Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
Re: Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
So with
3A904BBF48A10000013807006CCB96900080604F60CD31E1210000030020
The fogs are not working and only one static cornering light works (left)
With this coding:
3A904BBF48E10200013807916CCB96905A88676F608D30C1200000030000
Front fogs are working? And both static cornering lights?
With this coding:
vento2013 wrote: Thu May 17, 2018 12:44 pmAfter this coding observation as belowciclo wrote: Wed May 16, 2018 4:40 pm BCM
New coding
Pass light(using left stalk) = working fine only High beam
Switch position to parking = Parking is ON
Fog lights = working (when fog is on parking off)
SCL = Only Left cornering is working. Right side not working
Auto scan did No errors in installation list but in address line 04(Attached new scan report)
1 Fault Found:
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
it was not there earlier
1
The fault of the steering angle G85 is not visible in the previous autoscan with/due to VCDS 12.12, even the address 04 (G85) does not appear in the reading (check it), but the fault is present since then.
With the VCDS 17.1 the fault and the reading of this address 04 are present.
SCLs depend of steering angle G85 (address 04), so...
Are you absolutely sure that the locking mechanism of the T41 connector is firmly tightened?
It is a very common failure in these processes. The tab must go to the end. PUSH IT firmly.
2
Your BCM coding copied from Shardul's Vento is totally wrong for your Vento and LED headlights. Don't use it again.
3
Use only my new BCM coding (perfect coding for your LED headlights), it is the starting point to make your "LED headlights" work properly when you install the right parts, BCM, ...
Wait for me to correct the new BCM coding for your "current electrical installation".
Will be corrected again depending of the results.
Note: What is clear in the autoscan is that all wiring that I sent you work perfectly, another very different thing is the compatibility of the parts, lights, wires, G85, etc ... that you decide to install in your Vento.
3A904BBF48A10000013807006CCB96900080606F60CD39E1210000030020
Tell us the result. Light by light, please.
vento2013
- Drives: 6R Polo(Vento)1.6TDi, Skoda Fabia 1.2MPi
DRL = OK
Pass Light = OK (Only High beam)
Parking light = OK (When Headlight is on parking is OFF) Need Specific BCM.
Low Beam = OK
High Beam = OK
Fog Lights = OK (Parking goes OFF)
Static Cornering = Not working
CH/LH = OK
Thursday,17,May,2018,23:07:53:39744
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWJ13601ET024078 License Plate: KA47M3663
Mileage: 62340km-38736mi Repair Order: Ciclo code2
Chassis Type: 60 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56 0B
VIN: WVWJ13601ET024078 Mileage: 62340km-38736miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CLNA) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 NT HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9971
Revision: --H33--- Serial number: 00000000000000
Coding: 00110016032500080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02103L906023NT 003012
ROD: EV_ECM16TDI02103L906023MJ.rod
VCID: 05064A5684BA6669DA-8050
Readiness: 0000 1000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 BF HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0001
Serial number: --------------
Coding: 60DD2F63212504C40614F470845920020000
Shop #: WSC 57830 002 1048576
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 0302544E8A8E5859F4-8056
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Serial number: 23101713470492
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF425BAE16C35B19B-802A
1 Fault Found:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 62345 km
Date: 2016.01.30
Time: 22:59:31
Voltage terminal 15: 12.00 V
Voltage terminal 30: 12.30 V
Terminal 15 status: On
Part No SW: 6R0 907 044 L HW: 6R0 907 044 L
Component: Climatronic H12 0612
Revision: V0000000
VCID: 3C70EFB2BFF0E7A1F5-8068
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 320170423
Coding: 3A904BBF48A10000013807006CCB96900080606F60CD39E1210000030020
