Hi All,
I am experiencing an issue with the other half's polo TDI.
I beleive there to be a fault with the EGR valve as it is showing similar symptons to when it failed 6000miles ago.
Rough idle, Poor MPG, DPF regen is more frequent and noisy engine.
There is currently no EML light on but the car feels crap! I do have .csv logs from VCDS if anyone is able to interpret them.
Thanks in advance.
Polo 6R TDi EGR Issues - VCDS Log Available.
Re: Polo 6R TDi EGR Issues - VCDS Log Available.
Well let's have a look at the log.
I will need to upload them when i get home, works machine doesn't like it for some reason.
I have logged the following,
Air Mass Actual Value
EGR Specified Value
EGR Solenoid Value
Exhaust Mass Flow of EGR
OBD EGR Position.
Is there anything else to add to the log?
Yes, a VCDS autoscan please.
Please find attached my log, this is all i have at the moment, quite happy to graph it or change the data if needed (VCDS Newbie)
Marker TIME Loc. IDE00021 TIME Loc. IDE00025 TIME Loc. IDE00085 TIME Loc. IDE00347 TIME Loc. IDE00473-ENG101849 TIME Loc. IDE00581 TIME Loc. IDE01259-ENG101849 TIME Loc. IDE03383 TIME Loc. IDE04257 TIME Loc. ENG107874-ENG98842
STAMP Engine speed STAMP Coolant temperature STAMP Normed load value STAMP Air mass: actual value: STAMP EGR Vacuum Regulator Solen.val.: activation-PWM rate STAMP EGR specified value STAMP EGR Solen.val.: actual value-PWM rate STAMP Exhaust mass flow of EGR STAMP High pressure EGR actuator: activation STAMP OBD EGR position control-Position
/min °C % g/s % % % g/s % %
0.14 1296 0.27 93 0.37 92.2 0.51 9.43 0.62 27.1 0.8 22.4 0.9 21.2 1.02 9.68 1.13 10 0.03 19.2
1.37 1268 1.53 93 1.63 60.8 1.77 8.78 1.88 40 2.03 35.3 2.13 34.9 2.28 6.03 2.39 12 1.27 15.3
2.62 885 2.76 93 2.87 23.5 3.03 5.28 3.13 38 3.28 38 3.38 38 3.53 5.46 3.63 14 2.51 35.3
3.89 879 4.03 93 4.12 23.5 4.26 8.25 4.37 0 4.53 5.1 4.63 4.3 4.78 11.12 4.88 18 3.78 38
5.13 1192 5.3 93 5.42 67.5 5.53 12.68 5.62 15.7 5.76 14.5 5.87 15.3 6.03 13 6.13 22 5.02 4.7
6.37 1680 6.51 93 6.62 96.1 6.78 14.9 6.89 34.9 7.02 36.1 7.14 36.5 7.27 16.25 7.37 22 6.28 22.4
7.64 1969 7.77 93 7.87 0 8.01 9.84 8.12 52.5 8.3 47.8 8.4 33.3 8.53 9.09 8.63 10 7.52 47.1
8.88 1344 9.03 93 9.14 99.2 9.27 15.06 9.37 8.6 9.51 9.8 9.62 11 9.77 16.4 9.89 22 8.78 14.1
10.12 1673 10.27 93 10.37 99.6 10.52 17.31 10.63 27.5 10.78 28.6 10.87 28.6 11.02 19.28 11.12 18 10.03 19.2
11.38 1985 11.52 93 11.63 0 11.78 10.71 11.89 56.5 12.03 55.3 12.14 55.7 12.27 9.12 12.38 8 11.27 43.9
12.64 1165 12.79 93 12.9 76.5 13.02 5.21 13.14 37.3 13.29 36.9 13.4 36.9 13.51 6.9 13.62 10 12.53 54.9
13.87 1209 14.02 93 14.12 85.1 14.28 7.25 14.38 33.3 14.53 34.5 14.63 37.6 14.78 7.9 14.88 20 13.77 32.9
15.13 1245 15.28 93 15.38 47.1 15.52 6.59 15.64 53.7 15.78 54.1 15.89 54.5 16.03 5.81 16.12 12 15.03 45.9
16.37 1202 16.53 93 16.63 0.4 16.78 6.21 16.88 55.3 17.02 55.7 17.12 58.4 17.27 5.43 17.38 0 16.27 52.5
17.62 1204 17.77 93 17.87 69 18.04 5.78 18.15 33.3 18.27 30.6 18.37 25.9 18.51 7.5 18.62 10 17.53 56.5
18.88 1217 19.02 93 19.13 92.5 19.28 8.81 19.38 27.1 19.53 27.8 19.63 26.7 19.77 9.31 19.89 14 18.77 25.1
20.13 1269 20.28 93 20.38 90.6 20.53 9.25 20.63 32.5 20.77 32.9 20.87 32.9 21.02 9.37 21.14 18 20.02 27.8
21.39 1328 21.53 93 21.63 89 21.78 8.81 21.89 36.9 22.03 36.9 22.12 37.3 22.26 9.12 22.37 20 21.28 34.5
22.63 1369 22.77 93 22.88 74.9 23.03 7.56 23.13 46.7 23.28 46.7 23.38 47.1 23.52 8.09 23.62 16 22.52 44.3
23.87 1385 24.03 93 24.13 79.6 24.27 7.25 24.38 46.7 24.52 46.7 24.63 50.2 24.79 7.9 24.88 8 23.76 47.1
