In which slot should i put SB44b to convert this wire loom to +15 switching off through ignition??
Thanks master [emoji1303]ciclo wrote:
hi hmthakurhmthakur wrote: Mon Jan 01, 2018 2:54 pm master ciclo,
will this receiver and valve sensors work with tpms of my car.
IC software = 0705 or higher
BCM = 7E0 937 090B or higher
TPMS unit = 3AA 907 273 F
Sensors/valves = 3AA 907 275 F
have installed gti cluster 6RD920870A, ic software:-0805
Already posted latest vcds scan
Thank you so much for the replyciclo wrote: Fri Jan 18, 2019 9:19 pm I also have the A model installed, it has the updated software (which is better in case of future retrofits), works wonderfully once it's adapted.
The Gannu thread warns you of everything you need to know.
Understood, person I am purchasing it from had done this earlier from his contacts at VW service center, so that should take are of it.hmthakur wrote: Sat Jan 19, 2019 6:37 am Hi blueeyes
Sourcing gti cluster is not a problem but for installation you would have to go to VW service centre.
Even I had sourced one from China through Taobao. Got it installed in Vw service.
I will patiently wait for his response before commiting to this project. Unless it involves BCM upgrade I definitely want to get it done.As per my knowledge you can activate TPMS with existing bcm and upgrading to gti cluster, just check that cluster has software 0805. Master cicolo could answer it correctly.
I will try my luck with other vendors and keep looking up online.I had got my steering from GCP Tunning. It seems their website doesn’t work any more. So can’t help you their.