VCID: 2B52DCEE4A9E70196C-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 230118 04 47 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5520
Serial number: 13202576130625091059
Coding: 010000
Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Serial number: 13102579130618031221
Coding: 010000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Serial number: 2671409414901055AB1B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Serial number: 13102580130620031450
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13102581130620063454
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361317300143
Coding: 108002
Shop #: WSC 00793 648 00255
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E74E5BAA1ECF5B1DB-806A
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00M0RR+
Coding: 003036
Shop #: WSC 01383 785 00200
VCID: 499E8666E82242097E-801C
Part No SW: 6RF 920 862 HW: 6RF 920 862
Component: KOMBI H01 0214
Coding: 140A000000
Shop #: WSC 13202 938 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
VCID: 091E4666A8A20209BE-805C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002300
VCID: 68D863E29BE89B0141-803C
Component: IMMO H01 0214
Serial number:
VCID: 6ADC19EA8DE4A91157-803E
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V1.clb
Part No SW: 6RF 909 144 K HW: 6RF 909 144 J
Component: EPS_ECU H44 0401
Coding: 0000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK_SK26.rod
VCID: 54A0A7123F600FE11D-8000
Address 56: Radio (J503) Labels: None
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 534 5314
Revision: -------- Serial number: VWZZZ4H6267388
Coding: 16000440040005
Shop #: WSC 127395 840 08317
VCID: 46848D5AF13CAD7193-8012
End-------------------------(Elapsed Time: 02:44)--------------------------
3A904BBF48A10000013807006CCB96900080676F60CD39E1210000030020
DRL = OK
Low Beam = OK
High Beam = OK
Static Cornering = OK Working perfectly
CH/LH = OK
Thursday,17,May,2018,23:30:50:39744
www.Ross-Tech.com
Mileage: 62340km-38736mi Repair Order: Ciclo 2+Edit
Readiness: 1000 1000
Coding: 01
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 62345 km
Date: 2016.01.30
Time: 23:27:35
Voltage terminal 15: 11.70 V
Voltage terminal 30: 12.05 V
Revision: V0000000
Coding: 3A904BBF48A10000013807006CCB96900080676F60CD39E1210000030020
Coding: 0728DD
Coding: 010000
Coding: 010000
Coding: 240000
Coding: 020000
Coding: 020000
Coding: 108002
Coding: 003036
Coding: 140A000000
Revision: B9082001
Coding: 002300
Serial number:
Coding: 0000
3A904BBF48A10000013807006CCB96900080676F60CF39E1210000030020
maybe this makes your parking lights work, but at full brightness instead of 100%
just use it as temporary solution until the correct BCM arrives of course
vento2013 wrote: Thu May 17, 2018 7:26 pm
I have made small change in code
DRL = OK
Low Beam = OK
High Beam = OK
CH/LH = OK
Thursday,17,May,2018,23:30:50:39744 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 17.1.3.0 Data version: 20170220 DS267.3 www.Ross-Tech.com VIN: WVWJ13601ET024078 License Plate: KA47M3663 Mileage: 62340km-38736mi Repair Order: Ciclo 2+Edit -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 60 (7E0) Scan: 01 03 04 08 09 10 15 17 19 25 44 56 0B VIN: WVWJ13601ET024078 Mileage: 62340km-38736miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 56-Radio -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CLNA) Labels: 03L-906-023-CAY.clb Part No SW: 03L 906 023 NT HW: 03L 907 425 B Component: 1,6l R4 CR td H33 9971 Revision: --H33--- Serial number: 00000000000000 Coding: 00110016032500080000 Shop #: WSC 00788 648 00255 ASAM Dataset: EV_ECM16TDI02103L906023NT 003012 ROD: EV_ECM16TDI02103L906023MJ.rod VCID: 05064A5684BA6669DA-8050 No fault code found. Readiness: 1000 1000 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: Redir Fail! Part No SW: 6R0 907 379 BF HW: 6R0 907 379 AQ Component: ABS9.0 front H01 0001 Serial number: -------------- Coding: 60DD2F63212504C40614F470845920020000 Shop #: WSC 57830 002 1048576 ASAM Dataset: EV_Brake1ABS90BOSCH 003017 ROD: EV_Brake1ABS90BOSCH_VW25.rod VCID: 0302544E8A8E5859F4-8056 No