly, maybe the CAN Bus module. I thought I saw something related to its configuration through the menus in the previous videos.
As I told you, the MFSW buttons are connected correctly. Maybe you should try A4FFFF coding instead of B0FFFF coding, but it's just in trying to make something work, maybe it'll not even have any effect.
Buy the appropriate parts. (already explained)
firebulletz
ciclo wrote:You don't have a big problem, you have many small problems ... [emoji38]
There is tutorial for this a4ffff coding?
What is the appropriate parts? I don't remember
firebulletz
I apologize if I repeat and if I am insistent, but I would like to be sure before buying.
What i have to buy, 7e0937090 (or 7h0937090?) or 1k8 steering wheel buttons?[emoji23]
You can buy a compatible 6R0 or 6RD BCM (2016 --->) to avoid having to make modifications to the wiring. This will make the steering wheel backlight work.
You can buy some Stalks without TRIP computer buttons. This will avoid incompatibilities with the buttons on the steering wheel.
You can buy the 1K8 buttons. They are the correct ones.
You can buy an IC with MFA +. This will make all buttons useful.
Read my previous replies.
spacewalker
Drives: Just a VW
Post by spacewalker »
End of February I will update my module to be compatible with PQ25 platform.
After new update you can run any MQB MFSW and operate CCS too (with ccs or acc,) or basic just to MFA and radio
also you can run PQ35 MFSW
No need to replace BCM to highline , keep old one
all you need is a require wires for CCS and LIN to corresponding with MFSW over SlipRing
cars with external BT module like 3C8 or 7P6 require extra emulator (this is BT issue) but is already sorted
2 configurations available (all is tested in PQ35 platform durring last 2 years)
-cars w/o externall BT or with RNS 315 (built in BT) or MIB for PQ platform - no need HighLine BCM and not require Emulator
-cars with external Bt such as 5K0 , 5N0, 3C8, 7P6 , 1Z0 .... require HighLine BCM and extra emulator
With my module you can operate radio even if you not have MFA+ cluster
any questions, you can ask below or PW message
spacewalker wrote: Fri Feb 23, 2018 6:10 am End of February I will update my module to be compatible with PQ25 platform.
Hi spacewalker
This is great for the PQ25 platform. I want it (of course).
With MQB do you mean 6C MFSW too? Just to clarify doubts.
Now I send you some information by private message. :wink:
