New member: Jasper's Red Polo 6R from Belgium
Hi everyone!
I'm already more than 3 years a member of this community, but with only 3 posts you can say I was not a very active one...
After reading some very interesting things here (mostly technical stuff), I've made the decision to try to be more active here. First things first, so let me introduce myself.
My name is Jasper, 23 years old and living in Belgium. Maybe some Dutch, Belgian or Swiss members over here will recognise me from the Dutch Polo community.
My car is a red Polo 6R from 2010. It has 3 doors, Highline version, came with the optional 17" Boavista wheels and equipped with the very powerful (it's not) 1.4i 16v 86bhp petrol engine.
I've already done quite a lot of modifications to it:
- painted the brake calipers red
- built-in oem mdi connection
- oem alu pedals
- oem rubber floor mats
- oem exhaust tip
- oem gti front grille
- plasti dipped the chrome line in the lower grille to red
- oem helix subwoofer
- tinted windows
- auto light switch (unfortunately oem was not possible so china clone)
- oem led license plate lights
- lowered on AP coilover suspension
- 18" OZ Superleggera wheels
and last but not least I have an original Ross-Tech VCDS cable in my possession.
Latest mod is currently happening: building in oem bluetooth module. Started with it yesterday but it's not working yet. Have some errors in vcds about left and right treble speaker open circuit? And my phone cannot find the module. Maybe because I have an RCD310 without multi-function steering wheel and no MFD+? If someone can help me with this... would be very nice!
BUT to end my introduction, one thing more has to be done. Here are some photos of my car. Hope you like them!
- oem alu pedals
- oem exhaust tip
- tinted windows
Re: New member: Jasper's Red Polo 6R from Belgium
Hi Jasper! Nice to see you here
Maybe it would be good to post an autoscan from VCDS to see if we can help you out.
Have been working on the module again this evening. Everything works fine now! The phone was able to connect and vcds auto-scan gave no faults anymore!
Fatherless One
- Drives: GTI 6C
It looks great Jasper
Have you considered fitting a GTI rear bumper and dual exhaust tips, that would make the rear stand out.
Thanks @Fatherless One
Yes I did, but when i make the decision to do this, I would like to do the whole r-line package including front bumper, sideskirts and spoiler.
And that's a bit pricey...
To be 100% sure the faults were gone, I did an auto-scan again today but unfortunately they were back
(autoscan-print below)
So first of all, the incorrectly coded module in the CAN gateway...which one is guilty?
Probably fault will be caused by the radio, media player or telephone module.
I have the individual codings here:
56-Radio: 0500040002
77-Telephone: 0810000000010110
2E-Media Player 3: 010100
The only remark I can do about this it that the radio won't accept 0500040202 coding. This is to indicate "telephone or telephone preparation installed". As said it declines with error 31: request out of range.
Next, what about the open circuit faults? The AUX one is because of the MDI I think because the MDI "overwrites" my AUX input. The AUX input will only work when I pull out my USB stick. Don't know if there's a solution for this or if it's either one or the other from factory.
About the treble speakers: I don't know what's wrong. I did some output tests and they both work fine. Or has it something to do with my subwoofer (oem Helix one)?
Auto-scan print:
Auto-scan print:
2E-Media Player 3 -- Status: Not registered 0001
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BH HW: 03C 906 024 BH
Component: CGGB MM4HV G 8327
Revision: --H09--- Serial number:
Coding: 0000071
Shop #: WSC 03247 202 104841
VCID: 65C03A52AF78C16CB7-515E
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Coding: 210228E3217400B5842714E384D100401300
Shop #: WSC 02069 000 00000
VCID: 4D90E2F210C8192C9F-8018
Address 08: Auto HVAC Labels: 6R0-907-044.clb
Part No SW: 6R0 907 044 B HW: 6R0 907 044 B
Component: Climatronic H08 Climatronic H08 02040204 VCID: 326A910E6D3666D4E2-8066
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 012100753
Coding: 3CB029BF08A10000012006003C2B1ED000C0410F60060000200000000000
Shop #: WSC 12345 160 20947
VCID: 3E72B53EA96EB2B416-806A
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 150110 05 54 0402
Coding: 0005F3
Subsystem 2 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB Component: J386__TSG_FT 006 0912
Serial number: KU0-KU007.01.1016901
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB Component: J387__TSG_BT 006 0912
Serial number: KU0-KU010.12.0915961
Coding: 08BC30
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 HW: 6R0 919 475
Component: PARKHILFE 4K H07 0008
Revision: -------- Serial number: 71320935601747
Coding: 100001