25.12 1385 25.27 93 25.37 0 25.54 7.31 25.63 54.9 25.77 54.9 25.88 54.9 26.02 6.03 26.12 18 25.02 51.8
26.38 1284 26.52 93 26.62 0 26.77 6.87 26.87 59.2 27.02 59.6 27.13 59.6 27.27 5.56 27.37 12 26.28 56.5
27.62 1085 27.77 93 27.88 0 28.03 5.84 28.12 55.7 28.26 46.3 28.37 46.3 28.53 4.59 28.63 6 27.51 59.6
28.88 879 29.02 93 29.12 25.9 29.27 5 29.38 44.3 29.53 44.7 29.62 44.3 29.77 5.12 29.87 10 28.77 46.3
30.13 875 30.28 94 30.37 24.3 30.51 5.12 30.62 44.3 30.78 43.9 30.88 43.9 31.03 5.18 31.13 10 30.02 44.3
31.37 864 31.52 94 31.64 25.9 31.78 5.25 31.88 0 32.03 5.5 32.13 9.4 32.28 12.87 32.38 12 31.27 43.9
32.62 1396 32.76 94 32.87 78.8 33.02 8.68 33.13 39.6 33.28 40.4 33.37 40 33.51 8.4 33.62 8 32.53 26.7
33.88 1226 34.03 94 34.13 80 34.27 10.65 34.37 9.8 34.55 17.3 34.65 18 34.77 11.96 34.87 16 33.77 31.4
35.12 1656 35.27 94 35.38 98.8 35.53 14.65 35.62 32.2 35.76 39.2 35.87 43.1 36.02 15.12 36.13 20 35.01 25.1
36.38 2004 36.52 94 36.62 0 36.78 9.71 36.88 54.5 37.03 56.1 37.12 58 37.26 8.31 37.37 8 36.28 45.9
37.63 1197 37.79 94 37.9 85.5 38.02 6.93 38.12 35.7 38.27 31.8 38.38 31.8 38.53 8.09 38.63 14 37.52 51.8
38.87 1365 39.03 94 39.13 99.6 39.27 10.59 39.38 25.9 39.52 26.3 39.64 25.9 39.78 11.4 39.88 20 38.77 29.4
40.12 1546 40.26 94 40.37 99.2 40.53 12.62 40.64 26.3 40.78 25.1 40.87 23.9 41.01 13.46 41.12 6 40.03 27.5
41.39 1761 41.52 94 41.62 97.3 41.76 24.4 41.87 5.1 42.03 5.9 42.13 7.5 42.28 29.03 42.37 16 41.27 8.6
42.62 2150 42.78 94 42.88 74.9 43.02 22.5 43.12 53.7 43.27 33.7 43.37 34.5 43.52 24.65 43.64 22 42.51 16.5
43.88 1643 44.02 94 44.12 83.1 44.28 21.46 44.39 0 44.52 0 44.62 0 44.76 17.34 44.87 -14 43.77 9.8
45.13 1381 45.28 94 45.37 99.2 45.51 19.21 45.62 0 45.77 0 45.89 0 46.03 22.43 46.12 2 45.03 0
46.37 1520 46.53 94 46.63 76.5 46.78 20.06 46.88 21.2 47.02 21.6 47.12 21.2 47.27 19.53 47.39 20 46.26 2.7
47.62 1647 47.76 94 47.87 94.9 48.03 18.65 48.13 22.4 48.28 23.1 48.39 23.1 48.52 19.5 48.64 22 47.52 22
48.89 1743 49.03 94 49.12 58.8 49.26 22.59 49.37 33.7 49.52 0.8 49.63 6.7 49.78 21.53 49.88 20 48.78 27.5
50.12 1780 50.27 94 50.38 48.6 50.53 12.96 50.62 47.8 50.76 54.9 50.87 56.9 51.04 11.75 51.15 14 50.01 25.1
51.37 1772 51.51 94 51.62 71.8 51.77 10.03 51.88 55.7 52.03 54.9 52.12 55.7 52.27 10.62 52.37 18 51.27 56.5
52.63 1763 52.77 94 52.88 44.3 53.02 8.18 53.13 60 53.28 63.1 53.38 62.4 53.52 7.93 53.62 8 52.52 56.5
53.87 1687 54.02 94 54.13 0 54.28 8.03 54.37 62.7 54.52 62.4 54.62 62.7 54.78 7.15 54.88 14 53.76 63.1
55.12 1583 55.26 95 55.37 0 55.52 8.06 55.64 63.9 55.77 0.8 55.87 0.8 56.02 13.5 56.12 -14 55.03 62.7
56.39 1408 56.53 95 56.62 0 56.76 13.46 56.87 0 57.03 0 57.13 0 57.27 12.34 57.37 -14 56.28 0
57.62 1089 57.77 95 57.88 14.5 58.02 7.4 58.13 30.2 58.28 33.7 58.38 36.1 58.53 6.31 58.63 16 57.51 0
58.87 884 59.01 95 59.12 7.1 59.27 5.43 59.38 43.9 59.53 43.9 59.64 47.8 59.78 5.31 59.88 2 58.77 36.5
60.13 1616 60.27 95 60.38 99.6 60.52 12.28 60.62 6.7 60.77 2.4 60.88 2.7 61.03 16.25 61.12 12 60.03 54.5
61.37 1690 61.52 95 61.63 98.8 61.78 22.78 61.87 7.5 62.01 9.8 62.12 10.2 62.27 24.43 62.38 24 61.27 3.5
62.62 2048 62.76 95 62.87 80.8 63.03 20.75 63.13 47.5 63.27 50.2 63.37 51.8 63.51 13.4 63.62 8 62.53 19.2
63.88 1481 64.03 95 64.12 99.2 64.26 18.06 64.37 0 64.52 1.6 64.63 0 64.78 16.78 64.88 -14 63.77 50.6
65.12 1373 65.27 95 65.38 99.6 65.54 18.93 65.65 0 65.76 0 65.87 0 66.02 22.12 66.13 -14 65.02 0
66.37 1519 66.51 95 66.62 86.7 66.77 22.15 66.88 18 67.02 19.2 67.12 19.2 67.26 21.09 67.37 16 66.27 1.6
67.65 1652 67.77 95 67.87 94.5 68.01 20.09 68.12 22 68.27 22.7 68.38 22.7 68.53 21.15 68.62 18 67.55 19.6
