Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
Re: Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
Looks like a very successful installation. Congratulations to you, and to everyone who supported you.
vento2013
- Drives: 6R Polo(Vento)1.6TDi, Skoda Fabia 1.2MPi
Thank you iichel pls do check coding is it correct? and one question. will cornering fog light works when only parking light is on?iichel wrote: Wed May 16, 2018 1:15 pm Looks like a very successful installation. Congratulations to you, and to everyone who supported you.
vento2013
Selection process
only picture of installation Nikhil in image
After installation 4am
No cornering lights will only work with low beam on.
The coding is intended for LED headlights?
vento2013
I have copied coding from Bi-Xenon installed car. Fog light was not working. So edited bit, now fog working
I'll have to rely on ciclo for making the best coding for BCM High to BCM Max (7E0), I'm sorry.
But what do you want the coding for? Bi-Xenon or LED headlights?
BCM
New coding
3A904BBF48A10000013807006CCB96900080604F60CD31E1210000030020
RLS (VCDS 17.X or higher)
New coding
0728DD
Gateway
New coding
002300
Clear all DTC's before to do a new autoscan.
Make a new autoscan.
Post the new autoscan.
The more faults, better.... repeat with me ... the more faults, better.
Please use your VCDS version.
New coding
New coding
0728DD
Gateway
New coding
002300
vento2013
LED Headlights..iichel wrote: Wed May 16, 2018 4:27 pm But what do you want the coding for? Bi-Xenon or LED headlights?
Ciclo replied
vento2013
Will try shortly and updateciclo wrote: Wed May 16, 2018 4:40 pm BCM
New coding
New coding
0728DD
Gateway
New coding
002300
vento2013
After this coding observation as belowciclo wrote: Wed May 16, 2018 4:40 pm BCM
New coding
Pass light(using left stalk) = working fine only High beam
Switch position to parking = Parking is ON
Fog lights = working (when fog is on parking off)
SCL = Only Left cornering is working. Right side not working
Auto scan did No errors in installation list but in address line 04(Attached new scan report)
1 Fault Found:
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
it was not there earlier
Updated Coding
Updated Coding
Thursday,17,May,2018,16:30:35:39744
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWJ13601ET024078 License Plate: KA47M3663
Mileage: 62345km-38736mi Repair Order: New Ciclo coding
Chassis Type: 60 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56 0B
VIN: WVWJ13601ET024078 Mileage: 62345km-38736miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CLNA) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 NT HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9971
Revision: --H33--- Serial number: 00000000000000
Coding: 00110016032500080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02103L906023NT 003012
ROD: EV_ECM16TDI02103L906023MJ.rod
VCID: 05064A5684BA6669DA-8050
Readiness: 0000 1000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 BF HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0001
Serial number: --------------
Coding: 60DD2F63212504C40614F470845920020000
Shop #: WSC 57830 002 1048576
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 0302544E8A8E5859F4-8056
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Serial number: 23101713470492
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF425BAE16C35B19B-802A
1 Fault Found:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 62345 km
Date: 2016.01.30
Time: 15:18:54
Voltage terminal 15: 12.20 V
Voltage terminal 30: 12.50 V
Terminal 15 status: On
Part No SW: 6R0 907 044 L HW: 6R0 907 044 L
Component: Climatronic H12 0612
Revision: V0000000
VCID: 3C70EFB2BFF0E7A1F5-8068
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 320170423
Coding: 3A904BBF48A10000013807006CCB96900080604F60CD31E1210000030020
VCID: 2B52DCEE4A9E70196C-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 230118 04 47 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5520
Serial number: 13202576130625091059
Coding: 010000
Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Serial number: 13102579130618031221
Coding: 010000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Serial number: 2671409414901055AB1B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Serial number: 13102580130620031450
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13102581130620063454
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361317300143
Coding: 108002
Shop #: WSC 00793 648 00255
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E74E5BAA1ECF5B1DB-806A
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00M0RR+
Coding: 003036
Shop #: WSC 01383 785 00200
VCID: 499E8666E82242097E-801C
Part No SW: 6RF 920 862 HW: 6RF 920 862
Component: KOMBI H01 0214
Coding: 140A000000
Shop #: WSC 13202 938 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
VCID: 091E4666A8A20209BE-805C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002300
VCID: 68D863E29BE89B0141-803C
Component: IMMO H01 0214
Serial number:
VCID: 6ADC19EA8DE4A91157-803E
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V1.clb
Part No SW: 6RF 909 144 K HW: 6RF 909 144 J
Component: EPS_ECU H44 0401
Coding: 0000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK_SK26.rod
VCID: 54A0A7123F600FE11D-8000
Address 56: Radio (J503) Labels: None
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 534 5314
Revision: -------- Serial number: VWZZZ4H6267388
Coding: 16000440040005
Shop #: WSC 127395 840 08317
VCID: 46848D5AF13CAD7193-8012
My previous Coding
3A904BBF48E10200013807916CCB96905A88676F608D30C1200000030000
with this coding observation as below
Pass light(using left stalk) = High beam n low beam both gets on
Switch position to parking = Parking is OFF
SCL = Both working fine
With the new coding, high beam signal should be OK. for the parking lights, you'll need to wait for the new BCM.
vento2013
Ok. but why Right cornering not working? Left is working. and there was no error for Steering angle sensoriichel wrote: Thu May 17, 2018 1:03 pm With the new coding, high beam signal should be OK. for the parking lights, you'll need to wait for the new BCM.
but both font fogs are working?vento2013 wrote: Thu May 17, 2018 1:10 pmOk. but why Right cornering not working? Left is working. and there was no error for Steering angle sensoriichel wrote: Thu May 17, 2018 1:03 pm With the new coding, high beam signal should be OK. for the parking lights, you'll need to wait for the new BCM.
vento2013
Yes. If turn on the switch both fog is working
vento2013
Sorry.. After new coding fog is not working..
Fog is working with this code
My previous Coding
