Polo 6R TDi EGR Issues - VCDS Log Available.
Discuss Engine, Gearbox and Exhaust
matt-t
Drives: Polo 1.2 TDi
Post by matt-t »
Hi All,
I am experiencing an issue with the other half's polo TDI.
I beleive there to be a fault with the EGR valve as it is showing similar symptons to when it failed 6000miles ago.
Rough idle, Poor MPG, DPF regen is more frequent and noisy engine.
There is currently no EML light on but the car feels crap! I do have .csv logs from VCDS if anyone is able to interpret them.
Thanks in advance.
Re: Polo 6R TDi EGR Issues - VCDS Log Available.
Well let's have a look at the log.
matt-t
Post by matt-t »
iichel wrote: Mon Jul 30, 2018 10:13 am Well let's have a look at the log.
I will need to upload them when i get home, works machine doesn't like it for some reason.
I have logged the following,
Air Mass Actual Value
EGR Specified Value
EGR Solenoid Value
Exhaust Mass Flow of EGR
OBD EGR Position.
Is there anything else to add to the log?
Yes, a VCDS autoscan please.
matt-t
Post by matt-t »
Please find attached my log, this is all i have at the moment, quite happy to graph it or change the data if needed (VCDS Newbie)
Marker	TIME	Loc. IDE00021	TIME	Loc. IDE00025	TIME	Loc. IDE00085	TIME	Loc. IDE00347	TIME	Loc. IDE00473-ENG101849	TIME	Loc. IDE00581	TIME	Loc. IDE01259-ENG101849	TIME	Loc. IDE03383	TIME	Loc. IDE04257	TIME	Loc. ENG107874-ENG98842
	STAMP	Engine speed	STAMP	Coolant temperature	STAMP	Normed load value	STAMP	Air mass: actual value:	STAMP	EGR Vacuum Regulator Solen.val.: activation-PWM rate	STAMP	EGR specified value	STAMP	EGR Solen.val.: actual value-PWM rate	STAMP	Exhaust mass flow of EGR	STAMP	High pressure EGR actuator: activation	STAMP	OBD EGR position control-Position
		 /min		 °C		 %		 g/s		 %		 %		 %		 g/s		 %		 %
	0.14	1296	0.27	93	0.37	92.2	0.51	9.43	0.62	27.1	0.8	22.4	0.9	21.2	1.02	9.68	1.13	10	0.03	19.2
	1.37	1268	1.53	93	1.63	60.8	1.77	8.78	1.88	40	2.03	35.3	2.13	34.9	2.28	6.03	2.39	12	1.27	15.3
	2.62	885	2.76	93	2.87	23.5	3.03	5.28	3.13	38	3.28	38	3.38	38	3.53	5.46	3.63	14	2.51	35.3
	3.89	879	4.03	93	4.12	23.5	4.26	8.25	4.37	0	4.53	5.1	4.63	4.3	4.78	11.12	4.88	18	3.78	38
	5.13	1192	5.3	93	5.42	67.5	5.53	12.68	5.62	15.7	5.76	14.5	5.87	15.3	6.03	13	6.13	22	5.02	4.7
	6.37	1680	6.51	93	6.62	96.1	6.78	14.9	6.89	34.9	7.02	36.1	7.14	36.5	7.27	16.25	7.37	22	6.28	22.4
	7.64	1969	7.77	93	7.87	0	8.01	9.84	8.12	52.5	8.3	47.8	8.4	33.3	8.53	9.09	8.63	10	7.52	47.1
	8.88	1344	9.03	93	9.14	99.2	9.27	15.06	9.37	8.6	9.51	9.8	9.62	11	9.77	16.4	9.89	22	8.78	14.1
	10.12	1673	10.27	93	10.37	99.6	10.52	17.31	10.63	27.5	10.78	28.6	10.87	28.6	11.02	19.28	11.12	18	10.03	19.2
	11.38	1985	11.52	93	11.63	0	11.78	10.71	11.89	56.5	12.03	55.3	12.14	55.7	12.27	9.12	12.38	8	11.27	43.9
	12.64	1165	12.79	93	12.9	76.5	13.02	5.21	13.14	37.3	13.29	36.9	13.4	36.9	13.51	6.9	13.62	10	12.53	54.9
	13.87	1209	14.02	93	14.12	85.1	14.28	7.25	14.38	33.3	14.53	34.5	14.63	37.6	14.78	7.9	14.88	20	13.77	32.9
	15.13	1245	15.28	93	15.38	47.1	15.52	6.59	15.64	53.7	15.78	54.1	15.89	54.5	16.03	5.81	16.12	12	15.03	45.9
	16.37	1202	16.53	93	16.63	0.4	16.78	6.21	16.88	55.3	17.02	55.7	17.12	58.4	17.27	5.43	17.38	0	16.27	52.5
	17.62	1204	17.77	93	17.87	69	18.04	5.78	18.15	33.3	18.27	30.6	18.37	25.9	18.51	7.5	18.62	10	17.53	56.5
	18.88	1217	19.02	93	19.13	92.5	19.28	8.81	19.38	27.1	19.53	27.8	19.63	26.7	19.77	9.31	19.89	14	18.77	25.1
	20.13	1269	20.28	93	20.38	90.6	20.53	9.25	20.63	32.5	20.77	32.9	20.87	32.9	21.02	9.37	21.14	18	20.02	27.8
	21.39	1328	21.53	93	21.63	89	21.78	8.81	21.89	36.9	22.03	36.9	22.12	37.3	22.26	9.12	22.37	20	21.28	34.5
	22.63	1369	22.77	93	22.88	74.9	23.03	7.56	23.13	46.7	23.28	46.7	23.38	47.1	23.52	8.09	23.62	16	22.52	44.3