68.87 1763 69.03 95 69.13 95.3 69.27 20.21 69.38 29 69.52 32.5 69.62 34.1 69.78 23.5 69.88 16 68.77 23.9
70.12 1838 70.26 95 70.37 52.9 70.53 19.21 70.63 36.1 70.78 39.2 70.87 42 71.01 16.09 71.12 8 70.03 29
71.38 1864 71.53 95 71.63 91.8 71.78 13 71.88 38 72.04 36.9 72.15 37.3 72.27 14.46 72.37 14 71.27 45.5
72.62 1902 72.77 95 72.88 42.7 73.02 11.46 73.12 47.1 73.26 51 73.37 51 73.53 10.5 73.63 12 72.51 36.9
73.87 1381 74.01 95 74.12 98 74.27 14.81 74.39 0.8 74.53 0.8 74.62 1.6 74.77 14.34 74.87 -8 73.77 48.6
75.13 1250 75.27 95 75.37 98.8 75.53 15.59 75.63 0 75.78 0 75.88 0 76.03 16.9 76.13 -14 75.03 1.6
76.38 1276 76.53 96 76.63 72.2 76.78 16.43 76.87 9.8 77.01 13.3 77.12 16.1 77.29 14.5 77.4 12 76.28 0
77.62 1298 77.76 96 77.87 93.3 78.03 13.37 78.13 17.3 78.28 19.6 78.37 21.6 78.52 13.25 78.62 22 77.52 16.1
78.88 1318 79.04 96 79.13 89.4 79.27 10.34 79.37 25.9 79.52 25.9 79.63 25.9 79.78 10.93 79.87 16 78.77 27.8
80.12 1326 80.27 96 80.38 94.1 80.52 10.56 80.62 25.9 80.77 26.3 80.87 25.9 81.03 11 81.13 14 80.01 25.5
81.37 1332 81.52 96 81.62 94.5 81.78 10.68 81.88 27.8 82.03 29.8 82.12 33.7 82.26 10.31 82.37 18 81.28 26.3
82.63 1337 82.78 96 82.87 84.3 83.02 8.65 83.12 36.9 83.27 36.1 83.39 36.9 83.53 9.15 83.63 12 82.52 37.3
83.88 1334 84.03 96 84.13 89.8 84.29 8.43 84.4 35.3 84.54 35.3 84.63 35.7 84.78 9.06 84.88 8 83.77 36.5
85.13 1337 85.27 96 85.37 89.8 85.52 8.53 85.63 34.9 85.77 34.9 85.88 34.9 86.03 9 86.13 14 85.03 34.9
86.4 1334 86.52 96 86.62 89.8 86.77 8.59 86.87 34.9 87.03 34.9 87.13 35.3 87.28 8.96 87.38 14 86.29 35.3
87.62 1338 87.77 96 87.88 89.4 88.03 8.65 88.12 34.5 88.26 35.3 88.37 35.3 88.53 9.03 88.63 14 87.52 34.9
88.87 1340 89 96 89.07 83.1 89.18 8.56 89.29 42 89.4 43.9 89.53 44.3 89.63 8.59 89.77 16 88.77 35.3
90.03 1338 90.13 96 90.27 17.6 90.38 6.78 90.53 51.4 90.64 52.5 90.78 52.9 90.88 6.43 91.03 18 89.87 45.9
91.26 1303 91.37 96 91.53 0 91.63 6.9 91.77 55.7 91.88 56.1 92.03 56.5 92.13 6.09 92.28 18 91.12 52.9
92.52 1256 92.62 97 92.76 0 92.87 10.28 93.02 0 93.13 3.5 93.27 8.2 93.38 11.56 93.52 16 92.38 57.6
93.77 1234 93.88 97 94.02 60 94.12 8.75 94.26 18.4 94.37 17.6 94.53 18 94.64 9.71 94.77 12 93.62 25.1
95.02 1233 95.12 97 95.28 99.6 95.39 10.68 95.52 23.5 95.62 23.9 95.76 23.9 95.87 10.43 96.03 14 94.88 17.3
96.27 1256 96.38 97 96.52 78.4 96.62 9.28 96.78 44.3 96.89 47.1 97.02 48.6 97.12 8.03 97.26 22 96.13 27.1
97.52 1241 97.64 97 97.79 0 97.89 6.4 98.01 55.7 98.12 55.7 98.27 56.5 98.38 6.03 98.52 20 97.37 53.7
98.76 1140 98.87 97 99.03 0 99.13 6.09 99.27 58.4 99.38 58.4 99.51 58.4 99.62 5.12 99.77 0 98.64 57.3
100.02 883 100.12 97 100.26 24.7 100.37 5.09 100.52 45.9 100.64 45.1 100.77 45.5 100.88 5 101.02 20 99.89 49.4
101.27 918 101.39 97 101.52 24.3 101.62 5.12 101.76 42.7 101.87 42.7 102.02 42.4 102.14 5.21 102.28 12 101.12 47.5
102.53 887 102.64 97 102.76 39.2 102.87 6.87 103.02 23.5 103.12 31.4 103.26 38.8 103.37 10.68 103.53 4 102.38 42.7
103.78 1483 103.88 97 104.03 98.4 104.13 16.37 104.28 15.3 104.39 20 104.52 21.2 104.63 15.81 104.77 18 103.64 8.2
105.02 1818 105.13 97 105.28 99.2 105.37 16.87 105.51 32.9 105.62 34.1 105.78 40 105.89 18.34 106.02 18 104.87 25.5
106.26 1915 106.37 96 106.53 0 106.64 9.84 106.77 46.3 106.87 22.7 106.98 14.5 107.05 13.09 107.17 -26 106.12 54.1
107.38 1346 107.53 96 107.62 98 107.76 16.4 107.87 0 108.03 0 108.13 0 108.28 19.21 108.37 -14 107.28 0
108.62 1552 108.77 96 108.89 93.7 109.03 24.03 109.12 14.1 109.26 18.8 109.37 18.4 109.52 22.75 109.63 22 108.51 0
109.87 1779 110.01 96 110.12 91.4 110.27 19.34 110.38 33.3 110.53 33.7 110.62 33.7 110.76 23.18 110.87 14 109.77 23.1
