RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
govindsharma
Drives: polo 1.2 petrol HighLine
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Post by govindsharma »
smg_shardul wrote: Mon Jan 22, 2018 3:39 pm
ciclo wrote:Thanks for letting us know.
Did you take pictures of the process?
Yes I took I will edit and upload here tomorrow...
Sent from my Pixel 2 using Tapatalk
Dear your tomorrow is big I think it takes more than 10 days to come tomorrow.Please share if possible some are waiting here to see your your great work.
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
I am out of station will reach my town by Tuesday...
smg_shardul
Drives: Polo 6R
For installation of twin barrel headlamp on H4 headlight setup we need to transfer all wires from 4 existing connector (indicator, headlight range control , indicator, parking light) to an new 10 pin connector & add 1 wire between T17 light switch connector and headlight relay
Following material is needed to Installation
1) 4 wires 1sqmm with 0.5m length
2) 2 10 pin connector
3) insulated tape
4) Terminal extracting tool
10 pin connector
10 pin connector
Remove existing headlight and it's 4 connectors extract all wires from existing connector by using terminal extracting tool and transfer to new 10 pin connector one by one.
For right side headlight 3 wires of H4 bulb are short in length use 1sqmm wire for extending wires .
For functioning of low beam and high beam together we need to add wire between T17 connector and headlight relay
Wire diagram of relay
Headlight relay
Headlight relay
Thin yellow wire of headlight relay
Wire connected to T17/7
Connect 1 sqmm wire to T17/7
Look for the thin yellow wire connected to headlight relay behind relay carrier that's the T5zv/2 cut and isolate existing wire and connect new wire coming from T17/7 by crimp or scotch lock.
Excellent, thank you very much for show us this job. 8)
The last image is somewhat confusing because it seems that the arrow points to the T17/4, it does not matter, the idea is what it's worth.
By the way, what model year is that car and what model? Just to make it clear. Thanks.
smg_shardul
Drives: Polo 6R
Post edited and uploaded correct pic
Actually forgot to click pic of T17 connector so attached the pic randomly
Got the pic from thakur s post...
The car in which I have installed headlight is 2010 manufactured Polo sedan Highline
smg_shardul
Drives: Polo 6R
Hey ciclo I have one question
Does 7E0937089A BCM support Auto light function?
Latest vento is equipped with this BCM
This car has Full LED headlights with DRL
One of my friend want to install Auto lights in his car.
yes it most certainly does support automatic lights
smg_shardul wrote: Sun Mar 11, 2018 2:06 pm Hey ciclo I have one question
Yes
smg_shardul
Drives: Polo 6R
Yes
What I have to do can you help me here ?
smg_shardul
Drives: Polo 6R
iichel wrote:yes it most certainly does support automatic lights
Yeh I also think same as all pins are quite similar of BCM Max and 089 BCM...
smg_shardul wrote: Sun Mar 11, 2018 5:19 pm
Yes
Of course I can help you.
I have to see an original Autoscan from this car to tell you exactly what to do. There are two possible solutions.
Send me the Autoscan by email. :wink:
smg_shardul
Drives: Polo 6R
ciclo wrote: Yes
Ok I will send you auto scan tomorrow
Do you need pics of fuse box , relay, T17 connector and current headlight switch as well?
From light switch only, both sides.
smg_shardul
Drives: Polo 6R
ciclo wrote:From light switch only, both sides.
Ok I will share you all things tomorrow
Nikhil
Drives: 1.6 tdi
Post by Nikhil »
Hi.
I have installed BCM MAX 090 D in Polo sedan in India. Shardul is my friend. The car is same like sharduls car except it have normal fog lamps while sharduls car have cornering fog lamps. I have just changed canbus lines from bcm to instrument cluster for now. I have done same thing on one more car but it was manual transmission car. Issue is after bcm max reverse light stoped working. Its a dsg car. I tried everything possible but not able to get power for reverse light. Old bcm works perfect for reverse light. If reverse light issue get solved i am planning to install bixenon headlights with headlight adaptation wiring.