fault code found. ------------------------------------------------------------------------------- Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb Part No SW: 6R0 959 654 HW: 6R0 959 654 Component: LENKW.SENSOR H07 0070 Serial number: 23101713470492 Coding: 01 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_LWSKLOVW25X 005001 ROD: EV_LWSKLOVW25X.rod VCID: 7EF425BAE16C35B19B-802A 1 Fault Found: 1140738 - Steering angle sensor B1168 54 [009] - Missing Calibration / Basic Setting Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 7 Mileage: 62345 km Date: 2016.01.30 Time: 23:27:35 Voltage terminal 15: 11.70 V Voltage terminal 30: 12.05 V Terminal 15 status: On ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb Part No SW: 6R0 907 044 L HW: 6R0 907 044 L Component: Climatronic H12 0612 Revision: V0000000 VCID: 3C70EFB2BFF0E7A1F5-8068 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 C HW: 7E0 937 090 C Component: BCM PQ25 Max4 H82 0752 Revision: B9082001 Serial number: 4000 320170423 Coding: 3A904BBF48A10000013807006CCB96900080676F60CD39E1210000030020 Shop #: WSC 00788 648 00255 VCID: 2B52DCEE4A9E70196C-807E Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB Component: RLS 230118 04 47 0106 Coding: 0728DD Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB Component: ------------- 006 5520 Serial number: 13202576130625091059 Coding: 010000 Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB Component: ------------- 006 5520 Serial number: 13102579130618031221 Coding: 010000 Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442 Component: E221__MFL-TAT H04 0019 Serial number: 2671409414901055AB1B Coding: 240000 Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L Component: ------------- 006 5520 Serial number: 13102580130620031450 Coding: 020000 Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L Component: ------------- 006 5520 Serial number: 13102581130620063454 Coding: 020000 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb Part No SW: 6R0 919 475 C HW: 7E0 919 475 Component: PARKHILFE 4K H11 0013 Revision: -------- Serial number: 47361317300143 Coding: 108002 Shop #: WSC 00793 648 00255 ASAM Dataset: EV_VW250ParkiAssis2 S01008 ROD: EV_VW250ParkiAssis2.rod VCID: 3E74E5BAA1ECF5B1DB-806A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 5K0-959-655.clb Part No SW: 6R0 959 655 J HW: 6R0 959 655 J Component: VW10AirbagU06 H10 0020 Revision: -------- Serial number: 003GW00M0RR+ Coding: 003036 Shop #: WSC 01383 785 00200 ASAM Dataset: EV_AirbaVW10BPAVW250 A01001 ROD: EV_AirbaVW10BPAVW250_VW25.rod VCID: 499E8666E82242097E-801C No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 6RF 920 862 HW: 6RF 920 862 Component: KOMBI H01 0214 Serial number: 00000000000000 Coding: 140A000000 Shop #: WSC 13202 938 00000 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729 ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod VCID: 091E4666A8A20209BE-805C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: None Part No SW: 7E0 909 901 HW: 7E0 937 090 C Component: GW-K-CAN TP20 H82 0752 Revision: B9082001 Coding: 002300 Shop #: WSC 00788 648 00255 VCID: 68D863E29BE89B0141-803C No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H01 0214 Serial number: Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: 6ADC19EA8DE4A91157-803E No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V1.clb Part No SW: 6RF 909 144 K HW: 6RF 909 144 J Component: EPS_ECU H44 0401 Coding: 0000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SteerAssisUDSNSK 005005 ROD: EV_SteerAssisUDSNSK_SK26.rod VCID: 54A0A7123F600FE11D-8000 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: None Part No SW: 6RD 035 187 B HW: 6RD 035 187 B Component: Radio 534 5314 Revision: -------- Serial number: VWZZZ4H6267388 Coding: 16000440040005 Shop #: WSC 127395 840 08317 VCID: 46848D5AF13CAD7193-8012 No fault code found. End-------------------------(Elapsed Time: 02:44)--------------------------
No small change, it's a big change. (changes are made in several parameters)
If at the moment you are happy with this lights operation, me too.