111.13 1545 111.27 96 111.38 0 111.52 14.9 111.63 9 111.78 16.5 111.88 20 112.02 10.43 112.12 22 111.02 34.1
112.37 1291 112.53 96 112.64 75.3 112.77 9.12 112.87 36.1 113.01 35.3 113.12 35.3 113.28 9 113.38 16 112.26 27.8
113.63 1325 113.77 96 113.88 63.1 114.03 7.75 114.13 47.8 114.28 47.1 114.37 47.8 114.52 8.03 114.62 8 113.53 38
114.89 1340 115.03 96 115.12 73.3 115.26 6.84 115.37 46.3 115.53 45.5 115.64 45.9 115.78 7.46 115.88 6 114.78 46.3
116.13 1350 116.28 96 116.38 78.4 116.52 6.78 116.63 43.1 116.77 42.7 116.88 43.1 117.05 7.34 117.15 20 116.03 44.7
117.37 1335 117.51 96 117.62 5.1 117.77 6.87 117.88 47.8 118.03 48.2 118.14 48.6 118.26 6.34 118.37 14 117.27 44.7
118.64 1313 118.77 96 118.87 0 119.01 7.06 119.12 51.4 119.28 52.2 119.38 52.5 119.52 6.12 119.62 16 118.52 49.4
119.87 1279 120.03 96 120.14 25.9 120.27 6.12 120.38 49 120.52 45.5 120.62 41.6 120.75 5.62 120.85 10 119.76 53.3
121.07 1266 121.18 96 121.29 88.6 121.38 7.5 121.53 28.2 121.63 28.2 121.79 27.8 121.9 8.59 122.02 18 121.01 35.3
122.27 1277 122.39 96 122.53 64.7 122.62 7.84 122.76 44.7 122.87 45.9 123.03 47.5 123.14 7.87 123.27 20 122.12 28.2
123.53 1280 123.63 96 123.78 11 123.88 6.75 124.02 51.8 124.13 53.7 124.27 53.3 124.38 5.84 124.53 20 123.37 48.6
124.78 1258 124.87 96 125.02 0 125.12 6.62 125.28 56.5 125.38 56.9 125.52 56.5 125.63 5.84 125.77 16 124.63 54.5
126.02 1223 126.13 96 126.27 0 126.38 10.68 126.52 0 126.62 0 126.77 2 126.89 11.18 127.02 22 125.87 58
127.28 1186 127.38 96 127.53 0 127.63 7.59 127.78 45.5 127.87 48.2 128.01 50.2 128.12 6.62 128.27 20 127.13 25.9
128.53 1144 128.62 96 128.76 0 128.87 6 129.03 54.5 129.13 54.9 129.27 54.5 129.37 5.31 129.51 20 128.38 52.9
129.77 1059 129.88 96 130.03 0 130.12 5.84 130.26 56.5 130.37 56.5 130.52 56.5 130.63 4.71 130.77 6 129.62 55.3
131.01 852 131.12 96 131.27 26.7 131.39 5.15 131.53 43.5 131.64 43.5 131.77 43.5 131.87 5.15 132.04 22 130.87 45.1
132.27 1000 132.37 96 132.52 0 132.63 5.9 132.78 60.4 132.88 61.2 133.02 61.2 133.13 5.28 133.28 18 132.15 49
133.53 1039 133.64 96 133.77 17.6 133.87 4.87 134.01 44.3 134.12 29 134.27 23.5 134.39 6.37 134.52 10 133.38 62.4
134.77 1054 134.89 95 135.02 97.3 135.14 10.43 135.28 0 135.38 0 135.52 0 135.63 11.4 135.78 -14 134.63 8.2
136.02 1152 136.13 95 136.28 87.5 136.39 12.37 136.53 2 136.64 5.9 136.78 7.1 136.87 13.06 137.01 14 135.89 0
137.27 1258 137.39 95 137.52 97.3 137.63 12.21 137.77 23.1 137.87 23.5 138.02 23.9 138.13 11.75 138.28 18 137.12 18
138.51 1354 138.62 95 138.78 96.5 138.89 11.28 139.03 32.2 139.13 32.5 139.27 33.3 139.38 11.65 139.53 18 138.37 26.7
139.77 1453 139.88 95 140.03 99.2 140.13 11.09 140.28 31.8 140.38 30.2 140.53 30.6 140.63 11.96 140.78 12 139.63 34.5
141.04 1551 141.15 95 141.27 99.2 141.38 12.37 141.53 28.2 141.63 28.6 141.78 28.2 141.88 13.75 142.03 18 140.88 27.5
142.28 1641 142.38 95 142.53 91 142.64 13.53 142.79 42.4 142.9 43.1 143.02 43.1 143.14 13.18 143.27 16 142.13 29.4
143.53 1725 143.63 95 143.77 91.4 143.88 11.68 144.03 43.9 144.13 43.9 144.28 43.9 144.37 12.65 144.51 16 143.38 43.9
144.77 1801 144.88 95 145.03 87.5 145.12 11.65 145.26 45.1 145.37 46.3 145.52 46.7 145.63 12.78 145.78 14 144.62 43.9
146.01 1558 146.12 95 146.27 0 146.38 7.87 146.52 52.2 146.62 36.9 146.77 18 146.87 8.78 147.02 0 145.87 54.9
147.28 1268 147.37 95 147.51 99.2 147.62 13.71 147.77 14.9 147.88 17.3 148.03 19.6 148.12 12.46 148.26 20 147.13 8.6
148.53 1338 148.63 95 148.77 65.5 148.88 7.87 149.01 50.2 149.12 49.8 149.27 50.2 149.38 8.37 149.52 8 148.37 39.2
149.76 1375 149.87 95 150.02 52.2 150.14 7.06 150.27 68.2 150.37 67.8 150.52 69 150.62 6.31 150.77 24 149.64 49.8