Shop #: WSC 124697 483 00190
ASAM Dataset: EV_VW250ParkiAssis2 S01006
ROD: EV_VW250ParkiAssis2.rod
VCID: 7BF47C2AF2FC679C71-802E
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag00L H09 0018
Revision: -------- Serial number: 003DW00BCK9E
Coding: 00304C
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001 ROD: EV_AirbaVW10BPAVW250.rod
VCID: 428AC1CED596D65472-8016
Serial number: 3572SRB40000A89501A1
Serial number: 3582SRB40000A8BCC93O
Serial number: 3516GRB4033CA5L92KVH
Serial number: 3526GRB4029CA5L8T3EF
Part No SW: 6R0 920 860 D HW: 6R0 920 860 D
Component: KOMBI H03 0205
Coding: 140A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
VCID: 3560AA12945871ECC7-8060
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb Part No SW: 6N0 909 901 HW: 6R0 937 087 D
Component: GW-K-CAN TP20 0207
Coding: 002000
VCID: 70EE5B06A3BA14C4D4-8024
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 90944 km
Time Indication: 0
Date: 2012.12.11
Time: 19:09:56
Component: IMMO H03 0205
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADA496E8D66EE149A-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7663885169
Coding: 010100
VCID: 2A5A896E45E62E145A-807E
Address 44: Steering Assist Labels: 6Q0-423-156.clb Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10150
Shop #: WSC 00788
VCID: 2E52857EED0E423486-807A
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2K7023823 Coding: 0500040002
VCID: 6BD44C6A8A9CF71CE1-803E
3 Faults Found:
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 129
Mileage: 90944 km
Time Indication: 0
Date: 2012.12.11
Time: 19:10:28
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 129
Mileage: 90944 km
Time Indication: 0
Date: 2012.12.11
Time: 19:10:28
03138 - Input AUX IN
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 129
Mileage: 90944 km
Time Indication: 0
Date: 2012.12.11
Time: 19:10:33
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007662541084
Coding: 0810000000010110
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 26427D5E59FE0A747E-8072
End-------------------------(Elapsed Time: 02:55)--------------------------
I'm not sure about the error, but it would make sense to register the MDI:
19 Can Gateway -> installation list -> tick 2E media player -> save
If you have an AUX input, uncheck it in the coding of the RCD310 since the aux input goes to the Media player.
01 for byte 0 of the MDI seems OK for that.
Thanks @iichel! Will try that tomorrow!
So just a quick update about my fault codes.
I disabled the AUX input and the fault code disappeared (obviously). The AUX input still does its job because its routed via the MDI like iichel described.
The one about the incorrectly coded module in the CAN gateway section was indeed the MDI (media player). Just checked it off in the installation list, so thanks again iichel.
The 2 open circuits faults kept me busy for a while but luckily I solved it. I knew the speakers weren't broken because the output tests of all speakers were positive. After a lot of searching on the internet, I discovered they show up just because of the new cable which is in between the original quadlock connector and radio. To solve the open circuit fault you just need to go to 56 Radio -> longcoding -> byte 04 -> set to 01 Treble speaker monitoring deactivated. First it was 02 in my case (front treble speaker monitoring) thus I got fault codes of the front speakers only. Just to check to be 100% sure, I set the value to 04 (F+R) to see if the rear speakers gave the open circuit fault as well. And yes, they did. Problem solved
cheba
- Drives: Polo R WRC 2014
So can you have both and AUX input and MDI? I'm wondering because I am switching from a head unit with built in AUX (RNS 315) to an RNS 510. I thought that the AUX input (in cars with AUX input in the lower center console) and the used the same part of the quadlock connector on the back of the head unit as the MDI, so you could install either AUX or MDI, but not both. But if I understand you correctly, the AUX input is wired to the MDI, which in turn is connected to the head unit?
As far as the Quadlock goes, i'm pretty sure the MDI will connect to the wires that the AUX will connect to as well. So you can have both, but you'll need to re-route the Aux to the MDI.
Then it will work fine.
cheba
I found the a schematic of the connector on the MDI unit and is has AUX L/R/ground pins. However I also found out that there are also AUX pins in the quadlock connector (in multi-pin connector 4) so it should be possible to connect the AUX straight to the head unit: https://www.my-gti.com/529/volkswagen-r ... ssignmentsiichel wrote: Tue Sep 18, 2018 5:30 pm As far as the Quadlock goes, i'm pretty sure the MDI will connect to the wires that the AUX will connect to as well. So you can have both, but you'll need to re-route the Aux to the MDI.
