Power steering fluid
Craig 6r
- Drives: 6r polo 1.4 gti
Hi. I’m trying to find out which power steering fluid goes in my car..polo 6r gti...thanks
Re: Power steering fluid
Any power steering fluid will do, really
https://www.autodoc.co.uk/car-parts/pow ... 91-1-4-gti
As you should not need to top up much, I’d stick with VW Group sourced stuff.
I know that you are not asking this question, but that system should not need topped up, it may look like it it is low, but as long as it touches/wets the base of the built in dip stick then it is okay.
veteran
RUM4MO,
My understanding was that on 6C's there simply isn't a steering fluid to top up, as the steering drive is supposed to be all-electric. Thus I can't figure out why the OP and all other respondents are inferring that a steering fluid reservoir exists on the 6C GTI. Have I been labouring under a misapprehension?
You are indeed correct saying that the 6C has a full electromechanical power steering. However, OP is referring to a 1.4 TSI (twincharged) 6R GTI, which has an electrohydraulich system (the horrible whine from the engine bay when moving the steering wheel when standing still comes from there).veteran wrote: Sat Jan 26, 2019 9:13 pm RUM4MO,
veteran
Oops, my mistake! I didn't look close enough at the OP's vehicle description.
Craig 6r
Thank you for the help.. i went to vw and bought some fluid.. it was only £11.36
