Help Retrofit OPS Module
kctai
Drives: polo sedan
Post by kctai »
Hi, guys im having problem with my retrofit.
OPS high and Low can-bus powertrain is tap for instrument cluster Pin 28 and 29.
when engage to reverse nothing shows in the radio.
the following is the VCDS scan.
thanks in advance.
__________________________________________________________________________________________________________________
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 55 56
VIN: PPVZZZ60ZHL000295
10-Park/Steer Assist -- Status: Cannot be reached 1100
Address 01: Engine
Cannot be reached
Unable to communicate with address 01,
and "Force K on engine" is activated.
Part No SW: 0AM 300 065 T HW: 0AM 927 769 F
Component: GSG DQ200G2_PQ 052 2501
Revision: 00005026 Serial number: CU501609045609
Coding: 0000020
Shop #: WSC 83300 833 00007
VCID: 40889B421318834458-8014
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2C63412307C0461634728256E0800908
ASAM Dataset: EV_Brake1ESP9i0BOSCH 003031
ROD: N/A
VCID: 0B127C6EA2DE101C7D-805E
No ASAM data for: "EV_Brake1ESP9i0BOSCH" (VW25)
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 418E9E46D8128A4C57-8014
Part No SW: 7E0 937 089 A HW: 7E0 937 089
Component: BCM PQ25 MMI4 H81 0744
Revision: BB081001 Serial number: 0972 249160289
Coding: 3A904BB808A1240012380600344B049000C0604F60C51960210000000820
Shop #: WSC 12345 123 61029
VCID: 316ECE8668B21ACCA7-8064
Subsystem 1 - Part No SW: 6R0 959 802 DF HW: 6R0 959 802 DF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 022 1522
Serial number: 13202722160907152418
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 DD HW: 6R0 959 801 DD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 022 1522
Serial number: 13102723160828213906
Coding: 010000
Subsystem 3 - Part No: 6RU 951 171
Component: Sensor, DWA 0 005 0502
Subsystem 4 - Part No: 6RU 951 171
Subsystem 5 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 2161619140502028AB1B
Coding: 240000
Subsystem 6 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1522
Serial number: 13102728161002213031
Coding: 020000
Subsystem 7 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1522
Serial number: 13202729160905224234
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E HW: 1Q0 919 475
Component: P0 919 475 T ARKHILFE 4K H03 0212
Revision: -------- Serial number: 32961635204288
Coding: 108102
ASAM Dataset: EV_VW75XParkAssis4K 001013
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 4382944ECA0E985C45-8016
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Component: VW10AirbagU0E H10 0020
Revision: -------- Serial number: 003GX02BC7VT
Coding: 003045
ASAM Dataset: EV_AirbaVW01BPAVW250 A01001
ROD: N/A
VCID: 4A9CB96AED24491486-801E
Subsystem 1 - Serial number: 3495RRB40185735IMGJM
Subsystem 2 - Serial number: 3505RRB40185735IC21F
No ASAM data for: "EV_AirbaVW01BPAVW250" (VW25)
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 6RF 920 861 B HW: 6RF 920 861 B
Component: KOMBI H01 0215
Coding: 140A000000
ASAM Dataset: EV_Komb_iUDS_VDD_RM09 A05729
ROD: N/A
No ASAM data for: "EV_Komb_iUDS_VDD_RM09" (VW36 *)
Part No SW: 7E0 909 901 HW: 7E0 937 089
Component: GW-K-CAN TP20 H81 0744
Revision: BB081001
Coding: 002300
VCID: 68D863E29BE89B04B0-803C
1 Fault Found
03075 - Parallel Parking Assistance Control Module (J791)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 250
Mileage: 14554 km
Time Indication: 0
Date: 2015.04.03
Time: 18:06:09
Address 25: Immobilizer (J334) Labels:* Redir Fail!
Component: IMMO H01 0215
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADC19EA8DE4A914A6-803E
Address 44: Steering Assist
Cannot be reached
Address 55: Headlight Range
Cannot be reached
Address 56: Radio (J503) Labels: None
Part No SW: 6RF 035 187 HW: 6RF 035 187
Component: Radio 019 0120
Revision: -------- Serial number: VWZGZ1S0074153
Coding: 00000440040000
VCID: 06044D5AB1BC6D7422-8052
1 Fault Found
01327 - Control Module for Parking Aid (J446)
Fault Priority: 6
Fault Frequency: 1
Reset counter: 249
Mileage: 14552 km
Time Indication: 0
Date: 2015.04.03
Time: 07:55:50
End-------------------------(Elapsed Time: 03:00)--------------------------
Re: Help Retrofit OPS Module
No in your car the instrument cluster of not on the power train can network bit it has its own network in bcm max and high (7e0 937 089/090)
Take the can lines from the steering column wiring loom, orange with black and orange with brown.
After that it should work.
kctai
Drives: polo sedan
Post by kctai »
Hi iichel,
It's mean that the method below is not working?
The attachment IMG-20180320-WA0008.jpg is no longer available
In your case this won't work, I'm sorry.
kctai
Drives: polo sedan
Post by kctai »
Hi iichel,
May I know how to identify the steering column wiring loom?
it's on the steering column
I agree with iichel in the diagnosis, like the doctors. :lol:
By the way, Polo Sedan with LED headlights. Very interesting (BCM coding).
The question is, is the BCM coding intact (from factory) for the lights?
also interesting --> CC via MFSW but byte 29 bit 6 disabled
iichel wrote: Tue Mar 20, 2018 10:32 am also interesting --> CC via MFSW but byte 29 bit 6 disabled
I'm afraid not.
Ah yes, now I see. 6C0 959 442A is with CC. google shows a lot of images with CC buttons but that's A.
then it's interesting why byte 17 bit 2 is on
iichel wrote: Tue Mar 20, 2018 10:44 am then it's interesting why byte 17 bit 2 is on
I think we're going of topic a bit, but cc by mfs is connecting mfsw to t73b/36, setting byte 17 bit 2 and 29 bit 6 and finding out your abs doesn't like it, right?
No iichel, we already know all that long ago.
The/my real problem that I do not find a natural way to understand what you have written. :lol:
"then it's interesting why byte 17 bit 2 is on"
In this BCM coding the Byte17 Bit2 is not activated.
kctai
Drives: polo sedan
Post by kctai »
Guys thanks the OPS module now is working fine after i connect directly to the BCM module.
Perfect, thanks for reporting the results.
Can you please provide us more info about your Polo Sedan? Pics? Thanks
(read our conversation)