	23.87	1385	24.03	93	24.13	79.6	24.27	7.25	24.38	46.7	24.52	46.7	24.63	50.2	24.79	7.9	24.88	8	23.76	47.1
	25.12	1385	25.27	93	25.37	0	25.54	7.31	25.63	54.9	25.77	54.9	25.88	54.9	26.02	6.03	26.12	18	25.02	51.8
	26.38	1284	26.52	93	26.62	0	26.77	6.87	26.87	59.2	27.02	59.6	27.13	59.6	27.27	5.56	27.37	12	26.28	56.5
	27.62	1085	27.77	93	27.88	0	28.03	5.84	28.12	55.7	28.26	46.3	28.37	46.3	28.53	4.59	28.63	6	27.51	59.6
	28.88	879	29.02	93	29.12	25.9	29.27	5	29.38	44.3	29.53	44.7	29.62	44.3	29.77	5.12	29.87	10	28.77	46.3
	30.13	875	30.28	94	30.37	24.3	30.51	5.12	30.62	44.3	30.78	43.9	30.88	43.9	31.03	5.18	31.13	10	30.02	44.3
	31.37	864	31.52	94	31.64	25.9	31.78	5.25	31.88	0	32.03	5.5	32.13	9.4	32.28	12.87	32.38	12	31.27	43.9
	32.62	1396	32.76	94	32.87	78.8	33.02	8.68	33.13	39.6	33.28	40.4	33.37	40	33.51	8.4	33.62	8	32.53	26.7
	33.88	1226	34.03	94	34.13	80	34.27	10.65	34.37	9.8	34.55	17.3	34.65	18	34.77	11.96	34.87	16	33.77	31.4
	35.12	1656	35.27	94	35.38	98.8	35.53	14.65	35.62	32.2	35.76	39.2	35.87	43.1	36.02	15.12	36.13	20	35.01	25.1
	36.38	2004	36.52	94	36.62	0	36.78	9.71	36.88	54.5	37.03	56.1	37.12	58	37.26	8.31	37.37	8	36.28	45.9
	37.63	1197	37.79	94	37.9	85.5	38.02	6.93	38.12	35.7	38.27	31.8	38.38	31.8	38.53	8.09	38.63	14	37.52	51.8
	38.87	1365	39.03	94	39.13	99.6	39.27	10.59	39.38	25.9	39.52	26.3	39.64	25.9	39.78	11.4	39.88	20	38.77	29.4
	40.12	1546	40.26	94	40.37	99.2	40.53	12.62	40.64	26.3	40.78	25.1	40.87	23.9	41.01	13.46	41.12	6	40.03	27.5
	41.39	1761	41.52	94	41.62	97.3	41.76	24.4	41.87	5.1	42.03	5.9	42.13	7.5	42.28	29.03	42.37	16	41.27	8.6
	42.62	2150	42.78	94	42.88	74.9	43.02	22.5	43.12	53.7	43.27	33.7	43.37	34.5	43.52	24.65	43.64	22	42.51	16.5
	43.88	1643	44.02	94	44.12	83.1	44.28	21.46	44.39	0	44.52	0	44.62	0	44.76	17.34	44.87	-14	43.77	9.8
	45.13	1381	45.28	94	45.37	99.2	45.51	19.21	45.62	0	45.77	0	45.89	0	46.03	22.43	46.12	2	45.03	0
	46.37	1520	46.53	94	46.63	76.5	46.78	20.06	46.88	21.2	47.02	21.6	47.12	21.2	47.27	19.53	47.39	20	46.26	2.7
	47.62	1647	47.76	94	47.87	94.9	48.03	18.65	48.13	22.4	48.28	23.1	48.39	23.1	48.52	19.5	48.64	22	47.52	22
	48.89	1743	49.03	94	49.12	58.8	49.26	22.59	49.37	33.7	49.52	0.8	49.63	6.7	49.78	21.53	49.88	20	48.78	27.5
	50.12	1780	50.27	94	50.38	48.6	50.53	12.96	50.62	47.8	50.76	54.9	50.87	56.9	51.04	11.75	51.15	14	50.01	25.1
	51.37	1772	51.51	94	51.62	71.8	51.77	10.03	51.88	55.7	52.03	54.9	52.12	55.7	52.27	10.62	52.37	18	51.27	56.5
	52.63	1763	52.77	94	52.88	44.3	53.02	8.18	53.13	60	53.28	63.1	53.38	62.4	53.52	7.93	53.62	8	52.52	56.5
	53.87	1687	54.02	94	54.13	0	54.28	8.03	54.37	62.7	54.52	62.4	54.62	62.7	54.78	7.15	54.88	14	53.76	63.1
	55.12	1583	55.26	95	55.37	0	55.52	8.06	55.64	63.9	55.77	0.8	55.87	0.8	56.02	13.5	56.12	-14	55.03	62.7
	56.39	1408	56.53	95	56.62	0	56.76	13.46	56.87	0	57.03	0	57.13	0	57.27	12.34	57.37	-14	56.28	0
	57.62	1089	57.77	95	57.88	14.5	58.02	7.4	58.13	30.2	58.28	33.7	58.38	36.1	58.53	6.31	58.63	16	57.51	0
	58.87	884	59.01	95	59.12	7.1	59.27	5.43	59.38	43.9	59.53	43.9	59.64	47.8	59.78	5.31	59.88	2	58.77	36.5
	60.13	1616	60.27	95	60.38	99.6	60.52	12.28	60.62	6.7	60.77	2.4	60.88	2.7	61.03	16.25	61.12	12	60.03	54.5
	61.37	1690	61.52	95	61.63	98.8	61.78	22.78	61.87	7.5	62.01	9.8	62.12	10.2	62.27	24.43	62.38	24	61.27	3.5
	62.62	2048	62.76	95	62.87	80.8	63.03	20.75	63.13	47.5	63.27	50.2	63.37	51.8	63.51	13.4	63.62	8	62.53	19.2
	63.88	1481	64.03	95	64.12	99.2	64.26	18.06	64.37	0	64.52	1.6	64.63	0	64.78	16.78	64.88	-14	63.77	50.6
	65.12	1373	65.27	95	65.38	99.6	65.54	18.93	65.65	0	65.76	0	65.87	0	66.02	22.12	66.13	-14	65.02	0
	66.37	1519	66.51	95	66.62	86.7	66.77	22.15	66.88	18	67.02	19.2	67.12	19.2	67.26	21.09	67.37	16	66.27	1.6
