tick over speed 9n3 1.416v poss to low
Uncle Fester
Drives: 2005 9n3 1.4 16v
Post by Uncle Fester »
Hi all
any idea what tick over speed should be on 2005 9n3 1.4 16v petrol ,
its on about 700 when warmed up , if to low is there a adjuster screw :D
Re: tick over speed 9n3 1.416v poss to low
That sounds to be okay, there is no simple way to set up or alter the tick over speed like in a carb, it would need to be carried out using something like VCDS and then changing a field value.
Uncle Fester
Thanks bud :)
bvs
Drives: 02 1.4s 16v
Post by bvs »
Does not sound too bad - I will try to remember to check ours the next time I drive it.
littlepolo
Post by littlepolo »
Sounds about right to me too. Cannot recall what mine is exactly but think it's somewhere around 650-700 once warmed up.
alexperkins
Site Admin
Post by alexperkins »
700 sounds correct to me
bvs
Drives: 02 1.4s 16v
Post by bvs »
I guess it varies a little with engine type,ours is an AUB,this picture taken today.
This is a link to a thread on the skoda forum - I have not read it all but Wino posted this list of engine codes and idle speeds,assuming they are similar to polo specs.
https://www.briskoda.net/forums/topic/4 ... ridle-rpm/
littlepolo
Ah, my BBY is an auto box which might explain the slightly lower tickover.
bvs
Drives: 02 1.4s 16v
Post by bvs »
I would imagine that a lower idle speed on an Auto is quite desirable - cuts down on the 'Thump' and 'Creep' when drive is selected.