151.03 1364 151.13 95 151.27 0 151.37 7.15 151.54 65.5 151.65 66.3 151.77 65.5 151.88 6.06 152.02 16 150.88 72.5
152.29 1368 152.4 95 152.52 0 152.62 7.25 152.78 71 152.89 72.2 153.03 72.9 153.13 6.18 153.28 16 152.12 66.3
153.51 1338 153.62 95 153.79 0 153.9 12.31 154.03 0 154.13 0 154.27 0 154.37 12.21 154.54 -14 153.37 75.3
154.77 1285 154.87 95 155.01 0 155.12 12.21 155.28 0 155.38 0 155.53 0 155.62 11.65 155.75 -14 154.65 0
155.93 1106 156.04 95 156.15 4.7 156.3 7.53 156.42 25.1 156.53 28.2 156.62 29.8 156.79 6.62 156.88 18 155.82 0
157.13 993 157.28 95 157.38 0 157.54 5.75 157.65 58 157.77 58.8 157.88 68.6 158.02 8.34 158.12 16 157.03 38
158.38 1612 158.52 95 158.63 94.5 158.76 11.15 158.87 27.5 159.02 28.2 159.14 27.8 159.27 12.21 159.38 16 158.27 47.5
159.62 1652 159.79 95 159.88 99.2 160.03 13.09 160.12 32.5 160.26 33.7 160.37 33.3 160.52 13.5 160.63 24 159.52 28.6
160.87 1710 161.01 95 161.12 77.6 161.27 10.75 161.38 48.2 161.52 48.2 161.62 48.2 161.76 11.28 161.87 16 160.78 42.4
162.13 1741 162.28 95 162.37 54.9 162.51 9.18 162.62 62.7 162.77 75.3 162.89 77.3 163.03 8.93 163.12 14 162.02 48.2
163.37 1729 163.52 95 163.63 42.4 163.78 7.28 163.87 80 164.01 79.6 164.12 80 164.27 7.46 164.39 0 163.26 79.2
164.64 1659 164.78 95 164.89 4.3 165.03 8.12 165.13 69.8 165.28 69.4 165.37 69.8 165.51 7.03 165.62 10 164.52 69.4
165.9 1617 166.02 95 166.12 21.6 166.26 7.4 166.37 83.9 166.52 83.5 166.64 83.1 166.77 7.03 166.87 14 165.79 69.8
167.12 1577 167.28 95 167.39 27.1 167.54 7.4 167.63 71.4 167.77 73.3 167.87 74.5 168.02 6.59 168.13 12 167.01 82.7
168.37 1509 168.52 95 168.62 0 168.78 7.9 168.88 75.7 169.03 76.1 169.14 76.1 169.27 6.46 169.38 20 168.28 73.7
169.63 1438 169.77 95 169.88 23.5 170.02 5.96 170.12 84.3 170.28 84.7 170.38 84.3 170.53 6.62 170.62 16 169.53 78
170.87 1431 171.03 95 171.14 58.4 171.28 6.65 171.38 83.5 171.53 83.9 171.63 84.3 171.78 6.81 171.88 14 170.76 84.3
172.12 1431 172.27 95 172.38 64.7 172.53 6.71 172.63 83.9 172.78 83.9 172.87 83.9 173.01 6.93 173.12 14 172.02 84.3
173.38 1448 173.52 94 173.63 63.1 173.77 6.65 173.87 83.9 174.02 83.5 174.13 83.9 174.27 6.56 174.37 8 173.27 83.9
174.62 1427 174.77 94 174.88 0 175.02 7.31 175.12 82.4 175.26 81.6 175.37 82.4 175.52 5.84 175.63 16 174.51 82.4
175.87 1338 176.01 94 176.12 0 176.27 6.78 176.38 83.5 176.52 83.9 176.62 83.5 176.76 5.65 176.87 -20 175.78 82.4
177.13 1160 177.27 94 177.37 0 177.51 8.4 177.62 34.1 177.77 40 177.88 43.1 178.02 6.87 178.13 18 177.02 3.5
178.38 957 178.56 94 178.66 22 178.78 5.46 178.87 38.4 179.02 37.6 179.12 38 179.27 5.15 179.39 12 178.28 48.2
179.63 864 179.77 94 179.87 23.9 180.02 5.28 180.13 38.8 180.28 38.8 180.38 38.4 180.53 5.25 180.63 14 179.52 38.8
180.88 872 181.03 94 181.12 23.5 181.26 5.31 181.37 39.6 181.52 25.1 181.63 1.6 181.77 6.84 181.88 -14 180.78 38.8
182.12 848 182.28 94 182.38 16.9 182.52 7 182.62 24.3 182.76 30.2 182.87 30.6 183.02 5.87 183.13 8 182.02 0
183.37 850 183.51 94 183.62 17.3 183.78 5.65 183.89 34.1 184.03 33.7 184.14 34.5 184.27 5.34 184.37 14 183.27 30.2
184.64 832 184.77 94 184.88 18 185.02 5.59 185.12 34.1 185.28 34.1 185.39 34.5 185.52 5.37 185.62 14 184.53 34.5
185.87 828 186.03 94 186.13 18 186.27 5.56 186.38 33.7 186.52 34.1 186.62 33.7 186.79 5.4 186.9 14 185.77 34.5
187.12 829 187.26 94 187.37 17.6 187.52 5.56 187.63 33.7 187.77 33.7 187.88 33.7 188.02 5.4 188.12 14 187.02 33.7
188.39 825 188.52 94 188.62 18.4 188.76 5.46 188.87 33.3 189.04 32.9 189.15 33.3 189.27 5.34 189.37 12 188.27 34.1
189.62 823 189.77 94 189.88 17.6 190.02 5.53 190.12 33.3 190.26 33.3 190.37 32.9 190.52 5.43 190.63 14 189.51 33.3
