Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
Re: Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
The electrical installation (wires) for your fog lights and SCLs should be as follows:
1. Supply for the BCM (according to the installation guide for your fuse box).
From the output of fuse 55 (SB55b) to slot T73b/11 BCM white connector.
2. Operation.
Signal. From slot T10/3 RED connector to slot T73a/7 BCM black connector.
Output. From BCM to the fog lights.
- From T73b/9 to T2/1 Left fog light connector. T2/2 to ground.
- From T73b/10 to T2/1 Right fog light connector. T2/2 to ground.
Any other type of installation is incorrect with 6R LED headlights installed.
According to your comments, this electrical installation was already working correctly with the 8IG BCM.
Test with 68 and 70 HEX in BCM Byte18.
Speculation:
These hexadecimals feed the blinker system differently, maybe they are necessary for the SCLs to work correctly with turn signal and/or the G85 steering sensor.
2. Operation.
Speculation:
- Drives: TSI
hello vento2013
Can you please send me a toturial of coding LED lights for a polo 6C?
Thanks mate
Thanks mate
hello mates
wich channels i have to change in adaption10 to get Led lights working and without fog lights?
Hi!
Thanks for interesting thread!
I have an issue with my Polo 6C that I guess you might have an answer to?
I have LED headlights fitted stock, but no rain/light sensors.
I tried coding CH/LH with VCDS, but unfortunately it doesn't really behave like i wish it would...
I coded the manual setting, the stalk version. When I pull the stalk after turning ignition off it turns rear light and number plates light on
according to the settings for CH/LH. I added the menu in the BAP so I can set timer for CH/LH.
The issue I have is that my LED low beam lights up for like 0,5 seconds with the DRL and then turns of, but the rear light stays on until the set timer is finished, 5, 10, 15 sek etc.
My question is, HOW do I code the low beams to stay on during the programmed CH/LH timer??
Thanks in advance!
Best regards
Christian
Thanks in advance!
Best regards
Christian
- Drives: POLO 6R DSG 2013
Hello everyone,
I have a Polo 6R 2013 with a BCM 6R0937087M.
Last week i tried to replace my BCM with 7H0937089 F HH50 SW 0251 in order to install OEM Bi Xenon headlight.
Everything works except the interior lights and key fob can not adapt.
I understand that some modifications are required at the installation.
Can anyone help me?
Can anyone help me?
Hi, welcome.
Apart from the new Bixenon headlight harnesses (T10-T14), it is necessary to adapt the 7H0 BCM Max with new wires and isolate some original wires. (fusebox, BCM, light switch, dimmer)
For remote controls:
http://wiki.ross-tech.com/wiki/index.ph ... l_Matching
1st Remote control ... entering 0
2nd Remote control ... entering 0
and so on... 3rd, etc..
Hello ciclo,
I replaced BCM with new wire after your wiring diagram. I isolate some original wire.
I manage to adapt remote control.
I made the new harness for the light button with the auto function and i replace the light switch.
I coded BCM.
Until here, everything work fine, no erors, except the light sensor.
The car is for the moment with halogen headlight.
Can you help me with corect coding to activate the light sensor?
So, this may actual coding:
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 F HW: 7H0 937 089
Component: BCM T5GP Li4 H50 0251
Revision: BS050001 Serial number: 0465 300111639
Coding: 64B0291808A1000001280EC06CEB0FD0F0C860FF60A60001200000000000
Shop #: WSC 64564 324 38760
VCID: 3979F2A0B0BEE287A0-806C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 110113 05 54 0403
Coding: 06302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1621
Serial number: KU0KU019111200016909
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1621
Serial number: KU0KU028111200012325
Coding: 18BC30
Subsystem 4 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-MD9 H04 0103
Serial number: 29190001675950069296
Coding: A50000
I coded BCM.
Coding: 06302D
Coding: 18BC30
Coding: 18BC30
Coding: A50000
RLS coding is OK.
New BCM coding
64B029B808A1000001280EC06CEB0FD0F0C860FF60A62001200000000000
Report the result.
New BCM coding
Report the result.
Hello ciclo,
Surprise...
After you send me your coding everything is ok.
I will check CH LH tonight.
Thank you man,
Surprise...
Thank you man,
Hello again ciclo,
Light sensor work perfect.
In this evening i tested CH LH.
It seems the function CH not work.
The headlights turn off when the engine is stopped.
LH work perfect.
Any ideea???
LH work perfect.
Any ideea???
- Drives: polo 1.2 petrol HighLine
Hello
For CH function when you turn off engine , before opening door flash high beam once and then open door.Lights will glow for 15 secs.Try this.
Thank you.
Thank you.
+1govindsharma wrote: ↑Fri Feb 21, 2020 3:00 am Hello
Thank you.
Small clarification, with the door already open the CH function also works.CeciliuTabara wrote: ↑Thu Feb 20, 2020 7:55 pm Hello again ciclo,
LH work perfect.
Any ideea???
http://www.uk-polos.net/viewtopic.php?f ... 05#p474349
http://www.uk-polos.net/viewtopic.php?f ... 95#p477710
http://www.uk-polos.net/viewtopic.php?f ... 65#p491539
http://www.uk-polos.net/viewtopic.php?f ... 65#p491577
http://www.uk-polos.net/viewtopic.php?f ... 30#p504328
http://www.uk-polos.net/viewtopic.php?f ... 82#p517482
http://www.uk-polos.net/viewtopic.php?f ... 15#p517604
http://www.uk-polos.net/viewtopic.php?f ... 20#p518296
http://www.uk-polos.net/viewtopic.php?f ... 20#p518219
http://www.uk-polos.net/viewtopic.php?f ... 80#p520980
viewtopic.php?f=56&t=58703&start=4020#p529332
Hello,
So...
CH work very nice after your indication.
Option BCM in adaptation channel are very interesting.
Thank you very much guys,
So...
