Franciswat's Polo 6R 1.6 Bifuel
- Franciswat
- Drives: 6R 1.6 Bifuel
Re: My polo 6r bifuel
Thank you guys a lot!
- Franciswat
Hi, i finally replaced both filters. Bigger One a bit dirt, the smaller looks new! I Will post a picture later.
I recently had an issue with an ignition coil and replaced It (my car has 75k kms and i have Never replaced them). I am curious to ask if You would replaced Only One or all of them together even if others still work.
Francesco
Francesco
It is not uncommon that if one ignition coil fails, the other ones will follow soon.
But if you feel like taking a chance, you could start with replacing one.
- Franciswat
Yes, i heard about that. My question is if mixing new and old ignition coils could make motor run less efficently or maybe even damage It in long time since One coil has to compensate the others wich work at 60-70% of Power for example.
no unless you have misfires, the coils should be fine
- Franciswat
Sorry for stupid question guys: where the filter air (below passenger seat) should point: gears or outside?
My arrow points outside but online i saw videos where it points gear..
No info about it on elsawin (thats crazy)..
UPDATE
If may help anyone in future arrow points gear.
UPDATE
- Franciswat
Hello guys, I have tried to upgrade my BCM to 7E0 but I encurred some big problems.
Remote controllers looked pair corretcly because I am able to open and close the car.
After I switch on the car I am no longer able to switch It off (motor still running and instrument cluster is on even with key removed).
Even If I insert the key and turn it to switch on the instrument cluster only (not the motor) when I remove the key the instrument cluster stays on and BOTH REMOTE CONTROLLERS does no longer works.
I have to reattach the battery and only then BOTH remote controllers start to work again.
Please can anyone help me? Thanks
VCDS scan
I apologise the video is take on the side.
VCDS scan
Tuesday,28,August,2018,13:58:54:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY54xxxx License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56 0B
VIN: WVWZZZ6RZCY543xxx Mileage: 76710km-47665miles
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 210224E3217100B5842524E484D700401300
Shop #: WSC 00788 648 00255
VCID: 00085B4297984341E9-8054
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 397EF6A6B0C2D289EE-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 060161479
Coding: 3CB02BBF08E10600923808006D2B0CD100C0412F60860000200000000000
Shop #: WSC 02737 534 00190
VCID: 68D863E29BE89B0141-803C
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU004011200011991
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU005011200017885
Coding: 08BC30
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0339054
Coding: 820000
Subsystem 4 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU010011200012406
Coding: 08BC32
Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU009011200013136
Coding: 08BC32
3 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 126
Mileage: 76711 km
Time Indication: 0
Date: 2013.01.18
Time: 00:20:22
03156 - Sensor for Anti-Theft System (G578)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 126
Mileage: 76711 km
Time Indication: 0
Date: 2013.01.18
Time: 00:20:22
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 126
Mileage: 76711 km
Time Indication: 0
Date: 2013.01.18
Time: 00:20:18
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 56D 919 475
Component: PARKHILFE 8K H02 0106
Revision: -------- Serial number: 20251528901029
Coding: 100001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K.rod
VCID: 3A7CE9AABDC4D991E7-806E
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX011W0JJ
Coding: 003232
VCID: 4A9CB96AED24491177-801E
Serial number: 3575HRB4059124B2F99H
Serial number: 3585HRB4061131GQCOUS
Serial number: 3515RRB405P0VC0I5P0W
Serial number: 3525RRB40510VC0IA9B9
Part No SW: 6R0 920 871 A HW: 6R0 920 871 A
Component: KOMBI H03 0505
Coding: 140A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 3460C7929FA02FE13D-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002200
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADC19EA8DE4A91157-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6AC8FEEA860C3940-807A
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 6RD 035 187 HW: 6RD 035 187
Component: Radio 517 5124
Revision: RB101000 Serial number: VWZZZ4Q5034465
Coding: 00000400040005
VCID: 0400575287805F61CD-8050
End-------------------------(Elapsed Time: 02:43)--------------------------
3CB02BBF08E10000003808006D2B0CD100C0412F60860000200000010000
I suppose this will solve some errors in your BCM
- LED license plate lights (if fitted) for byte 27--> 00 becomes 01
- Anti theft system errors (if not fitted), 06 and 92 become 00 for byte 6 and 8.
I'm not sure if it fixes your errors. It would be interesting to see what errors exist in your engine control module.
Did you deactive factory mode of the BCM? (channel 99 of the adaptations set from 1 to 0)
- Franciswat
Thanks for reply iichel
I changed byte 27 for plate light to 0; anti theft gave error due to the fact I forgot to re-place the fuse wich I removed before installation.
Yes factory mode was disabled.
Car has strange behaviour, please look at the video.
The problem is that you must explain with precision each and every one of the wires that you have installed. Also all the new equipment (types of headlights, other lights, etc), and I mean how you have installed them, I do not mean how you see them in the diagram or installation guide.