This BCM coding is for Vento LED Headlights, in the same way like factory coding. (except Byte18)
We'll wait for your new BCM 8IT for LED headlights.
Well, just for curiosity ...
Try the following Hexadecimals and with the following order in the Byte18 of your current BCM 8IG for Bixenon headlights.
61
62
63
64
65
66
and tell us in which of them the SCLs start to work. (64?)
vento2013
Sorry was bit busy. So now replying.
Just now checked Hexadecimals and with the following order in the Byte 18, 61 to 66 result are
Byte 18 changed value to 61, 62, 63
DRL = OK
Low Beam = OK
High Beam = OK
Byte 18 changed value to 64
DRL = OK
Pass Light = Not OK (High beam+Low Beam)
Low Beam = OK
High Beam = OK
Static Cornering = Ok
Byte 18 changed value to 65, 66
DRL = OK
Low Beam = OK
High Beam = OK
now in Byte 18 value is 66
scan report
One more weird thing noticed with this coding
or
Reverse camera used to flicker a lot(attached image) I do not use reverse camera much, I prefer parking sensor with acoustic sound so I never bothered about camera. But with this new coding
3A904BBF48A10000013807006CCB96900080666F60CD39E1210000030020
camera is not flickering I am not sure how it is related to this. What I noticed just sharing it here.
DRL = OK
Low Beam = OK
High Beam = OK
DRL = OK
Low Beam = OK
High Beam = OK
DRL = OK
Low Beam = OK
High Beam = OK
scan report
Saturday,19,May,2018,19:13:01:39744
www.Ross-Tech.com
Mileage: 62340km-38736mi Repair Order: coding66
Coding: 01
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 62345 km
Date: 2016.01.30
Time: 23:27:35
Revision: V0000000
Coding: 3A904BBF48A10000013807006CCB96900080666F60CD39E1210000030020
Coding: 0728DD
Coding: 010000
Coding: 010000
Coding: 240000
Coding: 020000
Coding: 020000
Coding: 108002
Coding: 003036
Coding: 140A000000
Revision: B9082001
Coding: 002300
Serial number:
Coding: 0000
End-------------------------(Elapsed Time: 02:41)--------------------------
or
Wow! good report!
... it's what I supposed.
Many thanks.
As I told you, it was not a small change. The BCM Byte18 modifies the way it feeds the BCM pins for the lights. Also the diagnosis.
You must bear in mind that this 7E0... C BCM is parameterized for Bixenon headlights, while the headlights you have installed are LED.
We are preparing a good coding for your new 7E0 BCM for LED headlights and rest of devices.
Many thanks.
Logically.
vento2013
Hi, Ciclo Finally BCM for LED headlights arrived.
just now swapped BCM n result is...
