peter_dk25
Drives: Blue GT
Re: iichels Polo 6R 1.2TDI Rosa Line Bluemotion
Post by peter_dk25 »
Thanks iichel - More things to buy :D
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Hahahahaha. Always with good excellent introduction!
peter_dk25 wrote: Fri Jun 01, 2018 1:48 pm Thanks iichel - More things to buy :D
+1 :)
Visited a modern aquaduct, carrying a traintrack :)
benzinkopf
iichel wrote:Visited a modern aquaduct, carrying a traintrack :)
-image-
Did I just look at a polo with ACC Radar?
Reason: removed big ass image.
Yes, you certainly are. But the engine ECU is too stupid to understand how it works.
I was hoping to make my MFSW module work with the ACC radar but I'm afraid it isn't possible.
The engine software had no ACC interpretation.
It will only receive accelerate and decelerate signals coming from the BCM as given by the user via the stalks.
I'm still planning of making the city brake assist work, with the new ESP9.0i unit but I'm not sure whether I'll be 100% successful.
For now it looks nice, but if it will not succeed, I'll take it off again and have the normal continuous bottom grill.
benzinkopf
iichel wrote:Yes, you certainly are. But the engine ECU is too stupid to understand how it works.
Oh. Please don’t tell me it’s working now. If not I’m going to be poor coz surely I will go along that route! With that tech. I can sustain this polo for another 15yrs . [emoji23]
Don't worry, if it were to work, I would have informed you more extensively ;-)
Glued on the Polo BlueGT or Polo 6C Bluemotion side spoilers thanks to user Blairzxy
Left: 6R6805945B
Right: 6R6805946B
More pictures --> https://imgur.com/a/BADvQK6
iichel wrote: Sun Jun 03, 2018 7:01 pm Visited a modern aquaduct, carrying a traintrack :)
https://i.imgur.com/ixvAzj3.jpg
8)
ciclo wrote: Tue Jun 05, 2018 7:33 am
8)
8)
Did I already tell you guys about my power steering failure? Probably not.
My power steering pump started to drink a bit too much water and shorted out, causing it to malfunction.
I removed the pump and was eventually able to repair it, removing the corrosion from the PCB by ultrasonic cleaning.
--> http://forums.ross-tech.com/showthread. ... -them-arms
At the same time, I was a bit fed up with the poor reliability record of these pumps in general, having heard about a lot of failures in the 6R lately.
I guess due to the location of these pumps, they are quite sensitive to water ingress and high current electricity is bad with water.
So, I decided to retrofit the electromechanical column as a backup plan.
I bought:
- 6C1423510AE steering column
- 6R1423961 coupling
- 6C1857017B dashboard carrier
- 6C1721913 crash support above pedals
- Mountings and screws for the column
Mounting the new dash carrier is a bit of a pain, but since I already did it once before while retrofitting the climatronic, I wasn't too afraid...
Take out the center console, steering wheel, glove box, airbags, steering wheel and dash first. Have a break.
Then take out the wipers, plenum chamber and take out the carrier.
Finally, take the chance to tidy up some wiring below the dash (this is always the part that makes me very happy), place the new column and do the wiring.
I took the OEM installation, with the ground point next to the airbag module and routed a 10mm2 wire to the engine compartment fuse box.
Then I simply took a contra-plug to the original power steering plug and took +15 and CAN powertrain from there.
Remove the G85 in the slip ring, code power steering column to 000300 and course, put everything back in.
It's quite a long job, I took me well over a day overall but then it's perfectly aligned and tidy.
After that, I went for a small drive, without active power steering but it did have an emergency programme.
I did some straight driving and some corners. Don't exceed 25 km/h.
Finally, some lock-to-lock cycles, stop, connect your VCDS and look at the measurement values of 44 Power Steering to see the steering angle. Get it as close to 0.0 degrees as you can.
Exit 44 , go to 03 ABS, login 40168, basic settings, and do the calibration of the steering angle sender.
Autoscan, remove all DTCs and make a new scan. It should all be OK.
At the end, this was the way to do it and I'm happy to report, it works perfectly.
