Amarok Oem Bixenon retrofit
georgenis
Drives: Amarok
Re: Amarok Oem Bixenon retrofit
Post by georgenis »
The DRL are not working at all. there is no 12v supply on pins 5 and 6 from t73b, only 4,5v with parking lights on. We need 12v with ignition on on pins 5 and 6 to have drl.
georgenis
Drives: Amarok
Post by georgenis »
The leds are working on parking lights (with car original wiring) and main beam.
What is your coding of byte 23?
georgenis wrote: Sat Feb 24, 2018 1:50 pm The leds are working on parking lights (with car original wiring) and main beam.
If you do not do exactly what is indicated by me, you will never make your lights work correctly.
iichel wrote: Sat Feb 24, 2018 1:50 pm What is your coding of byte 23?
georgenis
Drives: Amarok
Post by georgenis »
For what is needed the modification with T17/16 wire? With original wiring everything is working on parking lights (also the leds).
georgenis
Drives: Amarok
Post by georgenis »
I have done the modifications with T17/16 wire and the parking lights are working now (including the front leds). Still no DRL.
Byte 23 bit 6 is 1
georgenis
Drives: Amarok
Post by georgenis »
VCDS
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 17.8.1(x64) Data version: 20171130 DS276.6
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Saturday,24,February,2018,17:08:05:57327
VIN: License Plate:
Mileage: 57340km-35629mi Repair Order:
Chassis Type: 2H-VN81 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 22 25 32 37 56 69 0B
VIN: WV1ZZZ2HZDA007105 Mileage: 57340km-35629miles
22-AWD -- Status: OK 0000
32-Differential Locks -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CNEA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 012 AD HW: 03L 907 309 AC
Component: R4 2,0L EDC H21 2710
Revision: 74H21--- Serial number: 00000000000000
Coding: 01594012230600080001
Shop #: WSC 07456 790 50316
ASAM Dataset: EV_ECM20BTD01103L906012AD 001002
ROD: EV_ECM20BTD01103L906012AD_001.rod
VCID: 66C37F8499B822760B-8032
Readiness: 0 0 0 0 1
VCDS
Self-Diagnosis Log
Page 2
VIN: License Plate:
Address 03: ABS Brakes (-----) Labels:. 2H0-907-37x-ESP.clb
Part No SW: 2H0 907 379 L HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0110
Revision: 00H44001
Coding: B07324B691940D9C24A389A36F5590
Shop #: WSC 07456 790 49164
VCID: 3979E4F8B0867D8E96-806C
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 2H0 907 047 E HW: 2H0 907 047 E
Component: Climatic-T5 H20 0505
Revision: 00001008
Coding: 0000000002
ROD: EV_ClimaT5Basis.rod
VCID: 2A5BCBB44D20C616EF-807E
Part No SW: 7E0 937 089 HW: 7E0 937 089
Component: BCM PQ25 MMI4 H80 0736
Revision: BB080001 Serial number: 0772 205170114
Coding: 640000380C21000000280CC12C4B84D42D00654E60021040300000020000
Shop #: WSC 18752 008 00032
VCID: 70EF19DCA37CFCC661-8024
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3321
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3321
Coding: 100000
Subsystem 3 - Part No SW: 2H0 959 442 HW: 2H0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H01 0103
Serial number: 27150001639610035324
Coding: A4FFFF
VCDS
Self-Diagnosis Log
Page 3
VIN: License Plate:
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231432400057
Coding: 110003
Shop #: WSC 12345 123 12345
VCID: 3B75FEF0B2BA4F9E84-806E
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00B H07 0013
Revision: -------- Serial number: 003HN0089MTP
Coding: 000000000000000000000000000000003042
Shop #: WSC 07446 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3365D6D09AEA87DE5C-8066
Serial number: 3495RRB40691138A20JK
Serial number: 3505RRB405J134DQFHQ$
Serial number: 3555YRB40084UHPKEHU1
Crash sensor for front airbag: front passenger side:
Serial number: 3565YRB40064UHPKPPUJ
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 2H0 920 861 C HW: 2H0 920 861 C
Component: KOMBI H05 0605
Coding: 170200
ROD: EV_Kombi_UDS_VDD_RM09_004_VN35.rod
VCID: 275D32805E32FB7EF0-8072
VCDS
Self-Diagnosis Log
Page 4
VIN: License Plate:
Part No SW: 7E0 909 901 HW: 7E0 937 089
Revision: BB080001
Coding: 002000
VCID: 68DF71BC9BAC340639-803C
Address 22: AWD Labels: None
Part No SW: 2H0 927 755 C HW: 2H0 927 755 C
Component: SG offroad VTG 0155
Revision: 00H07000 Serial number: T1IYC136215TSM
Coding: 0000013
Shop #: WSC 131071 1023 2097151
VCID: 306FD9DCA3FCBCC621-8064
Component: IMMO H05 0605
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADB0BB48DA006162F-803E
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 A HW: 2H0 927 771
Component: Quersperre H04 0017
Revision: 11001001 Serial number: 4DG 16.05.12 00
Coding: 000001
ASAM Dataset: EV_QuersUDSAAMVN817 A01606
ROD: EV_QuersUDSAAMVN817.rod
VCID: 2C57CDAC47D4D8261D-8078
VCDS
Self-Diagnosis Log
Page 5
VIN: License Plate:
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 N HW: 3C0 035 279 N
Component: RNS315-EU H52 0319
Serial number: VWZAZ2M5927569
Coding: 000002110200150000031001
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 2E53C7A471C8AA3633-807A
Data medium:
Subsystem 1 - Part No: 3AA 919 866 A
Component: EUR_E_V8 0069
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030189325
Coding: 0100000100000000
VCID: 306FD9DC63FCBCC621-8064
End-------------------------(Elapsed Time: 02:45)--------------------------
georgenis
Drives: Amarok
Post by georgenis »
I have changed at this coding byte 23 bit 0 on (high beam alternate voltage for terminal 58), because without bit 0 on, I had bulb error on instrument cluster when flashing.
georgenis
Drives: Amarok
Post by georgenis »
There are only 2V on headlight pin 10 with DRL on. On pin 4 are 12V.
georgenis
Drives: Amarok
Post by georgenis »
The led parking lights are working, the main beam with led parking lights are working, the flash is working, the static cornering lights are working.
No DRL.
I copy and paste:
Second step
Front parking/side lights
Left
Isolate original wire T10/10 headlight connector.
Install new 0.5mm2 wire from T10/10 headlight connector to T73b/5 BCM white connector.
Right
Install new 0.5mm2 wire from T10/10 headlight connector to T73b/6 BCM white connetor.
DRLs
Isolate original T17/3 light switch connector. Remove fuses SC26 and SC27.
Install new 0.5mm2 wire from T17/3 to T73b/29 BCM white connector.
Left
Isolate original wire T10/4 headlight connector.
Install new 0.5mm2 wire from T10/4 headlight connector to T73b/3 BCM white connetor.
Right
Install new 0.5mm2 wire from T10/4 headlight connector to T73a/5 BCM black connector.
Maybe you made a mistake when you installed the cables and you have exchanged the wires dedicated to parking lights with wires for the DRLs.
Check it.
I asked you this question before:
ciclo wrote: Sat Feb 24, 2018 1:41 pm Have you made the second step in its entirety? :arrow: viewtopic.php?f=56&t=70902&start=30#p530329
viewtopic.php?f=56&t=70902&start=60#p530843
georgenis
Drives: Amarok
Post by georgenis »
I have checked them many times. There is no mistake in the wiring. I also have 12v on t17/3 wire going to Bcm with Drl on.
If there was mistake in the wiring the leds wouldn’t work on parking lights or main beam. They are working dimmed.
Ok, thanks for answering my question.
I'm going to review some things.
Off topic:
I don't explain some things to you because I have good reasons not to explain them publicly.
You must understand that's Saturday and just at this moment is when my family leaves me a little of free time.