	67.65	1652	67.77	95	67.87	94.5	68.01	20.09	68.12	22	68.27	22.7	68.38	22.7	68.53	21.15	68.62	18	67.55	19.6
	68.87	1763	69.03	95	69.13	95.3	69.27	20.21	69.38	29	69.52	32.5	69.62	34.1	69.78	23.5	69.88	16	68.77	23.9
	70.12	1838	70.26	95	70.37	52.9	70.53	19.21	70.63	36.1	70.78	39.2	70.87	42	71.01	16.09	71.12	8	70.03	29
	71.38	1864	71.53	95	71.63	91.8	71.78	13	71.88	38	72.04	36.9	72.15	37.3	72.27	14.46	72.37	14	71.27	45.5
	72.62	1902	72.77	95	72.88	42.7	73.02	11.46	73.12	47.1	73.26	51	73.37	51	73.53	10.5	73.63	12	72.51	36.9
	73.87	1381	74.01	95	74.12	98	74.27	14.81	74.39	0.8	74.53	0.8	74.62	1.6	74.77	14.34	74.87	-8	73.77	48.6
	75.13	1250	75.27	95	75.37	98.8	75.53	15.59	75.63	0	75.78	0	75.88	0	76.03	16.9	76.13	-14	75.03	1.6
	76.38	1276	76.53	96	76.63	72.2	76.78	16.43	76.87	9.8	77.01	13.3	77.12	16.1	77.29	14.5	77.4	12	76.28	0
	77.62	1298	77.76	96	77.87	93.3	78.03	13.37	78.13	17.3	78.28	19.6	78.37	21.6	78.52	13.25	78.62	22	77.52	16.1
	78.88	1318	79.04	96	79.13	89.4	79.27	10.34	79.37	25.9	79.52	25.9	79.63	25.9	79.78	10.93	79.87	16	78.77	27.8
	80.12	1326	80.27	96	80.38	94.1	80.52	10.56	80.62	25.9	80.77	26.3	80.87	25.9	81.03	11	81.13	14	80.01	25.5
	81.37	1332	81.52	96	81.62	94.5	81.78	10.68	81.88	27.8	82.03	29.8	82.12	33.7	82.26	10.31	82.37	18	81.28	26.3
	82.63	1337	82.78	96	82.87	84.3	83.02	8.65	83.12	36.9	83.27	36.1	83.39	36.9	83.53	9.15	83.63	12	82.52	37.3
	83.88	1334	84.03	96	84.13	89.8	84.29	8.43	84.4	35.3	84.54	35.3	84.63	35.7	84.78	9.06	84.88	8	83.77	36.5
	85.13	1337	85.27	96	85.37	89.8	85.52	8.53	85.63	34.9	85.77	34.9	85.88	34.9	86.03	9	86.13	14	85.03	34.9
	86.4	1334	86.52	96	86.62	89.8	86.77	8.59	86.87	34.9	87.03	34.9	87.13	35.3	87.28	8.96	87.38	14	86.29	35.3
	87.62	1338	87.77	96	87.88	89.4	88.03	8.65	88.12	34.5	88.26	35.3	88.37	35.3	88.53	9.03	88.63	14	87.52	34.9
	88.87	1340	89	96	89.07	83.1	89.18	8.56	89.29	42	89.4	43.9	89.53	44.3	89.63	8.59	89.77	16	88.77	35.3
	90.03	1338	90.13	96	90.27	17.6	90.38	6.78	90.53	51.4	90.64	52.5	90.78	52.9	90.88	6.43	91.03	18	89.87	45.9
	91.26	1303	91.37	96	91.53	0	91.63	6.9	91.77	55.7	91.88	56.1	92.03	56.5	92.13	6.09	92.28	18	91.12	52.9
	92.52	1256	92.62	97	92.76	0	92.87	10.28	93.02	0	93.13	3.5	93.27	8.2	93.38	11.56	93.52	16	92.38	57.6
	93.77	1234	93.88	97	94.02	60	94.12	8.75	94.26	18.4	94.37	17.6	94.53	18	94.64	9.71	94.77	12	93.62	25.1
	95.02	1233	95.12	97	95.28	99.6	95.39	10.68	95.52	23.5	95.62	23.9	95.76	23.9	95.87	10.43	96.03	14	94.88	17.3
	96.27	1256	96.38	97	96.52	78.4	96.62	9.28	96.78	44.3	96.89	47.1	97.02	48.6	97.12	8.03	97.26	22	96.13	27.1
	97.52	1241	97.64	97	97.79	0	97.89	6.4	98.01	55.7	98.12	55.7	98.27	56.5	98.38	6.03	98.52	20	97.37	53.7
	98.76	1140	98.87	97	99.03	0	99.13	6.09	99.27	58.4	99.38	58.4	99.51	58.4	99.62	5.12	99.77	0	98.64	57.3
	100.02	883	100.12	97	100.26	24.7	100.37	5.09	100.52	45.9	100.64	45.1	100.77	45.5	100.88	5	101.02	20	99.89	49.4
	101.27	918	101.39	97	101.52	24.3	101.62	5.12	101.76	42.7	101.87	42.7	102.02	42.4	102.14	5.21	102.28	12	101.12	47.5
	102.53	887	102.64	97	102.76	39.2	102.87	6.87	103.02	23.5	103.12	31.4	103.26	38.8	103.37	10.68	103.53	4	102.38	42.7
	103.78	1483	103.88	97	104.03	98.4	104.13	16.37	104.28	15.3	104.39	20	104.52	21.2	104.63	15.81	104.77	18	103.64	8.2
	105.02	1818	105.13	97	105.28	99.2	105.37	16.87	105.51	32.9	105.62	34.1	105.78	40	105.89	18.34	106.02	18	104.87	25.5
	106.26	1915	106.37	96	106.53	0	106.64	9.84	106.77	46.3	106.87	22.7	106.98	14.5	107.05	13.09	107.17	-26	106.12	54.1
	107.38	1346	107.53	96	107.62	98	107.76	16.4	107.87	0	108.03	0	108.13	0	108.28	19.21	108.37	-14	107.28	0
	108.62	1552	108.77	96	108.89	93.7	109.03	24.03	109.12	14.1	109.26	18.8	109.37	18.4	109.52	22.75	109.63	22	108.51	0
	109.87	1779	110.01	96	110.12	91.4	110.27	19.34	110.38	33.3	110.53	33.7	110.62	33.7	110.76	23.18	110.87	14	109.77	23.1