DRL = OK
Pass Light(Flashing) = OK
Parking light = OK
Low Beam = OK
High Beam = OK
Fog Lights = OK
Static Cornering = Partially working(only Left side working)
VCDS scan report
DRL = OK
Parking light = OK
Low Beam = OK
High Beam = OK
Fog Lights = OK
VCDS scan report
Monday,04,June,2018,12:26:49:39744
www.Ross-Tech.com
Mileage: Repair Order: 04062018 8ITBCM
ASAM Dataset: EV_ECM1T6DI02103L906023NT 003012
ROD: N/A
No ASAM data for: "EV_ECM1T6DI02103L906023NT" (VW36 *)
ASAM Dataset: EV_Brake1AB9S0BOSCH 003017
ROD: N/A
No ASAM data for: "EV_Brake1AB9S0BOSCH" (VW25)
Coding: 01
ASAM Dataset: EV_LWSKLOVW52X 005001
ROD: N/A
No ASAM data for: "EV_LWSKLOVW52X" (VW25)
1 Fault Found:
1140738 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 62403 km
Date: 2016.02.17
Time: 00:38:22
Revision: V0000000
Revision: B9082001 Serial number: 4000 173170900
Shop #: WSC 12345 123 12345
Coding: 0728DD
Coding: 010000
Coding: 010000
Coding: 240000
Coding: 020000
Coding: 020000
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 224
Reset counter: 12
Mileage: 62403 km
Time Indication: 0
Date: 2016.02.17
Time: 00:39:37
00979 - Lamp for Low Beam; Right (M31)
Fault Priority: 3
Reset counter: 12
Mileage: 62403 km
Time Indication: 0
Date: 2016.02.17
Time: 00:39:37
Coding: 108002
Coding: 003036
ASAM Dataset: EV_AibraVW10BPAVW250 A01001
ROD: N/A
No ASAM data for: "EV_AibraVW10BPAVW250" (VW25)
Coding: 140A000000
ASAM Dataset: EV_Kobmi_UDS_VDD_RM09 A05729
ROD: N/A
No ASAM data for: "EV_Kobmi_UDS_VDD_RM09" (VW36 *)
Revision: B9082001
Coding: 102300
Serial number:
ASAM Dataset: EV_Mimo_UDS_VDD_RM09 A03710
ROD: N/A
No ASAM data for: "EV_Mimo_UDS_VDD_RM09" (VW36 *)
Coding: 0000
ASAM Dataset: EV_SteerAsissUDSNSK 005005
ROD: N/A
No ASAM data for: "EV_SteerAsissUDSNSK" (VW25)
I'm afraid the low beam errors will only go away if you have the correct BCM; coding it will not work.
I think the value ciclo wrote for byte 18 (HEX 66) is indeed the correct one for your configuration but you could try 60 and 73. But I don't think it will make a difference.
In this last autoscan the Byte18 is 60 HEX, change it to 66 HEX.vento2013 wrote: Mon Jun 04, 2018 8:27 am Hi, Ciclo Finally BCM for LED headlights arrived.
DRL = OK
Parking light = OK
Low Beam = OK
High Beam = OK
Fog Lights = OK
VCDS scan reportCode: Select all
Monday,04,June,2018,12:26:49:39744 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 17.1.3.0 Data version: 20170220 DS267.3 www.Ross-Tech.com VIN: WVWJ13601ET024078 License Plate: KA47M3663 Mileage: Repair Order: 04062018 8ITBCM -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 60 (7E0) Scan: 01 03 04 08 09 10 15 17 19 25 44 56 0B VIN: WVWJ13601ET024078 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 56-Radio -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CLNA) Labels: 03L-906-023-CAY.clb Part No SW: 03L 906 023 NT HW: 03L 907 425 B Component: 1,6l R4 CR td H33 9971 Revision: --H33--- Serial number: 00000000000000 Coding: 00110016032500080000 Shop #: WSC 00788 648 00255 ASAM Dataset: EV_ECM1T6DI02103L906023NT 003012 ROD: N/A VCID: 05064A5684BA6669DA-8050 No ASAM data for: "EV_ECM1T6DI02103L906023NT" (VW36 *) No fault code found. Readiness: 0000 1000 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: Redir Fail! Part No SW: 6R0 907 379 BF HW: 6R0 907 379 AQ Component: ABS9.0 front H01 0001 Serial number: -------------- Coding: 60DD2F63212504C40614F470845920020000 Shop #: WSC 57830 002 1048576 ASAM Dataset: EV_Brake1AB9S0BOSCH 003017 ROD: N/A VCID: 0302544E8A8E5859F4-8056 No ASAM data for: "EV_Brake1AB9S0BOSCH" (VW25) No fault code found. ------------------------------------------------------------------------------- Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb Part No SW: 6R0 959 654 HW: 6R0 959 654 Component: LENKW.SENSOR H07 0070 Serial number: 23101713470492 Coding: 01 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_LWSKLOVW52X 005001 ROD: N/A VCID: 7EF425BAE16C35B19B-802A No ASAM data for: "EV_LWSKLOVW52X" (VW25) 1 Fault Found: 1140738 - ROD - Unknown Error Code - 00 [009] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 12 Mileage: 62403 km Date: 2016.02.17 Time: 00:38:22 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb Part No SW: 6R0 907 044 L HW: 6R0 907 044 L Component: Climatronic H12 0612 Revision: V0000000 VCID: 3C70EFB2BFF0E7A1F5-8068 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 C HW: 7E0 937 090 C Component: BCM PQ25 Max4 H82 0752 Revision: B9082001 Serial number: 4000 173170900 Coding: 3A904BBF48A10000013807006CCB96900080606F60CD39E1210000030020 Shop #: WSC 12345 123 12345 VCID: 2B52DCEE4A9E70196C-807E Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB Component: RLS 230118 04 47 0106 Coding: 0728DD Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB Component: ------------- 006 5520 Serial number: 13202576130625091059 Coding: 010000 Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB Component: ------------- 006 5520 Serial number: 13102579130618031221 Coding: 010000 Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442 Component: E221__MFL-TAT H04 0019 Serial number: 2671409414901055AB1B Coding: 240000 Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L Component: ------------- 006 5520 Serial number: 13102580130620031450 Coding: 020000 Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L Component: ------------- 006 5520 Serial number: 13102581130620063454 Coding: 020000 2 Faults Found: 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 224 Reset counter: 12 Mileage: 62403 km Time Indication: 0 Date: 2016.02.17 Time: 00:39:37 00979 - Lamp for Low Beam; Right (M31) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 224 Reset counter: 12 Mileage: 62403 km Time Indication: 0 Date: 2016.02.17 Time: 00:39:37 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb Part No SW: 6R0 919 475 C HW: 7E0 919 475 Component: PARKHILFE 4K H11 0013 Revision: -------- Serial number: 47361317300143 Coding: 108002 Shop #: WSC 00793 648 00255 ASAM Dataset: EV_VW250ParkiAssis2 S01008 ROD: EV_VW250ParkiAssis2.rod VCID: 3E74E5BAA1ECF5B1DB-806A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 5K0-959-655.clb Part No SW: 6R0 959 655 J HW: 6R0 959 655 J Component: VW10AirbagU06 H10 0020 Revision: -------- Serial number: 003GW00M0RR+ Coding: 003036 Shop #: WSC 01383 785 00200 ASAM Dataset: EV_AibraVW10BPAVW250 A01001 ROD: N/A VCID: 499E8666E82242097E-801C No ASAM data for: "EV_AibraVW10BPAVW250" (VW25) No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 6RF 920 862 HW: 6RF 920 862 Component: KOMBI H01 0214 Serial number: 00000000000000 Coding: 140A000000 Shop #: WSC 13202 938 00000 ASAM Dataset: EV_Kobmi_UDS_VDD_RM09 A05729 ROD: N/A VCID: 091E4666A8A20209BE-805C No ASAM data for: "EV_Kobmi_UDS_VDD_RM09" (VW36 *) No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: None Part No SW: 7E0 909 901 HW: 7E0 937 090 C Component: GW-K-CAN TP20 H82 0752 Revision: B9082001 Coding: 102300 Shop #: WSC 12345 123 12345 VCID: 68D863E29BE89B0141-803C No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H01 0214 Serial number: Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Mimo_UDS_VDD_RM09 A03710 ROD: N/A VCID: 6ADC19EA8DE4A91157-803E No ASAM data for: "EV_Mimo_UDS_VDD_RM09" (VW36 *) No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V1.clb Part No SW: 6RF 909 144 K HW: 6RF 909 144 J Component: EPS_ECU H44 0401 Coding: 0000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SteerAsissUDSNSK 005005 ROD: N/A VCID: 54A0A7123F600FE11D-8000 No ASAM data for: "EV_SteerAsissUDSNSK" (VW25) No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: None Part No SW: 6RD 035 187 B HW: 6RD 035 187 B Component: Radio 534 5314 Revision: -------- Serial number: VWZZZ4H6267388 Coding: 16000440040005 Shop #: WSC 127395 840 08317 VCID: 46848D5AF13CAD7193-8012 No fault code found. End-------------------------(Elapsed Time: 02:41)--------------------------
Tell us the result.
