RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
smg_shardul wrote: Sun Aug 26, 2018 8:42 am
2 Faults Found
03428 - Activation of Left Adaptive Light
006 - Short to Plus - Intermittent
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 141
Mileage: 89193 km
Time Indication: 0
Date: 2015.14.31
Time: 00:16:07
03429 - Activation of Right Adaptive Light
Fault Priority: 3
Fault Frequency: 20
Reset counter: 141
Mileage: 89053 km
Time Indication: 0
Date: 2015.14.28
Time: 16:41:50
1. Cornering lights (intermittent faults - Clear all DTCs)
- Install the wiring correctly.
https://drive.google.com/file/d/0B2nv91 ... sp=sharing
- It is not possible to use low consumption LED bulbs for cornering lights.
Apart:
2. The weird behavior of the rear fog lamp with the light switch in side lights
Try this new coding and tell us the result (and post a new autoscan with the next coding) :
3A904BBF48E30200013807916CCB96905A88656F604D39C1200000030000
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
ciclo wrote: Mon Aug 27, 2018 2:55 am
2 Faults Found
Fault Priority: 3
Fault Frequency: 1
Reset counter: 141
Mileage: 89193 km
Time Indication: 0
Date: 2015.14.31
Time: 00:16:07
Fault Priority: 3
Fault Frequency: 20
Reset counter: 141
Mileage: 89053 km
Time Indication: 0
Date: 2015.14.28
Time: 16:41:50
Apart:
Yes i have installed LED in cornering lamps
changed the coding as per above instructions what chages are expected after changing to new coding ?
here is the latest scanned report.
Friday,31,August,2018,17:54:09:57843
VCDS Version: 18.2.1.2 (x64)
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: MEXA16608GT067313 License Plate:
Mileage: 89920km-55873mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56
VIN: MEXA16608GT067313 Mileage: 89920km-55873miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWXB) Labels: None
Part No SW: 03L 906 023 SN HW: 03L 907 425 B
Component: R4 1.5l TDI H33 9977
Revision: --H33--- Serial number: 00000000000000
Coding: 00250116032500080000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_ECM15TDI02130L906023SN 001001
ROD: N/A
VCID: 0407F47A8FFAEC6403-8050
No ASAM data for: "EV_ECM15TDI02130L906023SN" (VW25)
Readiness: 0 0 0 0 1
Part No SW: 0AM 300 065 L HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6560
Revision: 00043014 Serial number: CU501510066015
Coding: 0000020
Shop #: WSC 28939 002 1048576
VCID: 387F508A4BB27884DF-806C
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2C63422907C74617346A4254E0820909
ASAM Dataset: EV_Brak1eESP90iBOSCH 003031
ROD: N/A
VCID: 0B15DF46A2A4A31C42-805E
No ASAM data for: "EV_Brak1eESP90iBOSCH" (VW25)
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Serial number: 26071513471359
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLVOW25X 005001
ROD: N/A
VCID: 7EF38692E11686B455-802A
No ASAM data for: "EV_LWSKLVOW25X" (VW25)
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41893D6ED868394C68-8014
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 173171271
Coding: 3A904BBF48E30200013807916CCB96905A88676F600D30C1200000030000
VCID: 2B557FC64AE4C31CA2-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 080617 04 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 CC HW: 6R0 959 802 CC Labels: 6R0-959-802.CLB
Component: ------------- 007 5521
Serial number: 13102670151005153008
Coding: 050000
Subsystem 3 - Part No SW: 6R0 959 801 BT HW: 6R0 959 801 BT Labels: 6R0-959-801.CLB
Serial number: 13202671151005132525
Coding: 050000
Subsystem 4 - Part No SW: 5TA 959 442 HW: 5TA 959 442
Serial number: 2991519341401746AJ2B
Coding: 250000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5520
Serial number: 13202580151005230949
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13102581150929004312
Coding: 020000
Address 10: Park/Steer Assist
Cannot be reached
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW0121NNF
Coding: 003036
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_AirbaWV10BPAVW A01001
ROD: N/A
VCID: 4999254EE858F10CB0-801C
No ASAM data for: "EV_AirbaWV10BPAVW" (VW25)
Part No SW: 6JA 920 840 A HW: 6JA 920 840 A
Component: KOMBI H15 0605
Coding: 140A01
Shop #: WSC 07053 266 104857
VCID: 3979558EB8B8618C20-806C
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 102300
VCID: 68DFC0CA9B9228048F-803C
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H15 0605
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_Mimo_UDS_VDD_RM09 A03709
ROD: N/A
VCID: 6ADBBAC28D9E1A1499-803E
No ASAM data for: "EV_Mimo_UDS_VDD_RM09" (VW36 *)
Address 44: Steering Assist (J500) Labels:. 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ASAM Dataset: EV_SteerAsissNSK 014008
ROD: N/A
VCID: 41893D6ED068394C68-8014
No ASAM data for: "EV_SteerAsissNSK" (VW25)
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5314
Revision: -------- Serial number: VWZZZ4H6283197
Coding: 16000400040005
Shop #: WSC 00078 790 00102
VCID: 46832E72F1461E745D-8012
End-------------------------(Elapsed Time: 02:47)--------------------------
sshakthi123
Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Post by sshakthi123 »
firegrafik wrote: Tue May 15, 2018 6:32 am
smg_shardul wrote: Mon May 14, 2018 8:59 pm
Hey ciclo , firegraphics will this module support to my vw polo sedan ?