	111.13	1545	111.27	96	111.38	0	111.52	14.9	111.63	9	111.78	16.5	111.88	20	112.02	10.43	112.12	22	111.02	34.1
	112.37	1291	112.53	96	112.64	75.3	112.77	9.12	112.87	36.1	113.01	35.3	113.12	35.3	113.28	9	113.38	16	112.26	27.8
	113.63	1325	113.77	96	113.88	63.1	114.03	7.75	114.13	47.8	114.28	47.1	114.37	47.8	114.52	8.03	114.62	8	113.53	38
	114.89	1340	115.03	96	115.12	73.3	115.26	6.84	115.37	46.3	115.53	45.5	115.64	45.9	115.78	7.46	115.88	6	114.78	46.3
	116.13	1350	116.28	96	116.38	78.4	116.52	6.78	116.63	43.1	116.77	42.7	116.88	43.1	117.05	7.34	117.15	20	116.03	44.7
	117.37	1335	117.51	96	117.62	5.1	117.77	6.87	117.88	47.8	118.03	48.2	118.14	48.6	118.26	6.34	118.37	14	117.27	44.7
	118.64	1313	118.77	96	118.87	0	119.01	7.06	119.12	51.4	119.28	52.2	119.38	52.5	119.52	6.12	119.62	16	118.52	49.4
	119.87	1279	120.03	96	120.14	25.9	120.27	6.12	120.38	49	120.52	45.5	120.62	41.6	120.75	5.62	120.85	10	119.76	53.3
	121.07	1266	121.18	96	121.29	88.6	121.38	7.5	121.53	28.2	121.63	28.2	121.79	27.8	121.9	8.59	122.02	18	121.01	35.3
	122.27	1277	122.39	96	122.53	64.7	122.62	7.84	122.76	44.7	122.87	45.9	123.03	47.5	123.14	7.87	123.27	20	122.12	28.2
	123.53	1280	123.63	96	123.78	11	123.88	6.75	124.02	51.8	124.13	53.7	124.27	53.3	124.38	5.84	124.53	20	123.37	48.6
	124.78	1258	124.87	96	125.02	0	125.12	6.62	125.28	56.5	125.38	56.9	125.52	56.5	125.63	5.84	125.77	16	124.63	54.5
	126.02	1223	126.13	96	126.27	0	126.38	10.68	126.52	0	126.62	0	126.77	2	126.89	11.18	127.02	22	125.87	58
	127.28	1186	127.38	96	127.53	0	127.63	7.59	127.78	45.5	127.87	48.2	128.01	50.2	128.12	6.62	128.27	20	127.13	25.9
	128.53	1144	128.62	96	128.76	0	128.87	6	129.03	54.5	129.13	54.9	129.27	54.5	129.37	5.31	129.51	20	128.38	52.9
	129.77	1059	129.88	96	130.03	0	130.12	5.84	130.26	56.5	130.37	56.5	130.52	56.5	130.63	4.71	130.77	6	129.62	55.3
	131.01	852	131.12	96	131.27	26.7	131.39	5.15	131.53	43.5	131.64	43.5	131.77	43.5	131.87	5.15	132.04	22	130.87	45.1
	132.27	1000	132.37	96	132.52	0	132.63	5.9	132.78	60.4	132.88	61.2	133.02	61.2	133.13	5.28	133.28	18	132.15	49
	133.53	1039	133.64	96	133.77	17.6	133.87	4.87	134.01	44.3	134.12	29	134.27	23.5	134.39	6.37	134.52	10	133.38	62.4
	134.77	1054	134.89	95	135.02	97.3	135.14	10.43	135.28	0	135.38	0	135.52	0	135.63	11.4	135.78	-14	134.63	8.2
	136.02	1152	136.13	95	136.28	87.5	136.39	12.37	136.53	2	136.64	5.9	136.78	7.1	136.87	13.06	137.01	14	135.89	0
	137.27	1258	137.39	95	137.52	97.3	137.63	12.21	137.77	23.1	137.87	23.5	138.02	23.9	138.13	11.75	138.28	18	137.12	18
	138.51	1354	138.62	95	138.78	96.5	138.89	11.28	139.03	32.2	139.13	32.5	139.27	33.3	139.38	11.65	139.53	18	138.37	26.7
	139.77	1453	139.88	95	140.03	99.2	140.13	11.09	140.28	31.8	140.38	30.2	140.53	30.6	140.63	11.96	140.78	12	139.63	34.5
	141.04	1551	141.15	95	141.27	99.2	141.38	12.37	141.53	28.2	141.63	28.6	141.78	28.2	141.88	13.75	142.03	18	140.88	27.5
	142.28	1641	142.38	95	142.53	91	142.64	13.53	142.79	42.4	142.9	43.1	143.02	43.1	143.14	13.18	143.27	16	142.13	29.4
	143.53	1725	143.63	95	143.77	91.4	143.88	11.68	144.03	43.9	144.13	43.9	144.28	43.9	144.37	12.65	144.51	16	143.38	43.9
	144.77	1801	144.88	95	145.03	87.5	145.12	11.65	145.26	45.1	145.37	46.3	145.52	46.7	145.63	12.78	145.78	14	144.62	43.9
	146.01	1558	146.12	95	146.27	0	146.38	7.87	146.52	52.2	146.62	36.9	146.77	18	146.87	8.78	147.02	0	145.87	54.9
	147.28	1268	147.37	95	147.51	99.2	147.62	13.71	147.77	14.9	147.88	17.3	148.03	19.6	148.12	12.46	148.26	20	147.13	8.6
	148.53	1338	148.63	95	148.77	65.5	148.88	7.87	149.01	50.2	149.12	49.8	149.27	50.2	149.38	8.37	149.52	8	148.37	39.2
	149.76	1375	149.87	95	150.02	52.2	150.14	7.06	150.27	68.2	150.37	67.8	150.52	69	150.62	6.31	150.77	24	149.64	49.8
