Bixenon headlights with AFS For polo gt Tsi 2015
hmthakur
Drives: Polo gt tsi 1.2 dsg
Re: Bixenon headlights with AFS For polo gt Tsi 2015
Post by hmthakur »
New scan report
Saturday,18,August,2018,13:08:59:19846
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: MEXC15608FT079060 License Plate: MH-15-18-8-1
Mileage: 11730km-7288mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44
VIN: MEXC15608FT079060 Mileage: 11730km-7288miles
25-Immobilizer -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC
Cannot be reached
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 073170395
Coding: 3AB02BBF08A30000003800007C2B9C9000C0414F608C0000200000000000
Shop #: WSC 12345 123 12345
VCID: 2A0E0B13ECFBF1370F3-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 061216 04 42 0106
Coding: 008F77
Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5550
Serial number: 13202576141210080401
Coding: 010000
Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Serial number: 13202579141210182244
Coding: 010000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Serial number: 13202580141106012556
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581141125202458
Coding: 020000
9 Faults Found:
03429 - Activation of Right Adaptive Light
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 0
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 00:16:54
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 00:01:54
03432 - Activation of Right Parking Light
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 00:01:54
01179 - Incorrect Key Programming
000 - -
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 01:18:10
000 - -
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2018.08.18
Time: 00:00:00
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 40
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 01:56:17
00979 - Lamp for Low Beam; Right (M31)
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 01:56:13
01504 - Bulb for License-Plate Light (X)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 00:00:01
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 11
Reset counter: 40
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 00:00:00
Address 15: Airbags
Cannot be reached
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140800
Shop #: WSC 13202 938 00000
VCID: 47C852A75F292C5FF0D-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002300
VCID: 688AB11B32770327D97-803C
1 Fault Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2018.08.18
Time: 00:00:00
Address 25: Immobilizer
Cannot be reached
Address 44: Steering Assist
Cannot be reached
End----(Elapsed Time: 00:55, VBatt start/end: 11.4V/11.7V. VIgn 0.0V)------
hmthakur
Post by hmthakur »
Problem is right side bixenon remaining on without switch on
hmthakur
Post by hmthakur »
What number system to use when installing pins in red coupler?? Number system on coupler or that given in installation sheet??
Coupler has horizontal numbers 1-2 and in installation sheet its given vertical 1
2
Right side bixenon is remaining on even after removing coupler, relays , switch, it stays on even if key is removed.
hmthakur
Post by hmthakur »
attaching latest scan report
Saturday,18,August,2018,18:18:09:19846
www.Ross-Tech.com
VIN: MEXC15608FT07906123 License Plate: MH-15-18-18-4
Scan: 01 02 03 04 08 09 15 17 19 25 44 55
55-Headlight Range -- Status: Not registered 0011
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056232400080000
Shop #: WSC 00793 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
VCID: 6D84C00F1D15260FAA1-8038
Readiness: 0110 0101
Part No SW: 0AM 300 062 R HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6201
Revision: 00043014 Serial number: CU501412085377
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 3B203E571F6178BF645-806E
Part No SW: 6R0 907 379 BH HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422A03C94614246F4251C0800904
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 055498AF25A5FE4F421-8050
Serial number: 11121404651355
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA6F7434073AD9703B-802A
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 40DA49BB7A871B67317-8014
Coding: 008F77
Coding: 010000
Coding: 010000
Subsystem 4 - Part No SW: 13 202 579 14 HW: 132 025 791 41
Component: RLS 061216 04 42 2101
Serial number: ÿ132025791412101822
Coding: 323234
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Coding: 020000
5 Faults Found:
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 00:41:44
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 00:41:44
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 00:41:44
01502 - Bulb for Rear Fog; Left (L46)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 00:41:43
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 00:41:43
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00XAULG
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 49CC549F493DDA2FE69-801C
Coding: 140800
Revision: B9081001
Coding: 002300
1 Fault Found:
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 11731 km
Time Indication: 0
Date: 2018.08.18
Time: 00:41:43
Component: IMMO H05 0805
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8ECB132CFB3137CF3-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 41DC4CBF710D126F3E9-8014
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
Shop #: WSC 00788 648 00255
VCID: 77A8E2676F499CDF40D-8022
1 Fault Found:
5256725 - Rear Vehicle Height/Level Sensor
C114E 15 [137] - Open or Short to Plus
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 11731 km
Date: 2018.08.18
Time: 00:41:45
End----------(Elapsed Time: 01:11, VBatt start/end: 13.7V/13.8V)-----------
right side bixenon is staying on without key inserted, removed all relays, couplers, even then the right side bixenon stays on, goes of once bridge in j331 is removed.unable to adapt remote
I'm not sure about your lighting related questions, might be a wiring issue.
but you could go to 19 CAN gateway --> Installation list --> tick 55 Xenon Range.
I suppose your sensor on the rear axle isn't connected yet?
For Xenon, I'd probably code it something like this: 3AB02BBF08A30000003800017C2B9C905AC0672F600D104020A000000000
But I think ciclo is better at this than I am.
hmthakur
Post by hmthakur »
Having problem with adaptation of remote
This is the procedure for matching remote: http://wiki.ross-tech.com/wiki/index.ph ... l_Matching
Note, before starting:
I think I remember that you received my wiring in January or February of this year.
