Amarok Oem Bixenon retrofit
Re: Amarok Oem Bixenon retrofit
Looks brilliant with the new cluster
Maybe some of these links is useful for you.
http://www.uk-polos.net/viewtopic.php?f ... 05#p474349
http://www.uk-polos.net/viewtopic.php?f ... 95#p477710
http://www.uk-polos.net/viewtopic.php?f ... 65#p491539
http://www.uk-polos.net/viewtopic.php?f ... 65#p491577
http://www.uk-polos.net/viewtopic.php?f ... 30#p504328
http://www.uk-polos.net/viewtopic.php?f ... 82#p517482
http://www.uk-polos.net/viewtopic.php?f ... 15#p517604
http://www.uk-polos.net/viewtopic.php?f ... 20#p518296
http://www.uk-polos.net/viewtopic.php?f ... 20#p518219
http://www.uk-polos.net/viewtopic.php?f ... 80#p520980
viewtopic.php?f=56&t=58703&start=4020#p529332
Thanks to you for your great collaboration!
Btw, how about the CCS?
georgenis
- Drives: Amarok
The CCS is working. No problem with it.
georgenis
- Drives: Amarok
Do You know if Amarok have TPMS? (ABS version)
The ABS version is not possible for the Amarok according to Erwin
The only possible version is the direct TPMS.
- Check that address 65 is available in the GW installation list of your BCM.
- The IC software must be 0705 or higher. (yours is 0709
georgenis
- Drives: Amarok
The Coming Home is working. I forgot to say.
Yes, BCM Max manages the 'Coming Home' function without the need for a light sensor, so I activated it in the codings I made for you. Thanks for reporting.
Please, the Autoscan when possible.
I am from Cluj, Romania i have the same issues with the xenon retrofit, where did made for you the coding?
Thank You
Thank You
Hello aronclb, welcome.
Please, post a VCDS autoscan, thanks.
Does the coding differ from car to car? Because i tried some codes posted on internet in forums but nothing happend, also the guy who installd the headlights told that he can not communicate with the headlight calculator. Also the vcds differ and are with wich one you can make more coding than with the other?
Please can you tell me who did it for you georgenis? I have issues with the led drl! Thank you
I believe this was the solution.georgenis wrote: Wed Feb 28, 2018 7:09 am He told me that he put the Bcm on other Amarok with xenon headlights from factory and made with ODIS a lights parameteres configuration, and then put the Bcm back in my car.
This also can be made with Vag commander.
When I arrive home I will post also the coding, but he told me is the same.