	151.03	1364	151.13	95	151.27	0	151.37	7.15	151.54	65.5	151.65	66.3	151.77	65.5	151.88	6.06	152.02	16	150.88	72.5
	152.29	1368	152.4	95	152.52	0	152.62	7.25	152.78	71	152.89	72.2	153.03	72.9	153.13	6.18	153.28	16	152.12	66.3
	153.51	1338	153.62	95	153.79	0	153.9	12.31	154.03	0	154.13	0	154.27	0	154.37	12.21	154.54	-14	153.37	75.3
	154.77	1285	154.87	95	155.01	0	155.12	12.21	155.28	0	155.38	0	155.53	0	155.62	11.65	155.75	-14	154.65	0
	155.93	1106	156.04	95	156.15	4.7	156.3	7.53	156.42	25.1	156.53	28.2	156.62	29.8	156.79	6.62	156.88	18	155.82	0
	157.13	993	157.28	95	157.38	0	157.54	5.75	157.65	58	157.77	58.8	157.88	68.6	158.02	8.34	158.12	16	157.03	38
	158.38	1612	158.52	95	158.63	94.5	158.76	11.15	158.87	27.5	159.02	28.2	159.14	27.8	159.27	12.21	159.38	16	158.27	47.5
	159.62	1652	159.79	95	159.88	99.2	160.03	13.09	160.12	32.5	160.26	33.7	160.37	33.3	160.52	13.5	160.63	24	159.52	28.6
	160.87	1710	161.01	95	161.12	77.6	161.27	10.75	161.38	48.2	161.52	48.2	161.62	48.2	161.76	11.28	161.87	16	160.78	42.4
	162.13	1741	162.28	95	162.37	54.9	162.51	9.18	162.62	62.7	162.77	75.3	162.89	77.3	163.03	8.93	163.12	14	162.02	48.2
	163.37	1729	163.52	95	163.63	42.4	163.78	7.28	163.87	80	164.01	79.6	164.12	80	164.27	7.46	164.39	0	163.26	79.2
	164.64	1659	164.78	95	164.89	4.3	165.03	8.12	165.13	69.8	165.28	69.4	165.37	69.8	165.51	7.03	165.62	10	164.52	69.4
	165.9	1617	166.02	95	166.12	21.6	166.26	7.4	166.37	83.9	166.52	83.5	166.64	83.1	166.77	7.03	166.87	14	165.79	69.8
	167.12	1577	167.28	95	167.39	27.1	167.54	7.4	167.63	71.4	167.77	73.3	167.87	74.5	168.02	6.59	168.13	12	167.01	82.7
	168.37	1509	168.52	95	168.62	0	168.78	7.9	168.88	75.7	169.03	76.1	169.14	76.1	169.27	6.46	169.38	20	168.28	73.7
	169.63	1438	169.77	95	169.88	23.5	170.02	5.96	170.12	84.3	170.28	84.7	170.38	84.3	170.53	6.62	170.62	16	169.53	78
	170.87	1431	171.03	95	171.14	58.4	171.28	6.65	171.38	83.5	171.53	83.9	171.63	84.3	171.78	6.81	171.88	14	170.76	84.3
	172.12	1431	172.27	95	172.38	64.7	172.53	6.71	172.63	83.9	172.78	83.9	172.87	83.9	173.01	6.93	173.12	14	172.02	84.3
	173.38	1448	173.52	94	173.63	63.1	173.77	6.65	173.87	83.9	174.02	83.5	174.13	83.9	174.27	6.56	174.37	8	173.27	83.9
	174.62	1427	174.77	94	174.88	0	175.02	7.31	175.12	82.4	175.26	81.6	175.37	82.4	175.52	5.84	175.63	16	174.51	82.4
	175.87	1338	176.01	94	176.12	0	176.27	6.78	176.38	83.5	176.52	83.9	176.62	83.5	176.76	5.65	176.87	-20	175.78	82.4
	177.13	1160	177.27	94	177.37	0	177.51	8.4	177.62	34.1	177.77	40	177.88	43.1	178.02	6.87	178.13	18	177.02	3.5
	178.38	957	178.56	94	178.66	22	178.78	5.46	178.87	38.4	179.02	37.6	179.12	38	179.27	5.15	179.39	12	178.28	48.2
	179.63	864	179.77	94	179.87	23.9	180.02	5.28	180.13	38.8	180.28	38.8	180.38	38.4	180.53	5.25	180.63	14	179.52	38.8
	180.88	872	181.03	94	181.12	23.5	181.26	5.31	181.37	39.6	181.52	25.1	181.63	1.6	181.77	6.84	181.88	-14	180.78	38.8
	182.12	848	182.28	94	182.38	16.9	182.52	7	182.62	24.3	182.76	30.2	182.87	30.6	183.02	5.87	183.13	8	182.02	0
	183.37	850	183.51	94	183.62	17.3	183.78	5.65	183.89	34.1	184.03	33.7	184.14	34.5	184.27	5.34	184.37	14	183.27	30.2
	184.64	832	184.77	94	184.88	18	185.02	5.59	185.12	34.1	185.28	34.1	185.39	34.5	185.52	5.37	185.62	14	184.53	34.5
	185.87	828	186.03	94	186.13	18	186.27	5.56	186.38	33.7	186.52	34.1	186.62	33.7	186.79	5.4	186.9	14	185.77	34.5
	187.12	829	187.26	94	187.37	17.6	187.52	5.56	187.63	33.7	187.77	33.7	187.88	33.7	188.02	5.4	188.12	14	187.02	33.7
	188.39	825	188.52	94	188.62	18.4	188.76	5.46	188.87	33.3	189.04	32.9	189.15	33.3	189.27	5.34	189.37	12	188.27	34.1
	189.62	823	189.77	94	189.88	17.6	190.02	5.53	190.12	33.3	190.26	33.3	190.37	32.9	190.52	5.43	190.63	14	189.51	33.3