190.87 825 191.01 94 191.12 18 191.27 5.68 191.39 33.3 191.52 32.9 191.62 33.3 191.76 5.43 191.87 14 190.78 32.9
192.15 826 192.27 94 192.37 17.3 192.51 5.5 192.62 33.7 192.78 33.7 192.89 33.7 193.02 5.43 193.14 14 192.04 33.3
193.37 823 193.52 94 193.64 17.3 193.77 5.5 193.87 0.8 194.01 2 194.12 3.5 194.27 10.25 194.38 22 193.27 33.3
194.62 1094 194.76 94 194.87 88.6 195.02 8.78 195.13 27.1 195.27 27.1 195.37 27.1 195.51 8.4 195.62 24 194.53 23.1
195.88 791 196.03 94 196.12 6.7 196.26 6.15 196.37 34.1 196.54 35.3 196.65 35.3 196.77 5.71 196.87 20 195.77 32.5
197.12 887 197.28 94 197.38 23.1 197.52 5.46 197.63 36.5 197.77 36.9 197.87 36.9 198.02 5.34 198.14 16 197.02 35.7
198.38 874 198.52 94 198.62 21.6 198.78 5.4 198.88 33.3 199.02 32.9 199.12 32.9 199.26 5.18 199.37 12 198.28 37.3
199.64 798 199.79 94 199.88 14.5 200.02 5.56 200.12 35.7 200.27 35.3 200.39 35.3 200.53 5.37 200.63 12 199.52 32.9
200.87 841 201.03 94 201.13 18 201.28 5.56 201.37 34.9 201.51 34.9 201.62 35.3 201.78 5.37 201.88 12 200.77 35.3
202.14 829 202.28 94 202.38 18 202.53 5.53 202.63 34.5 202.78 34.9 202.87 34.5 203.01 5.37 203.12 12 202.03 35.3
203.38 827 203.53 94 203.62 18 203.76 5.56 203.87 34.5 204.03 34.5 204.14 34.5 204.28 5.34 204.38 10 203.28 34.5
204.63 826 204.78 94 204.88 18 205.03 5.5 205.13 34.1 205.27 34.1 205.37 33.7 205.55 5.34 205.65 12 204.53 34.5
205.88 823 206.02 94 206.12 18 206.27 5.53 206.38 33.3 206.52 33.7 206.62 33.3 206.77 5.43 206.87 16 205.78 33.3
207.14 827 207.28 94 207.38 17.3 207.52 5.56 207.62 33.7 207.77 33.7 207.89 33.7 208.02 5.4 208.13 12 207.02 33.7
208.38 826 208.54 94 208.65 17.6 208.77 5.5 208.87 33.7 209.01 33.7 209.12 34.1 209.27 5.37 209.38 12 208.28 33.7
209.63 825 209.77 94 209.87 18 210.02 5.56 210.13 33.7 210.27 33.7 210.38 34.1 210.53 5.37 210.63 12 209.53 34.1
210.88 825 211.02 94 211.13 18 211.27 5.56 211.37 33.7 211.52 33.3 211.63 33.3 211.78 5.37 211.87 12 210.78 34.1
212.12 827 212.28 94 212.38 18 212.52 5.53 212.63 33.3 212.78 33.3 212.88 33.7 213.05 5.4 213.15 12 212.01 33.7
213.37 825 213.51 94 213.62 18 213.77 5.5 213.89 33.7 214.02 33.7 214.13 33.7 214.27 5.37 214.37 12 213.27 33.7
214.63 825 214.77 94 214.87 18 215.01 5.56 215.12 33.7 215.27 33.7 215.38 33.7 215.52 5.4 215.62 12 214.53 33.7
215.87 824 216.03 94 216.13 18 216.27 5.62 216.37 33.3 216.51 33.7 216.62 33.7 216.77 5.4 216.88 12 215.76 33.7
217.13 825 217.28 94 217.38 17.6 217.53 5.59 217.63 33.7 217.78 33.7 217.87 33.7 218.01 5.43 218.12 12 217.02 33.7
218.38 826 218.52 94 218.63 18 218.77 5.5 218.87 33.7 219.03 33.7 219.13 33.7 219.28 5.37 219.37 12 218.27 33.7
219.62 825 219.77 94 219.89 18 220.02 5.56 220.12 33.7 220.26 33.7 220.37 33.7 220.52 5.4 220.63 12 219.52 33.7
220.89 824 221.02 94 221.12 18 221.28 5.56 221.38 33.7 221.53 33.7 221.64 33.7 221.76 5.4 221.87 12 220.78 33.7
222.13 826 222.28 94 222.37 17.3 222.49 5.5 222.58 33.7 222.7 33.7 222.79 33.7 222.88 5.4 222.99 12 222.02 33.7
223.22 825 223.32 94 223.43 17.6 223.53 5.59 223.62 33.7 223.72 33.7 223.82 33.7 223.92 5.43 224.03 14 223.1 33.7
224.27 826 224.39 94 224.53 17.3 224.64 5.5 224.78 33.7 224.89 33.7 225 33.7 225.1 5.4 225.26 12 224.12 33.7
225.41 825 225.53 94 225.62 18 225.79 5.43 225.89 33.7 226.01 32.9 226.12 33.7 226.27 5.37 226.37 12 225.32 33.7
226.64 827 226.77 94 226.89 17.6 227.01 5.56 227.12 33.7 227.27 33.7 227.38 33.7 227.53 5.4 227.62 12 226.53 33.7
227.87 826 228.03 94 228.13 17.6 228.28 5.59 228.37 33.7 228.51 33.7 228.62 33.7 228.77 5.4 228.88 12 227.76 33.7
