Power steering fluid
Craig 6r
Drives: 6r polo 1.4 gti
Post by Craig 6r »
Hi. I’m trying to find out which power steering fluid goes in my car..polo 6r gti...thanks
Re: Power steering fluid
Any power steering fluid will do, really
https://www.autodoc.co.uk/car-parts/pow ... 91-1-4-gti
As you should not need to top up much, I’d stick with VW Group sourced stuff.
I know that you are not asking this question, but that system should not need topped up, it may look like it it is low, but as long as it touches/wets the base of the built in dip stick then it is okay.
veteran
Post by veteran »
RUM4MO,
My understanding was that on 6C's there simply isn't a steering fluid to top up, as the steering drive is supposed to be all-electric. Thus I can't figure out why the OP and all other respondents are inferring that a steering fluid reservoir exists on the 6C GTI. Have I been labouring under a misapprehension?
veteran wrote: Sat Jan 26, 2019 9:13 pm RUM4MO,
You are indeed correct saying that the 6C has a full electromechanical power steering. However, OP is referring to a 1.4 TSI (twincharged) 6R GTI, which has an electrohydraulich system (the horrible whine from the engine bay when moving the steering wheel when standing still comes from there).
veteran
Post by veteran »
Oops, my mistake! I didn't look close enough at the OP's vehicle description.
Craig 6r
Post by Craig 6r »
Thank you for the help.. i went to vw and bought some fluid.. it was only £11.36