	190.87	825	191.01	94	191.12	18	191.27	5.68	191.39	33.3	191.52	32.9	191.62	33.3	191.76	5.43	191.87	14	190.78	32.9
	192.15	826	192.27	94	192.37	17.3	192.51	5.5	192.62	33.7	192.78	33.7	192.89	33.7	193.02	5.43	193.14	14	192.04	33.3
	193.37	823	193.52	94	193.64	17.3	193.77	5.5	193.87	0.8	194.01	2	194.12	3.5	194.27	10.25	194.38	22	193.27	33.3
	194.62	1094	194.76	94	194.87	88.6	195.02	8.78	195.13	27.1	195.27	27.1	195.37	27.1	195.51	8.4	195.62	24	194.53	23.1
	195.88	791	196.03	94	196.12	6.7	196.26	6.15	196.37	34.1	196.54	35.3	196.65	35.3	196.77	5.71	196.87	20	195.77	32.5
	197.12	887	197.28	94	197.38	23.1	197.52	5.46	197.63	36.5	197.77	36.9	197.87	36.9	198.02	5.34	198.14	16	197.02	35.7
	198.38	874	198.52	94	198.62	21.6	198.78	5.4	198.88	33.3	199.02	32.9	199.12	32.9	199.26	5.18	199.37	12	198.28	37.3
	199.64	798	199.79	94	199.88	14.5	200.02	5.56	200.12	35.7	200.27	35.3	200.39	35.3	200.53	5.37	200.63	12	199.52	32.9
	200.87	841	201.03	94	201.13	18	201.28	5.56	201.37	34.9	201.51	34.9	201.62	35.3	201.78	5.37	201.88	12	200.77	35.3
	202.14	829	202.28	94	202.38	18	202.53	5.53	202.63	34.5	202.78	34.9	202.87	34.5	203.01	5.37	203.12	12	202.03	35.3
	203.38	827	203.53	94	203.62	18	203.76	5.56	203.87	34.5	204.03	34.5	204.14	34.5	204.28	5.34	204.38	10	203.28	34.5
	204.63	826	204.78	94	204.88	18	205.03	5.5	205.13	34.1	205.27	34.1	205.37	33.7	205.55	5.34	205.65	12	204.53	34.5
	205.88	823	206.02	94	206.12	18	206.27	5.53	206.38	33.3	206.52	33.7	206.62	33.3	206.77	5.43	206.87	16	205.78	33.3
	207.14	827	207.28	94	207.38	17.3	207.52	5.56	207.62	33.7	207.77	33.7	207.89	33.7	208.02	5.4	208.13	12	207.02	33.7
	208.38	826	208.54	94	208.65	17.6	208.77	5.5	208.87	33.7	209.01	33.7	209.12	34.1	209.27	5.37	209.38	12	208.28	33.7
	209.63	825	209.77	94	209.87	18	210.02	5.56	210.13	33.7	210.27	33.7	210.38	34.1	210.53	5.37	210.63	12	209.53	34.1
	210.88	825	211.02	94	211.13	18	211.27	5.56	211.37	33.7	211.52	33.3	211.63	33.3	211.78	5.37	211.87	12	210.78	34.1
	212.12	827	212.28	94	212.38	18	212.52	5.53	212.63	33.3	212.78	33.3	212.88	33.7	213.05	5.4	213.15	12	212.01	33.7
	213.37	825	213.51	94	213.62	18	213.77	5.5	213.89	33.7	214.02	33.7	214.13	33.7	214.27	5.37	214.37	12	213.27	33.7
	214.63	825	214.77	94	214.87	18	215.01	5.56	215.12	33.7	215.27	33.7	215.38	33.7	215.52	5.4	215.62	12	214.53	33.7
	215.87	824	216.03	94	216.13	18	216.27	5.62	216.37	33.3	216.51	33.7	216.62	33.7	216.77	5.4	216.88	12	215.76	33.7
	217.13	825	217.28	94	217.38	17.6	217.53	5.59	217.63	33.7	217.78	33.7	217.87	33.7	218.01	5.43	218.12	12	217.02	33.7
	218.38	826	218.52	94	218.63	18	218.77	5.5	218.87	33.7	219.03	33.7	219.13	33.7	219.28	5.37	219.37	12	218.27	33.7
	219.62	825	219.77	94	219.89	18	220.02	5.56	220.12	33.7	220.26	33.7	220.37	33.7	220.52	5.4	220.63	12	219.52	33.7
	220.89	824	221.02	94	221.12	18	221.28	5.56	221.38	33.7	221.53	33.7	221.64	33.7	221.76	5.4	221.87	12	220.78	33.7
	222.13	826	222.28	94	222.37	17.3	222.49	5.5	222.58	33.7	222.7	33.7	222.79	33.7	222.88	5.4	222.99	12	222.02	33.7
	223.22	825	223.32	94	223.43	17.6	223.53	5.59	223.62	33.7	223.72	33.7	223.82	33.7	223.92	5.43	224.03	14	223.1	33.7
	224.27	826	224.39	94	224.53	17.3	224.64	5.5	224.78	33.7	224.89	33.7	225	33.7	225.1	5.4	225.26	12	224.12	33.7
	225.41	825	225.53	94	225.62	18	225.79	5.43	225.89	33.7	226.01	32.9	226.12	33.7	226.27	5.37	226.37	12	225.32	33.7
	226.64	827	226.77	94	226.89	17.6	227.01	5.56	227.12	33.7	227.27	33.7	227.38	33.7	227.53	5.4	227.62	12	226.53	33.7
	227.87	826	228.03	94	228.13	17.6	228.28	5.59	228.37	33.7	228.51	33.7	228.62	33.7	228.77	5.4	228.88	12	227.76	33.7
	229.12	824	229.26	94	229.37	17.6	229.52	5.56	229.64	33.7	229.77	33.7	229.88	33.7	230.02	5.4	230.14	12	229.02	33.7
	230.38	825	230.52	94	230.62	18.4	230.76	5.56	230.87	33.7	231.03	34.1	231.13	33.7	231.27	5.43	231.37	14	230.28	33.7