Last week, I finally bought an RCD 510 head unit so my Bluetooth module could do its job properly (RCD 310 doesn't support telephone connection of course). With a lot of expectations where I could control my bluetooth music with the radio buttons instead of using my phone all the time and seeing track information on screen, I changed my head units and turned on everything. Unfortunately, still no track information on screen only BT-AUDIO and not able to skip or select tracks... Does anyone know why? I thought an RCD 510 unit was always able to display these IF you're using a bluetooth module which supports this (A2DP and 9W7 if I'm correct). The bluetooth module which I bought in July has part number 5K0 035 730 D and I did a lot of research about this back then. It should have these 2 protocols. Anyone knows what's the problem?
Hi Jasper, sorry to hear it still doesn't work. Do you have any access to VCDS? Can you post an autoscan? Do you have a compatible telephone? (I'm assuming your phone is fine, just making sure)
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56 77
VIN: WVWZZZ6RZAY173210 Mileage: 96790km-60142miles
VCDS
77-Telephone -- Status: Sporadic communication error 1000
Coding: 0000071
VCID: 65C03A52AF78C16246-5140
PartNoSW:6R0907379R HW:6R0907379R
Revision: --------
VCID: 4D90E2F210C819226E-8018
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Fault Priority: 0
Fault Frequency: 3
Reset counter: 214
Mileage: 96593 km
Time Indication: 0
Date: 2013.05.30
Time: 16:45:55
Hex Value: 0x0000
Hex Value: 0x8000
Hex Value: 0x1203
Hex Value: 0x2BB3
Hex Value: 0x497F
Hex Value: 0x7F7F
Hex Value: 0x8000
Hex Value: 0x0000
Revision: V0000000
VCID: 326A910E6D3666DA13-8066
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 3
Reset counter: 225
Mileage: 92177 km
Time Indication: 0
Date: 2013.02.02
Time: 18:24:25
01273 - Fresh Air Blower (V2)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 94135 km
Time Indication: 0
Date: 2013.03.18
Time: 16:30:23
PartNoSW:6R0937087D HW:6R0937087D
Coding: 3CB029BF08A10000012006003C2B16D000C0410F60060000200000000000
VCID: 3E72B53EA96EB2BAE7-FFFE
Coding: 0005F3
Coding: 08BC30
Coding: 08BC30
Coding: 100001
VCID: 7BF47C2AF2FC679280-802E
PartNoSW:6R0959655C HW:6R0959655C
Coding: 00304C
VCID: 428AC1CED596D65A83-8016
Page 5
PartNoSW:6R0920860D HW:6R0920860D
Coding: 140A00
VCID: 3560AA12945871E236-8060
Coding: 002000
VCID: 70EE5B06A3BA14CA25-8024
1 Fault Found:
01303 - Telephone Transceiver (R36)
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 221
Mileage: 96694 km
Time Indication: 0
Date: 2013.06.05
Time: 20:43:56
Serial number:
VCID: 6ADA496E8D66EE1A6B-803E
PartNoSW:5N0035342F HW:5N0035342F
Coding: 010100
VCID: 2A5A896E45E62E1AAB-807E
Coding: 10150
Shop #: WSC 00788
VCID: 2E52857EED0E423A77-807A
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 036 0130
Revision: 00000001 Serial number: VWZ1Z3I4227281
Coding: 0501000001
Shop #: WSC 00028 028 00001
VCID: 65C03A526C78C16246-8030
4 Faults Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 221
Mileage: 96694 km
Time Indication: 0
Date: 2013.06.05
Time: 20:43:56
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 27
Reset counter: 198
Mileage: 176392 km
Time Indication: 0
Date: 2013.11.08
Time: 09:10:29
00821 - Antenna 2 for Radio (R93)
Fault Priority: 5
Fault Frequency: 1
Reset counter: 198
Mileage: 140558 km
Time Indication: 0
Date: 2014.02.14
Time: 21:03:20
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
PartNoSW:5K0035730D HW:5K0035730D
ROD: UHVNA.rod
VCID: 26427D5E59FE0A7A8F-8072
Also my telephone book does some strange things. Just telling because maybe it has some relation to the music idk... My contacts in my phone are set like it should be. First and last name in their respective fields etc. I already did a telephone book update in the radio settings but it still looks like this:
The contacts name and number are in the same line separated by blocks and DVLM & Brennan Heart is a song on my phone. I don't know what it is doing there. I didn't set it as ringtone and it shows up in every phone contact?? Also unable to call from phone book.
But let us first figure out the music.