Today is:
Saturday-Sunday. August. Holidays and weekend ... good time for anyone who does not have to work. :|
Thank you.
hmthakur wrote: Sat Aug 18, 2018 8:56 am Problem is right side bixenon remaining on without switch on
https://uk-polos.net/viewtopic.php?f=56 ... 45#p530221
hmthakur wrote: Sat Aug 18, 2018 2:43 pm What number system to use when installing pins in red coupler?? Number system on coupler or that given in installation sheet??
2
If in the installation guide it is indicated in vertical (with drawing), it is vertical. As simple as that.
There is no other possible interpretation. In vertical facilitates the wires installation and prevents possible mistakes.
hmthakur wrote: Sat Aug 18, 2018 6:45 pm attaching latest scan report
Why are you doing this? Where is it indicated that you do these things?
Your New BCM must be coded correctly.
VCDS
You must faithfully follow all instructions provided on this Ross-tech page. :arrow: http://wiki.ross-tech.com/wiki/index.ph ... eplacement
(indicated in the sale of the wiring)
BCM coding
Do not follow the instructions indicated by other users of the forum that meddle in matters that do not concern them. (because I have to review what these users have written, wasting my time)
You have to tell me exactly and with exquisite precision which parts and cables you have installed and which ones you have not installed.
Then I will provide you with the new coding of your new BCM.
iichel please, do the favor of creating something that has not been done previously by others and stop bothering in the sales of my wiring, I've told you a million times. THANK YOU.
hmthakur wrote: Sat Aug 18, 2018 7:18 pm Sent from my iPhone using Tapatalk
Damn smartphones. (as I said on one occasion)
hmthakur
Post by hmthakur »
Cicolo sorry to bother you on holidays and vacation
Installation part list
1) bixenon headligth valeo (used) L:-6R2 941 031D, r:-6R2 941 032D
2) BCm:-7E0937090B
2) RLS Sensor :-5K7 955 559 C
3) auto dimming mirror 3GO 857 511 AC 9B9
4) auto headlight switch 5ND 941 431 E XSH
5) auto dimmer sent by you
6) AFS module unit:- 6R0 907 357
8) AFs Senosr :-6R0 941 273 B
9) TPMS Receiver:-3AA 907273F
wiring
Headlights T10 to T14 from Carsystems
Bcm Wiring provided by you
auto headlight wiring provided by you
fuse exetension loom
rear number plate loom
RLS + auto dimming wiring
wire loom for AFS From Carsystems
Wire loom for Tpms from Aliexpress
wiring installed as per instructions given by you.
Afs Wiring installed as per instructions given by car systems
red cable to sb 5
black cable ground
orange cable can high installed to isolated cable near IC (as per car system can gateway pin 16)
brown cable can low installed to isolated cable near IC (as per car system can gateway pin 6)
left headlight
yellow cable-pin1 headlight connector T-14
violet cable:-pin-4 headlight connector t-14
gray cable:pin:-2 headlight connector t14
brown cable pin no-3 headlight connector t14
right headlight
white cable:- pin-1 headlight connector t14
green cable :-pin-4 headlight connector t 14
orange cable pin-2 headligth connector t14
red cable pin-3 headlight connector t14
tpms wiring done as per below pic
after whole installation and wiring
installed bcm
connected vcds
disabled factory mode
copied can gateway code coding was accepted
copied central electronics long code coding was accepted
did the selection of installation list as per previous installation
did the procedure for remote adaptation as per ross-tech. after selection of test and pressing unlock key nothing happens and save option is not highlighted.Remote is Not getting adapted
problems
right side bixenon headlight is remaining on as soon as battery is pluged, even if key is not inserted.
Have installed wires in read coupler as per you instruction was just confirming by asking about numbering
tried to disconnecting switch from coupler , removed relays from loom provided by you but right headlight doesnt switch of.
head light switched of after removing bridge from j331.
two pins of parking light have to be installed.
scan report is as per my old long coding in coding helper.
hmthakur
Post by hmthakur »
headlight problem is due to coding or should i check the wiring again??
or am i installing the bridge incorrectly
OK, thanks.
Remote Control Matching, once you enter 0 in the new value you have to save and then press and hold the unlock button.
Remember that the new value for all remote controls must be '0'. It is the same process for all remote controls.
In a couple of hours (asap) I send you the new codings for the new BCM and the new RLS.
ASAP.
hmthakur wrote: Sun Aug 19, 2018 8:01 am headlight problem is due to coding or should i check the wiring again??
Coding.
I see that you have edited the previous post.
The new installed BCM, is it brand new or is it used?
Channel 000: Remote Control Clearing
http://wiki.ross-tech.com/wiki/index.ph ... l_Clearing
Channel 001: Remote Control Matching ... 0, test, save, press unlock button...
hmthakur
Post by hmthakur »
ciclo wrote: Sun Aug 19, 2018 8:19 am I see that you have edited the previous post.
My Bcm is brand new sent by firegrafik
hmthakur
Post by hmthakur »