	231.62	826	231.77	94	231.88	18	232.02	5.5	232.12	33.7	232.26	33.7	232.37	33.7	232.52	5.4	232.64	14	231.51	33.7
	232.88	826	233.02	94	233.12	18	233.28	5.5	233.39	33.7	233.52	33.7	233.62	33.7	233.76	5.4	233.87	12	232.77	33.7
	234.13	823	234.28	94	234.37	21.2	234.51	5.46	234.62	15.3	234.77	17.6	234.88	19.2	235.02	8.65	235.12	22	234.03	33.7
	235.37	1252	235.52	94	235.63	99.6	235.77	9.21	235.88	20	236.02	9	236.12	2.4	236.29	11.71	236.4	-10	235.26	34.9
	236.62	1268	236.76	94	236.87	99.2	237.05	13.68	237.15	0	237.27	0	237.37	1.6	237.51	18.18	237.62	12	236.52	1.6
	237.88	1887	238.02	94	238.14	71.8	238.27	18.12	238.37	43.5	238.52	47.5	238.64	47.8	238.78	14.37	238.88	12	237.77	9.8
	239.14	1801	239.28	94	239.39	0	239.52	8.78	239.63	49.4	239.77	44.3	239.87	40.4	240.03	7.62	240.14	6	239.02	45.9
	240.38	1181	240.52	94	240.62	91.4	240.77	10.68	240.89	22.7	241.02	24.7	241.14	32.5	241.27	9.78	241.37	20	240.27	26.7
	241.64	1279	241.77	94	241.89	0	242.01	7.09	242.12	46.7	242.27	45.9	242.38	46.3	242.52	6.25	242.64	16	241.52	41.6
	242.87	1122	243.03	94	243.13	12.9	243.27	5.71	243.39	43.9	243.53	23.9	243.64	21.6	243.78	5.15	243.88	2	242.77	46.3
	244.14	1066	244.26	94	244.37	89	244.52	10.75	244.64	8.2	244.77	9	244.87	8.2	245.01	10.75	245.12	20	244.02	11.4
	245.38	1218	245.53	94	245.64	98	245.79	11.75	245.9	23.9	246.02	24.7	246.13	26.7	246.27	11.59	246.38	18	245.28	14.5
	246.62	1395	246.78	94	246.88	99.2	247.02	11.28	247.13	20	247.28	18.8	247.38	18	247.53	14.18	247.64	16	246.52	29
	247.89	1642	248.03	94	248.13	96.1	248.28	15.84	248.38	36.9	248.53	40	248.62	40.4	248.76	16.18	248.87	16	247.78	14.1
	249.13	1913	249.27	94	249.39	97.3	249.51	14.87	249.62	42	249.77	42.4	249.88	42.4	250.02	16.4	250.12	18	249.02	42.4
	250.38	1846	250.54	94	250.65	0	250.77	9	250.87	57.6	251.01	59.6	251.12	51.4	251.27	7.65	251.38	4	250.27	54.9
	251.62	1230	251.76	94	251.87	99.2	252.02	13	252.13	10.6	252.27	11.8	252.37	14.9	252.51	12.81	252.62	22	251.53	11.4
	252.88	1295	253.03	94	253.12	64.3	253.26	7.81	253.37	49	253.52	51.8	253.63	50.2	253.77	7.84	253.89	22	252.77	32.5
	254.12	1274	254.27	94	254.38	0	254.52	6.37	254.62	53.3	254.76	53.7	254.87	53.7	255.02	6.09	255.13	20	254.02	52.9
	255.37	1204	255.51	94	255.62	0	255.77	6.15	255.88	56.1	256.02	56.1	256.12	56.1	256.26	5.62	256.37	18	255.28	54.5
	256.63	1119	256.78	94	256.87	0	257.01	5.9	257.12	58	257.29	58.8	257.4	58.8	257.52	5.21	257.62	20	256.53	56.9
	257.87	1050	258.02	94	258.14	20	258.28	5.46	258.39	65.5	258.53	68.2	258.63	69.4	258.78	4.53	258.89	10	257.76	60
	259.14	996	259.27	94	259.37	62.7	259.53	5.25	259.63	49	259.77	48.2	259.89	48.6	260.01	5.28	260.12	4	259.03	64.3
	260.38	888	260.53	94	260.62	23.9	260.76	5.21	260.87	46.7	261.04	46.7	261.15	46.7	261.27	5.28	261.37	12	260.27	46.7
	261.62	896	261.79	94	261.9	1.6	262.02	5.21	262.12	52.2	262.27	52.9	262.38	55.7	262.53	5.34	262.63	20	261.52	46.7
	262.87	1025	263.02	94	263.12	0	263.27	5.78	263.38	83.9	263.52	84.3	263.62	84.3	263.76	5.46	263.87	16	262.78	63.9
	264.13	1216	264.27	94	264.38	0	264.52	6.12	264.62	84.3	264.77	83.5	264.88	84.3	265.02	5.34	265.12	16	264.02	84.3
	265.37	1072	265.49	94	265.59	6.7	265.7	5.4	265.81	83.9	265.9	63.9	266.02	49	266.12	3.12	266.27	14	265.26	84.3
[code]
matt-t
Post by matt-t »
And the auto-scan
[code]
Monday,30,July,2018,11:16:05:02866
VCDS Version: https://protect-eu.mimecast.com/s/SEPECAnw2cNMYyqTGXZN6?domain=18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180212 DS287.0
https://protect-eu.mimecast.com/s/VMLJCBgx2u73oQ2T6M5rW?domain=ross-tech.com
VIN: WVWZZZ6RZCU026794   License Plate: HJ12 UNL
Mileage: 95740km-59490mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZCU026794   Mileage: 95740km-59490miles