My car is with ABS & ESP I heard there is little bit change in with ESP and without ESP
It's parametrization depends not only for ABS or ESP.
The same control unit used on T6 and other models so it could have non-Polo parametrization.
VagCanPro is able to load the any parametrization for this AFS unit. If MaDwArLoCk could load the parametrization you need I think his offer is good.
Hi firegrafik, lichel, antardaksh04
I'm from India owning Vento (Polo sedan) 2017 model comes with a BCM 6R0 937 085 R and I would like to update the BCM and few other options. Can you help me sourcing the BCM and other parts. As said by multiple users from India, it is impossible to get the parts here. So expecting your help to source the required parts.
I have following in my mind to upgrade.
1. BCM Max
2. No headlight upgrade as of now. I will alive with H7 headlights for some more time
3. Auto light switch (my car has Rain sensor with dimming mirror already)
4. CH, LH
5. Dimming of interior lights along with manual headlight adjuster present
6. Stalk - single side parking
7. DRL sourcing beside fog lights as said here viewtopic.php?f=56&t=69687&start=30#p524168
Thanks in advance,
Sakthi
smg_shardul
Drives: Polo 6R
sshakthi123 wrote: Tue Oct 30, 2018 11:22 am
1. BCM Max
4. CH, LH
Thanks in advance,
Sakthi
First request ciclo to source the wiring for BCM Adaption without his wires adapting BCM is very difficult.
Sourcing a parts won't be an issue firegraphics will help you in that.
Your all above requirements will get fulfilled by ciclos wires.
sshakthi123
smg_shardul wrote: Tue Oct 30, 2018 12:19 pm First request ciclo to source the wiring for BCM Adaption without his wires adapting BCM is very difficult.
Yea, I already requested ciclo and he may help out sometime in January.
ciclo wrote: Mon Oct 29, 2018 6:35 pm I will let you know.
Maybe I'll make these wiring looms again (exceptionally), in any case it will not be possible before January of next year.
I thought I can collect the parts required before that. So once ciclo finds sometime then I will get the wiring and proceed.
Thanks,
Sakthi
Jerryncg93
Drives: Volkswagen Vento 1.2 tsi
Post by Jerryncg93 »
ciclo wrote: Wed Sep 13, 2017 10:28 am Mirror - 3G0.857.511.АС 9В9 OK
The upper cover is 6С0.868.438 Impossible to know until you test it.
The lower case is 6С0.858.548 Impossible to know until you test it.
auto switch - 3С8941431А OK
ВСМ - 7E0937090C OK/ 7E0937090B OKwhichever available
RLS Sensor : 5K7 955 559B OK
Your wiring is made to 80%.
T3 RLS connector has to arrive to my VW dealer. Waiting for...
Where did you buy all these parts?
I am from Malaysia.
smg_shardul
Drives: Polo 6R
Jerryncg93 wrote: Mon Dec 03, 2018 8:59 am
I am from Malaysia.
Contact Firegraphics
Jerryncg93
Hi guys, I'm from Malaysia.
I've recently purchased a set of rain light sensor,
Sensor - 5K7 955 547
Auto-headlight switch - 5ND 941 431B
Hardness as attached below.
BCM - 7E0 937 089A
Currently i have followed seller's instruction to tap the purple cable to BCM White bracket connector, pin 24.
However, it was occupied, seller's instructed to cut an opening at cable pin24, and tap the purple color hardness to it.
I have followed, but unfortunately the original hardness was broken during the process, so i uses the purchased hardness pin to plug into the pin 24, and tap the original purple and white cable to it. Then I try to starts the car, but was unable to start, engine lights came out.
Latest situation is i unplugged the pin 24, and some functions like plate number lights, headlight switch, anti-theft functions are off.
Any advice please?
And also I have no idea how and which port in fuse box to tap into. (Red color hardness)
Please advice guys. :cry:
Jerryncg93
So I just plug the red cable into this pin hole ya?
Also, do you have any advice on the previous issue I've encountered?
Jerryncg93 wrote: Mon Jun 17, 2019 7:29 am So I just plug the red cable into this pin hole ya?
Hmm... red/black wire?... yes.
It would be perfect if you add a fuse. (e.g., 5A)
Jerryncg93 wrote: Mon Jun 17, 2019 7:29 am Also, do you have any advice on the previous issue I've encountered?
Make a good splice of the wires for the LIN. (purple wire with original violet/white wire)
All the problems mentioned are directly related to this LIN/wire, T73b/24 . (RLHS, alarm sensors)
Jerryncg93
Can I use 7.5A?
yes
MikeNL
Drives: 6R 1.6 TDI
Post by MikeNL »
ciclo wrote: Mon Jun 17, 2019 6:23 pmyes
Sorry to ask it this way but I couldn't PM you, can you PM me sir? :)
Tell me what you want here. I'll be happy to help you.