Tuesday,05,June,2018,13:14:52:11868
VCDS Version: 18.2.1.2  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.1
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN: WVWZZZ6RZBYiichel   License Plate:
Mileage: yes  Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 44 47 55 56 57
          61 69 6C 77
VIN: WVWZZZ6RZBYiichel   Mileage: yes
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9980
   Revision: 12005001    Serial number:
   Coding: 00114036033401080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TDI03103P906021B 001043
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 270B06DDAF6FF1FF10D-8072
Readiness: 0 0 0 0 1
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Serial number: --------------
   Coding: 21DD4885432500C5841A126EC25500521505
   Shop #: WSC 00049 770 00138
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F7B4E7D27DF89BFF8D-805A
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 372BD69D7FCF617F80D-8062
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3829D5A172516E07897-806C
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 092150183
   Coding: 3CB02FF828CB2400933906E2FFEB9FD0808260EF608D78D0B0A050030820
   VCID: 688945E162713E87D97-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 140415 03  37  0059
   Coding: 0380DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 7 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29160000978830096203
   Coding: A80000
   Subsystem 8 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  002 0803
   Serial number: KU0-KU008.06.0910897
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
1 Fault Found:
00975 - Heated Rear Window (Z1)
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 221
                    Mileage: km
                    Time Indication: 0
                    Date: 2018.06.05
                    Time: 13:15:56
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231422402620
   Coding: 318001
   VCID: 3B23CAAD43E7451F645-806E
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F691C3DEC97EF3-801E
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140E01
   VCID: 3333E28D6BB78D5FBC5-8066
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 042200
   Revision: AA001001
   Coding: 040400E200000100000000
   VCID: 2E05F3F98095A0B7D3B-807A
   Component: IMMO          H04 0709
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8D3FE97CFD0C97CF3-803E
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F3BEEFD879FA9BFD8D-807A
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
   VCID: 2B03FAEDB307D59FF45-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Coding: 00070002010000A10001
   VCID: 3635DB99784598779BB-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AD    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3124
   Serial number: CF3F0205
   Coding: 000300
   ASAM Dataset: EV_SteerAssisUDSTRW 014026
   ROD: EV_SteerAssisUDSTRW_014.rod
   VCID: 79AF10A5095BB70F369-802C
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
   VCID: 280905E1A271FE87197-807C
   Revision: --------    Serial number: --------------
   Coding: 0192000001000000
   Shop #: WSC 00788 648 00255
   VCID: 77AB169D3F4FA17F40D-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
Address 57: TV Tuner        Labels: None
   Part No SW: 3C0 919 148 B    HW: 3C0 919 148
   Component: R78 DTV-JP          0250
   Revision: R0H14000    Serial number: 80100800042102
   Coding: 0000816
   Shop #: WSC 01324 020 00200
   VCID: 280905E1AEF1FE87197-807C
   Subsystem 1 - Part No: 4F0 919 805
   Component: R204 TVKLeser       0010
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0733
   Coding: 030F1A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F3BEEFD871FA9BFD8D-807A
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65974CD5996323EFE21-8030
1 Fault Found:
03006 - Back-up Camera System not calibrated
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 220
                    Time Indication: 0
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105254406
   Coding: 020100000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 25170CD5D563E3EF221-8070
End----------(Elapsed Time: 02:20, VBatt start/end: 14.1V/14.4V)-----------
taking the cute little Polo for a midweek in the mountains.. :-)
Splendid! Image
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
:D
cool!!!!
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post by Jay-Jay »
iichel wrote:Did I already tell you guys about my power steering failure? Probably not.
My power steering pump started to drink a bit too much water and shorted out, causing it to malfunction. [...] So, I decided to retrofit the electromechanical column.
At the end, [...]I'm happy to report, it works perfectly.
I guess you have the only Polo 6R with electro-mechanic steering in the world! Congratulations! :)
Do you feel it's better/more precise than the electro-hydraulic one?
I remember I saw on ETKA that the steering rods for electro-mechanical steering are different than those for electro-hydraulic one.