56-Radio -- Status: OK 0000
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 A    HW: 03P 907 425 A
   Component: R3 1.2l TDI   H07 9978
   Revision: 11002001    Serial number:
   Coding: 00114010000500080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12TDI03103P906021A 001023
   ROD: EV_ECM12TDI03103P906021.rod
   VCID: 261406847867BE17284-8072
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 230224E3416F00B8C42C24EB82D500821300
   Shop #: WSC 31414 790 31414
   VCID: 074A6B009F6D871F332-8052
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 323CEAD4442FD2B7B4C-8066
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0254
   Revision: BF046001    Serial number: 0434 207110318
   Coding: 3CB02BBF08A10000003008002D2B0CD00000410F60060000200000000000
   Shop #: WSC 16862 123 104857
   VCID: 45D6A108E5A1550F01E-8010
   Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU026071100013410
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU027071100015759
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU025071100014267
   Coding: 08BC32
   Subsystem 4 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU009081100011473
   Coding: 08BC32
   Component: VW10Airbag027 H09 0020
   Revision: --------    Serial number: 003GX00SKBAZ
   Coding: 003237
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACC9234CC3FBA77ECC-801E
   Serial number: 3575HRB40590OPI2DPI3
   Serial number: 3585HRB40590OPI2B057
   Serial number: 3515RRB40570L9U4FHU6
   Serial number: 3525RRB40570L9U4E0OQ
   Part No SW: 6R0 920 961 H    HW: 6R0 920 961 H
   Component: KOMBI         H03 0505
   Coding: 440A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3B22C7F093E513FF67A-806E
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0254
   Revision: BF046001
   Coding: 002300
   VCID: 70B820DC8AA3A0A7828-8024
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8C32B4ACFF5A77CCC-803E
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7660594521
   Coding: 010000
   VCID: 290E0DB869F9916F056-807C
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 31414
   VCID: 2F3AE3A05E5DFF5FDB2-807A
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: Radio RCD310  032 0079
   Revision: 01000001    Serial number: VWZ1Z2L3480362
   Coding: 01000400020001
   VCID: 3332EFD0BB35DBBFBFA-8066
End----------(Elapsed Time: 01:13, VBatt start/end: 12.3V/12.4V)-----------
Readiness Status: 00000000 00001110 11101000 00000000
MIL Status: MIL OFF
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Passed
Number of EOBD-related DTC(s): 0
[code]
matt-t
Post by matt-t »
Anyone? :( :?:
Look pretty much OK to me, the car isn't complaining about EGR issues. Did you have the emissions update done?
PS, strange header in your VCDS with the mimecast referrer?
matt-t
Post by matt-t »
iichel wrote: Wed Aug 01, 2018 6:06 pm Look pretty much OK to me, the car isn't complaining about EGR issues. Did you have the emissions update done?
Mimecast is security software, indpendent to VCDS.
The car had the emission fix done and then the EGR failed within months, VW replaced the EGR for free as it was a direct result of the fix. The car has done approx 6000-6200 miles since the new EGR and the car is starting to play up again.
Rough idle, Poor MPG, DPF regen is more frequent circa every 250 miles and it can be hesitant to pull off sometimes.
I presume the DPF regen to be a result of the EGR potentially sticking open and allowing constant flow through it causing excessive soot loading. These symptoms are similar to the previous EGR failure, but it wasn't until the valve went completely that it caused the EML light and limp mode to follow.