229.12 824 229.26 94 229.37 17.6 229.52 5.56 229.64 33.7 229.77 33.7 229.88 33.7 230.02 5.4 230.14 12 229.02 33.7
230.38 825 230.52 94 230.62 18.4 230.76 5.56 230.87 33.7 231.03 34.1 231.13 33.7 231.27 5.43 231.37 14 230.28 33.7
231.62 826 231.77 94 231.88 18 232.02 5.5 232.12 33.7 232.26 33.7 232.37 33.7 232.52 5.4 232.64 14 231.51 33.7
232.88 826 233.02 94 233.12 18 233.28 5.5 233.39 33.7 233.52 33.7 233.62 33.7 233.76 5.4 233.87 12 232.77 33.7
234.13 823 234.28 94 234.37 21.2 234.51 5.46 234.62 15.3 234.77 17.6 234.88 19.2 235.02 8.65 235.12 22 234.03 33.7
235.37 1252 235.52 94 235.63 99.6 235.77 9.21 235.88 20 236.02 9 236.12 2.4 236.29 11.71 236.4 -10 235.26 34.9
236.62 1268 236.76 94 236.87 99.2 237.05 13.68 237.15 0 237.27 0 237.37 1.6 237.51 18.18 237.62 12 236.52 1.6
237.88 1887 238.02 94 238.14 71.8 238.27 18.12 238.37 43.5 238.52 47.5 238.64 47.8 238.78 14.37 238.88 12 237.77 9.8
239.14 1801 239.28 94 239.39 0 239.52 8.78 239.63 49.4 239.77 44.3 239.87 40.4 240.03 7.62 240.14 6 239.02 45.9
240.38 1181 240.52 94 240.62 91.4 240.77 10.68 240.89 22.7 241.02 24.7 241.14 32.5 241.27 9.78 241.37 20 240.27 26.7
241.64 1279 241.77 94 241.89 0 242.01 7.09 242.12 46.7 242.27 45.9 242.38 46.3 242.52 6.25 242.64 16 241.52 41.6
242.87 1122 243.03 94 243.13 12.9 243.27 5.71 243.39 43.9 243.53 23.9 243.64 21.6 243.78 5.15 243.88 2 242.77 46.3
244.14 1066 244.26 94 244.37 89 244.52 10.75 244.64 8.2 244.77 9 244.87 8.2 245.01 10.75 245.12 20 244.02 11.4
245.38 1218 245.53 94 245.64 98 245.79 11.75 245.9 23.9 246.02 24.7 246.13 26.7 246.27 11.59 246.38 18 245.28 14.5
246.62 1395 246.78 94 246.88 99.2 247.02 11.28 247.13 20 247.28 18.8 247.38 18 247.53 14.18 247.64 16 246.52 29
247.89 1642 248.03 94 248.13 96.1 248.28 15.84 248.38 36.9 248.53 40 248.62 40.4 248.76 16.18 248.87 16 247.78 14.1
249.13 1913 249.27 94 249.39 97.3 249.51 14.87 249.62 42 249.77 42.4 249.88 42.4 250.02 16.4 250.12 18 249.02 42.4
250.38 1846 250.54 94 250.65 0 250.77 9 250.87 57.6 251.01 59.6 251.12 51.4 251.27 7.65 251.38 4 250.27 54.9
251.62 1230 251.76 94 251.87 99.2 252.02 13 252.13 10.6 252.27 11.8 252.37 14.9 252.51 12.81 252.62 22 251.53 11.4
252.88 1295 253.03 94 253.12 64.3 253.26 7.81 253.37 49 253.52 51.8 253.63 50.2 253.77 7.84 253.89 22 252.77 32.5
254.12 1274 254.27 94 254.38 0 254.52 6.37 254.62 53.3 254.76 53.7 254.87 53.7 255.02 6.09 255.13 20 254.02 52.9
255.37 1204 255.51 94 255.62 0 255.77 6.15 255.88 56.1 256.02 56.1 256.12 56.1 256.26 5.62 256.37 18 255.28 54.5
256.63 1119 256.78 94 256.87 0 257.01 5.9 257.12 58 257.29 58.8 257.4 58.8 257.52 5.21 257.62 20 256.53 56.9
257.87 1050 258.02 94 258.14 20 258.28 5.46 258.39 65.5 258.53 68.2 258.63 69.4 258.78 4.53 258.89 10 257.76 60
259.14 996 259.27 94 259.37 62.7 259.53 5.25 259.63 49 259.77 48.2 259.89 48.6 260.01 5.28 260.12 4 259.03 64.3
260.38 888 260.53 94 260.62 23.9 260.76 5.21 260.87 46.7 261.04 46.7 261.15 46.7 261.27 5.28 261.37 12 260.27 46.7
261.62 896 261.79 94 261.9 1.6 262.02 5.21 262.12 52.2 262.27 52.9 262.38 55.7 262.53 5.34 262.63 20 261.52 46.7
262.87 1025 263.02 94 263.12 0 263.27 5.78 263.38 83.9 263.52 84.3 263.62 84.3 263.76 5.46 263.87 16 262.78 63.9
264.13 1216 264.27 94 264.38 0 264.52 6.12 264.62 84.3 264.77 83.5 264.88 84.3 265.02 5.34 265.12 16 264.02 84.3
265.37 1072 265.49 94 265.59 6.7 265.7 5.4 265.81 83.9 265.9 63.9 266.02 49 266.12 3.12 266.27 14 265.26 84.3
[code]Re: Polo 6R TDi EGR Issues - VCDS Log Available.
And the auto-scan
[code]
Monday,30,July,2018,11:16:05:02866
VCDS Version: https://protect-eu.mimecast.com/s/SEPECAnw2cNMYyqTGXZN6?domain=18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180212 DS287.0
