- Drives: Blue GT
Re: iichels Polo 6R 1.2TDI Rosa Line Bluemotion
Thanks iichel - More things to buy
- Drives: 1.2TSI 105HP DSG7
Hahahahaha. Always with good excellent introduction!
Visited a modern aquaduct, carrying a traintrack
iichel wrote:Visited a modern aquaduct, carrying a traintrack
-image-
Did I just look at a polo with ACC Radar?
Reason: removed big ass image.
Yes, you certainly are. But the engine ECU is too stupid to understand how it works.
I was hoping to make my MFSW module work with the ACC radar but I'm afraid it isn't possible.
The engine software had no ACC interpretation.
It will only receive accelerate and decelerate signals coming from the BCM as given by the user via the stalks.
I'm still planning of making the city brake assist work, with the new ESP9.0i unit but I'm not sure whether I'll be 100% successful.
For now it looks nice, but if it will not succeed, I'll take it off again and have the normal continuous bottom grill.
Oh. Please don’t tell me it’s working now. If not I’m going to be poor coz surely I will go along that route! With that tech. I can sustain this polo for another 15yrs . [emoji23]iichel wrote:Yes, you certainly are. But the engine ECU is too stupid to understand how it works.
Don't worry, if it were to work, I would have informed you more extensively
Glued on the Polo BlueGT or Polo 6C Bluemotion side spoilers thanks to user Blairzxy
Left: 6R6805945B
Right: 6R6805946B
More pictures --> https://imgur.com/a/BADvQK6
Left: 6R6805945B
Right: 6R6805946B
iichel wrote: ↑Sun Jun 03, 2018 7:01 pm Visited a modern aquaduct, carrying a traintrack
https://i.imgur.com/ixvAzj3.jpg
ciclo wrote: ↑Tue Jun 05, 2018 7:33 amiichel wrote: ↑Sun Jun 03, 2018 7:01 pm Visited a modern aquaduct, carrying a traintrack
Did I already tell you guys about my power steering failure? Probably not.
My power steering pump started to drink a bit too much water and shorted out, causing it to malfunction.
I removed the pump and was eventually able to repair it, removing the corrosion from the PCB by ultrasonic cleaning.
--> http://forums.ross-tech.com/showthread. ... -them-arms
At the same time, I was a bit fed up with the poor reliability record of these pumps in general, having heard about a lot of failures in the 6R lately.
I guess due to the location of these pumps, they are quite sensitive to water ingress and high current electricity is bad with water.
So, I decided to retrofit the electromechanical column as a backup plan.
I bought:
- 6C1423510AE steering column
- 6R1423961 coupling
- 6C1857017B dashboard carrier
- 6C1721913 crash support above pedals
- Mountings and screws for the column
Mounting the new dash carrier is a bit of a pain, but since I already did it once before while retrofitting the climatronic, I wasn't too afraid...
Take out the center console, steering wheel, glove box, airbags, steering wheel and dash first. Have a break.
Then take out the wipers, plenum chamber and take out the carrier.
Finally, take the chance to tidy up some wiring below the dash (this is always the part that makes me very happy), place the new column and do the wiring.
I took the OEM installation, with the ground point next to the airbag module and routed a 10mm2 wire to the engine compartment fuse box.
Then I simply took a contra-plug to the original power steering plug and took +15 and CAN powertrain from there.
Remove the G85 in the slip ring, code power steering column to 000300 and course, put everything back in.
It's quite a long job, I took me well over a day overall but then it's perfectly aligned and tidy.
After that, I went for a small drive, without active power steering but it did have an emergency programme.
I did some straight driving and some corners. Don't exceed 25 km/h.
Finally, some lock-to-lock cycles, stop, connect your VCDS and look at the measurement values of 44 Power Steering to see the steering angle. Get it as close to 0.0 degrees as you can.
Exit 44 , go to 03 ABS, login 40168, basic settings, and do the calibration of the steering angle sender.
Autoscan, remove all DTCs and make a new scan. It should all be OK.
At the end, this was the way to do it and I'm happy to report, it works perfectly.