It is absolutely clear that the problem is in the wires installation.
It would have been easier to help you with this problem (it's not big) if I had manufactured your wiring looms. I deeply regret not having had time to manufacture them when you requested them.
- Franciswat
Hi Ciclo, I really appreciate the fact that you take care of my issues and I will never thank you enough for the time you dedicate me.
I understand you did not have time to prepare wirings for me so do not worry about it because your support is just as precious.
After reading some discussions here on forum and making some tests I could solve majors problems; you can please tell me If I did it correctly or not.
I read in a thread by federicodrdpro (about installing 7E0 BCM) that you said him to isolate T17/6 and T17/7; I first tried to isolate them both and then I found It was enought to isolate T17/6 only to make engine and instrument cluster switch on/off correctly so i reconnected T17/7 and kept T17/6 isolated.
At this point I had to solve problem that some buttoms lights were still off with headlights on; I read in the same topic above about to enable byte 27 bit 1 and after doing that all buttoms lighted up correctly.
As I said I do not know If that was the best way to solve the problems so I ask you if I did it correctly.
An autoscan still show an error about alarm horn and some times (totally casually) broken light bulb icon light on even If all lights works correctly (I use oem alogen lght bulbs).
Thank you
Thank you
Monday,03,September,2018,00:25:27:39744
www.Ross-Tech.com
VIN: WVWZZZ6RZCY54xxxx Mileage: 77040km-47870miles
Address 01: Engine
Cannot be reached
Revision: --------
Revision: 0003SH02
Coding: 3CB02BBF08E10600923808006D2B0CD100C0412F60860000200000020000
Coding: 18BC30
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Coding: 820000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Coding: 08BC32
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 128
Mileage: 77040 km
Time Indication: 0
Date: 2013.01.24
Time: 09:54:59
Coding: 100001
Coding: 003232
Coding: 140A01
Revision: B9080001
Coding: 002200
Serial number:
Coding: 11250
Shop #: WSC 00788
4 Faults Found:
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 128
Mileage: 77040 km
Time Indication: 0
Date: 2013.01.24
Time: 09:54:57
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 128
Mileage: 77040 km
Time Indication: 0
Date: 2013.01.24
Time: 09:54:57
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 128
Mileage: 77040 km
Time Indication: 0
Date: 2013.01.24
Time: 09:54:57
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 128
Mileage: 77040 km
Time Indication: 0
Date: 2013.01.24
Time: 09:54:57
End-------------------------(Elapsed Time: 03:15)--------------------------
Hi FranciswatFranciswat wrote: ↑Mon Sep 03, 2018 12:14 am
I read in a thread by federicodrdpro (about installing 7E0 BCM) that you said him to isolate T17/6 and T17/7; I first tried to isolate them both and then I found It was enought to isolate T17/6 only to make engine and instrument cluster switch on/off correctly so i reconnected T17/7 and kept T17/16 isolated.
This is absolutely wrong.
First thing, you can't take another 6R as an example because both 6R probably don't have the same electrical configuration. (i have not checked the thread of federicodrdpro)
In any case:
T17/6, T17/7 must be isolated.
T17/16 must be connected to T73b/7.
I need you upload the images again from your T17 light switch connector to see the colors of the original wires.
(it is no longer possible to view the images where you uploaded them)
https://imgur.com/mDdcvwH
>>>> https://uk-polos.net/viewtopic.php?f=56 ... 89#p525089
Easier impossible ...
- Franciswat
Thank you ciclo for explaining me that.
Sorry in previous post I wrote T17/16 instead of T17/6.
I post below the pictures of light switch connector, please do not look automatic light box (I definitelly removed It prior to install bcm) and t17/3 was disconnected because to disable headlight in 0 position.
That's federico's thread to witch I am refering to.
https://uk-polos.net/viewtopic.php?f=56&t=70787
These are the other pictures of my fusebox and dimmer of my first original post (if needed).
https://s25.postimg.cc/oc32j0n7z/DSC_0032.jpg
https://s25.postimg.cc/gxdqqn1cf/DSC_0036.jpg
https://s25.postimg.cc/xvcrchaq7/DSC_0038.jpg
https://s25.postimg.cc/x3a3da6j3/DSC_0014.jpg
About faulty light warning I noticed It appear only when I insert reverse gear.
This may help to solve the problem. Thank you
- Franciswat
Update
I have insulated both T17/6 and T17/7 from light switch and car has been working good since 4th september.
I could not figure out light bulb error so I iichel helped me to disable rear bulb light check; looking forward to find out the problem (maybe need to code something about lamp check?! -> lamp is good and contacts had been cleaned! ).
Anyway more works are coming..
PS please ciclo let me know what you think about wirings and rear bulb error when you can, thanks!
Hello Franciswhat.
I apologize you for my delay in answer in your thread.
Currently I don't know exactly what you want me to comment on. (temporarily I have my mind lost in other worlds/things )
Please tell me what's the current status of your 6R (Current Autoscan).
