UPGRADING BCM 6R
Re: UPGRADING BCM 6R
Ok, thanks for the warning.benzinkopf wrote: Sat Jun 16, 2018 8:00 pm“ein......Kabel”
so it should be single wire.
btw. i think i bought the same AFS wiring from the same seller last time. As the wiring is made for LHD. i have to take out the terminal pins from the 26pin afs connector and switch the position from LHD to RHD, for one reason:
1) the length of wires provided is of coz opposite for Left and Right.
Yes, but the item from tuning fanatics shop will get you the exact same wiring.ciclo wrote: Sat Jun 16, 2018 8:03 pm Thanks!
So the right one is .... https://www.ebay.com/itm/VW-Polo-V-6R-X ... xylpNTRTVy
benzinkopf
- Drives: 1.2TSI 105HP DSG7
it may not bring any harm with the LHD or RHD as our bixenon leveling is just up & down, so it will still work. correct me if i’m wrong: but as there is adaptation settings to manually offset the motor position of each headlight, i believe it is necessary to correct that so the AFS module knows exactly the left and right headlight.
I don't think it makes a difference, in ELSA there are no different wirings for left and right hand drive with respect to the AFS wiring.benzinkopf wrote: Sat Jun 16, 2018 8:15 pm it may not bring any harm with the LHD or RHD as our bixenon leveling is just up & down, so it will still work. correct me if i’m wrong: but as there is adaptation settings to manually offset the motor position of each headlight, i believe it is necessary to correct that so the AFS module knows exactly the left and right headlight.
I'd connect the headlights for a RHD polo the same way as a LHD.
govindsharma
- Drives: polo 1.2 petrol HighLine
Thank you all of you sir for your kind help finally i have to buy these two wires.
1.VW Polo 6R ALWR Nachrüstung Kabelbaum Adapter cable harness. https://www.ebay.in/itm/170982304945?Vi ... SI:IN:1123
2.VW Polo V 6R Xenon Bi-Xenon Adapter Kabelbaum Kabel cable wiring https://www.ebay.in/itm/171296258148?Vi ... SI:IN:1123
Sir I have to take out 4 wire from BCM, 2 of cornering lights that i have to joint together and insert to SB54 a fuse and wire from 3rd connector of auto headlight red switch to SB54b fuse. and 2 cable of fog light drls which i had recently connected. ok.
And insert new 6 wires from T10 to T14 wiring to BCM only and leave the BCM intact.No wire from AFS to BCM.
All the wires of AFS is as under that i had understand via diagram that you had provided please check.
T26/2 - can high T32/28
T26/3 - can low T32/29
T26/7 - T4 AW/4 (Rear Axle)
T26/10 - T4 AW/2 (Rear Axle)
T26/11 - T4 AW/1 (Rear Axle)
T26/15 - T14B/1 (MX2 Right Headlight T14 Connector)
T26/20 - T14B/4 (MX2 Right Headlight T14 Connector)
T26/21 - T14B/2 (MX2 Right Headlight T14 Connector)
T26/22 - T14B/3 (MX2 Right Headlight T14 Connector)
T26/16 - T14A/3 (MX1 Left Headlight T14 Connector)
T26/17 - T14A/1 (MX1 Left Headlight T14 Connector)
T26/18 - T14A/4 (MX1 Left Headlight T14 Connector)
T26/19 - T14A/2 (MX1 Left Headlight T14 Connector)
T26/23 - SB13 (POWER)
T26/24 - earth.(EARTH)
Above wiring is ok for AFS and OEM BiXenon Headlights.
Yes, everything is fine.
A present for you: https://uk-polos.net/viewtopic.php?f=56 ... 50#p536420
https://i32.servimg.com/u/f32/18/94/39/39/dsc_0011.jpg
govindsharma
Sir I had found this kind of grommet under my car but it is tottaly sealed and one wire or pipe goes through it.ciclo wrote:Yes, everything is fine.
The cable you show I think belongs to the ABS sensor/rpm y and obviously the grommet is not the same as this,
Searching in ETKA:
If I select the Polo made in Europe this is the result,
If I select the Polo made in India this is the result,
Therefore, you must find another place to route the wires for AFS sensor.
I don't know if anyone in India did this work in its Polo 6R.
I think iichel used another route for the AFS sensor wires in his 6R.
Searching in ETKA:
Indeed I did, I used the grommet below the rear left seat.
Thanks for confirmation.
govindsharma
iichel Sir can you please show image of that place from where you routed AFS wire.
Thank you.
Thank you.
sure thing mate, here you go --> https://imgur.com/a/e6M59o2
govindsharma
Thank you I had seen this kind of hole is there in my car and that is covered by black groomet.
Yep the same here. I just punched through it and sealed it against water.