Tuesday,05,June,2018,13:14:52:11868
VCDS Version: 18.2.1.2 HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.1
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN: WVWZZZ6RZBYiichel License Plate:
Mileage: yes Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 44 47 55 56 57
61 69 6C 77
VIN: WVWZZZ6RZBYiichel Mileage: yes
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 907 425
Component: R3 1.2l TDI H06 9980
Revision: 12005001 Serial number:
Coding: 00114036033401080000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ECM12TDI03103P906021B 001043
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 270B06DDAF6FF1FF10D-8072
Readiness: 0 0 0 0 1
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD4885432500C5841A126EC25500521505
Shop #: WSC 00049 770 00138
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0F7B4E7D27DF89BFF8D-805A
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0346244897
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSY_PQ35GP.rod
VCID: 372BD69D7FCF617F80D-8062
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3829D5A172516E07897-806C
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001 Serial number: 0771 092150183
Coding: 3CB02FF828CB2400933906E2FFEB9FD0808260EF608D78D0B0A050030820
VCID: 688945E162713E87D97-803C
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 140415 03 37 0059
Coding: 0380DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Serial number: KU0KU011111300010103
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU007111300016463
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H05 1501
Subsystem 7 - Part No SW: 6C0 959 442 C HW: 6C0 959 442 C
Component: E221__MFL-DC1 H04 0103
Serial number: 29160000978830096203
Coding: A80000
Subsystem 8 - Part No SW: 6R0 959 811 B HW: 6R0 959 811 B
Component: J388__TSG_HL 002 0803
Serial number: KU0-KU008.06.0910897
Coding: 08BC32
Subsystem 9 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Serial number: KU0-KU004.06.0913330
Coding: 08BC32
1 Fault Found:
00975 - Heated Rear Window (Z1)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 221
Mileage: km
Time Indication: 0
Date: 2018.06.05
Time: 13:15:56
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231422402620
Coding: 318001
VCID: 3B23CAAD43E7451F645-806E
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX0142TCE
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F691C3DEC97EF3-801E
Serial number: 3575HRB40650BI7U48C8
Serial number: 3585HRB405J09RECEOUJ
Serial number: 3515RRB405T0BTBEF9G7
Serial number: 3525RRB405R0BTBEKPFQ
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H04 0709
Coding: 140E01
VCID: 3333E28D6BB78D5FBC5-8066
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0733
Revision: B9080001
Coding: 042200
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 040400E200000100000000
VCID: 2E05F3F98095A0B7D3B-807A
Component: IMMO H04 0709
Coding: 000007
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8D3FE97CFD0C97CF3-803E
Address 2B: Steer. Col. Lock (J764) Labels:| 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 11000256123005
Coding: 4100000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F3BEEFD879FA9BFD8D-807A
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7666620365
Coding: 010100
VCID: 2B03FAEDB307D59FF45-807E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 E HW: 1T0 035 686 H
Component: RNS-MID H26 6276
Revision: AB001001 Serial number: VWZ6Z7P1950254
Coding: 00070002010000A10001
VCID: 3635DB99784598779BB-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V15 8515
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AD HW: 6R1 909 144 E
Component: EPS_TRW_ALow 312 3124
Serial number: CF3F0205
Coding: 000300
ASAM Dataset: EV_SteerAssisUDSTRW 014026
ROD: EV_SteerAssisUDSTRW_014.rod
VCID: 79AF10A5095BB70F369-802C
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0000052
ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
ROD: EV_AudioVerst10KanalSTT4.rod
VCID: 280905E1A271FE87197-807C
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0192000001000000
Shop #: WSC 00788 648 00255
VCID: 77AB169D3F4FA17F40D-8022
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 57: TV Tuner Labels: None
Part No SW: 3C0 919 148 B HW: 3C0 919 148
Component: R78 DTV-JP 0250
Revision: R0H14000 Serial number: 80100800042102
Coding: 0000816
Shop #: WSC 01324 020 00200
VCID: 280905E1AEF1FE87197-807C
Subsystem 1 - Part No: 4F0 919 805
Component: R204 TVKLeser 0010
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0733
Coding: 030F1A5A
Subsystem 1 - Part No SW: 6C0 915 181 HW: 6C0 915 181
Component: J367-BDM H08 0223
Serial number: 61083A44504351928092
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0080
Revision: 3A002002 Serial number: 00000116932377
Coding: 0100000100000000
VCID: 2F3BEEFD871FA9BFD8D-807A
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7E0 907 441 HW: 7E0 907 441
Component: J772__Rearview 0040
Revision: 00H08000 Serial number: 525PA8-J060533
Coding: 0030115
VCID: 65974CD5996323EFE21-8030
1 Fault Found:
03006 - Back-up Camera System not calibrated
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Time Indication: 0
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 025 0983
Revision: -------- Serial number: 35502105254406
Coding: 020100000100010000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi.rod
VCID: 25170CD5D563E3EF221-8070
End----------(Elapsed Time: 02:20, VBatt start/end: 14.1V/14.4V)-----------
taking the cute little Polo for a midweek in the mountains..
- Jay-Jay
- Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
I guess you have the only Polo 6R with electro-mechanic steering in the world! Congratulations!iichel wrote:Did I already tell you guys about my power steering failure? Probably not.
My power steering pump started to drink a bit too much water and shorted out, causing it to malfunction. [...] So, I decided to retrofit the electromechanical column.
At the end, [...]I'm happy to report, it works perfectly.
Do you feel it's better/more precise than the electro-hydraulic one?
I remember I saw on ETKA that the steering rods for electro-mechanical steering are different than those for electro-hydraulic one.