https://protect-eu.mimecast.com/s/VMLJCBgx2u73oQ2T6M5rW?domain=ross-tech.com
VIN: WVWZZZ6RZCU026794 License Plate: HJ12 UNL
Mileage: 95740km-59490mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZCU026794 Mileage: 95740km-59490miles
56-Radio -- Status: OK 0000
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 A HW: 03P 907 425 A
Component: R3 1.2l TDI H07 9978
Revision: 11002001 Serial number:
Coding: 00114010000500080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TDI03103P906021A 001023
ROD: EV_ECM12TDI03103P906021.rod
VCID: 261406847867BE17284-8072
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 230224E3416F00B8C42C24EB82D500821300
Shop #: WSC 31414 790 31414
VCID: 074A6B009F6D871F332-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 323CEAD4442FD2B7B4C-8066
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 207110318
Coding: 3CB02BBF08A10000003008002D2B0CD00000410F60060000200000000000
Shop #: WSC 16862 123 104857
VCID: 45D6A108E5A1550F01E-8010
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU026071100013410
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU027071100015759
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU025071100014267
Coding: 08BC32
Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU009081100011473
Coding: 08BC32
Component: VW10Airbag027 H09 0020
Revision: -------- Serial number: 003GX00SKBAZ
Coding: 003237
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACC9234CC3FBA77ECC-801E
Serial number: 3575HRB40590OPI2DPI3
Serial number: 3585HRB40590OPI2B057
Serial number: 3515RRB40570L9U4FHU6
Serial number: 3525RRB40570L9U4E0OQ
Part No SW: 6R0 920 961 H HW: 6R0 920 961 H
Component: KOMBI H03 0505
Coding: 440A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 3B22C7F093E513FF67A-806E
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 002300
VCID: 70B820DC8AA3A0A7828-8024
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8C32B4ACFF5A77CCC-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660594521
Coding: 010000
VCID: 290E0DB869F9916F056-807C
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F3AE3A05E5DFF5FDB2-807A
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 032 0079
Revision: 01000001 Serial number: VWZ1Z2L3480362
Coding: 01000400020001
VCID: 3332EFD0BB35DBBFBFA-8066
End----------(Elapsed Time: 01:13, VBatt start/end: 12.3V/12.4V)-----------
Readiness Status: 00000000 00001110 11101000 00000000
MIL Status: MIL OFF
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Passed
Number of EOBD-related DTC(s): 0
[code]- iichel
Look pretty much OK to me, the car isn't complaining about EGR issues. Did you have the emissions update done?
PS, strange header in your VCDS with the mimecast referrer?
Mimecast is security software, indpendent to VCDS.iichel wrote: Wed Aug 01, 2018 6:06 pm Look pretty much OK to me, the car isn't complaining about EGR issues. Did you have the emissions update done?
The car had the emission fix done and then the EGR failed within months, VW replaced the EGR for free as it was a direct result of the fix. The car has done approx 6000-6200 miles since the new EGR and the car is starting to play up again.
Rough idle, Poor MPG, DPF regen is more frequent circa every 250 miles and it can be hesitant to pull off sometimes.
I presume the DPF regen to be a result of the EGR potentially sticking open and allowing constant flow through it causing excessive soot loading. These symptoms are similar to the previous EGR failure, but it wasn't until the valve went completely that it caused the EML light and limp mode to follow.