vento2013
Tried 66 in byte 18ciclo wrote: Mon Jun 04, 2018 12:50 pm
Tell us the result.
DRL = OK
Parking light = OK
Low Beam = OK
High Beam = OK
Fog Lights = OK
But new issue, when high beam is on right low beam flickers once in a while.
So now in byte 18 value is 60
and I turned off SCL.
this is my present coding
Coding: 3A904BBF48A10000013807002CCB96900080604F60C939E1210000030020
except SCL everything else perfect
have two fault codes
Try 64 and 65 HEX in Byte18.
64
3A904BBF48A10000013807006CCB96900080646F60CD39E1210000030020
65
3A904BBF48A10000013807006CCB96900080656F60CD39E1210000030020
Apart:
Keep in mind that you still have a fault in the "new"
G85 steering angle you installed.
The basic setting can be made in the ABS unit or in Address 44: Steering Assist (J792) depends on the model and units installed.
Notice (warning):
I don't know how to do the basic setting at address 44, everything you do at address 44 is at your own risk/responsibility.
64
65
Apart:
Notice (warning):
vento2013 wrote: Mon Jun 04, 2018 7:33 pm Tried 66 in byte 18
DRL = OK
Parking light = OK
Low Beam = OK
High Beam = OK
Fog Lights = OK
have two fault codes![]()
vento2013
Hello Ciclo,
Sorry for very late reply, was stuck in some work.
Initially SCL was not working later everything stopped working. VCDS scan threw 2 faults Terminal 30 Left N Right 011-Open Circuit. So checked all wiring once again the culprit was loosely inserted ELECTRIC BRIDGE. Reinserted properly. now everything working perfectly.
DRL = OK
Parking light = OK
Low Beam = OK
High Beam = OK
Fog Lights = OK
Auto headlight = OK
Rain Sensing wiper = OK
04 Steering angle sensor still showing fault code, but SCL working perfectly. Tried doing Basic setting using ODIS, it shown no communication!!
Other than steering angle sensor
There are 2 Faults Found:
But Low beam working perfectly. Pls let me know, what might be the issue.
Below is the scan report.
DRL = OK
Parking light = OK
Low Beam = OK
High Beam = OK
Fog Lights = OK
Auto headlight = OK
www.Ross-Tech.com
ROD: N/A
ROD: N/A
Coding: 01
ROD: N/A
1 Fault Found:
- 00 [009]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 62403 km
Date: 2016.02.17
Time: 00:38:22
Revision: V0000000
Coding: 0728DD
Coding: 010000
Coding: 010000
Coding: 240000
Coding: 020000
Coding: 020000
2 Faults Found:
Fault Priority: 3
Reset counter: 12
Mileage: 62403 km
Time Indication: 0
Date: 2016.02.17
Time: 00:39:37
Fault Priority: 3
Reset counter: 12
Mileage: 62403 km
Time Indication: 0
Date: 2016.02.17
Time: 00:39:37
Coding: 108002
Coding: 003036
ROD: N/A
Coding: 140A000000
ROD: N/A
Revision: B9082001
Coding: 102300
Serial number:
ROD: N/A
Coding: 0000
ROD: N/A
