Ciclo, I have updated the latest coding you sent. And here are the observations,
ciclo wrote: ↑Tue Feb 19, 2019 5:03 pm
1. Auto close windows
It's still not working, but the comfort feature is all set.
2. CH/LH
Verified as you said. CH - semi auto, LH - both works. thanks.
3. It is very likely (99%) that your current WRMs don't have the right software for this function.
How do we make it work? windows not closing on rain / on lock.
5. What model of bulbs do you have installed? LED bulbs?
Osram LED 1141 1.2w bulbs
6. Make the basic setting (in the correct way). ABS unit (address 03).
- security access 40168
- basic setting
- steering wheel 0º (Meas.Blocks)
- G85 adjustment. ON/OFF/Next
The adjustment will not be confirmed in your car until you close the address 03.
I'm able to go in but the option steering wheel 0º (Meas.Blocks) is not found in the list. So unable to make these changes.
7. It's not possible. It is not a function for the
DRLs. They are
Day lights.
Ok
9. ???
No. You must drive with a minimum of lighting.
Ok
4,8 wait for a new BCM coding.
4 - It worked. I checked again. thanks.
8 - works. DRL goes off when the indicator is enabled. But I need an option to enable/disable this particular one. So need 2 set of codes, one with enabling it, other with disabling it. Please help.
So here is the updated list that is to be focused,
1. Auto close windows not working (kept the windows down and locked the car. It left the windows as it is though I set the one touch up and down already)
2. Auto close windows on detecting rain in running or in park mode NOT working
3. Central electronics errors for DRL bulbs
4. Steering angle sensor calibration error
5. DRL is NOT going off upon indicator (
pls provide coding for turning this on/off on enabling indicator. Based on my likes I will turn this on or off)
Find below the latest auto scan,
Wednesday,20,February,2019,08:02:58:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXJ1760XJT075118 License Plate: 8854
Mileage: 18080km-11234mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56
VIN: MEXJ1760XJT075118 Mileage: 18080km-11234miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWXC) Labels: None
Part No SW: 03L 906 023 RS HW: 03L 907 425 B
Component: R4 1.5l TDI H33 9977
Revision: --H33--- Serial number:
Coding: 00110116032500080000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_ECM15TDI02103L906023RS 001002
ROD: EV_ECM15TDI02103L906023QT.rod
VCID: 081F2E22B3333D0450-805C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 CA HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0004
Serial number: --------------
Coding: 60DD2F63212A04C50615F46A845920020000
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 7F0DB5FEE6FD7ABC61-802A
Serial number: 03111813470922
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF348FAE1F773B46A-802A
1 Fault Found:
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 18063 km
Date: 2015.05.30
Time: 14:12:49
Voltage terminal 15: 12.20 V
Voltage terminal 30: 12.40 V
Terminal 15 status: On
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 4189F306D889CC4C57-8014
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 222180856
Coding: 3B904BFF48A10000013806407CEB96904980610F608C21C1220000030000
Shop #: WSC 12345 123 12345
VCID: 2C57B2B24F0B312494-8078
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 290617 04 42 0106
Coding: 066800
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2521
Serial number: 13202848170704050535
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2521
Serial number: 13102849170705002249
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 1811713320101504AB1B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1522
Serial number: 13102728170704212031
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1522
Serial number: 13102729170630002341
3 Faults Found:
00901 - Back-Up Lamps
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 18063 km
Time Indication: 0
Date: 2015.05.30
Time: 14:21:31
02745 - Bulb for Daytime Running Light; Left
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 18063 km
Time Indication: 0
Date: 2015.05.30
Time: 14:12:53
02746 - Bulb for Daytime Running Light; Right
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 18063 km
Time Indication: 0
Date: 2015.05.30
Time: 14:12:53
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231325304021
Coding: 308002
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 3A7B84EABD5F9F9416-806E
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW01BGFS-
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4999EB26E8B9040C8F-801C
Part No SW: 6RF 920 862 B HW: 6RF 920 862 B
Component: KOMBI H01 0217
Coding: 1208000000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
VCID: 4B95D12EE2C5161CBD-801E
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 002300
VCID: 68DF0EA29B73DD04B0-803C
Component: IMMO H01 0217
Serial number:
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB74AA8D7FEF14A6-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 4189F306D089CC4C57-8014
Address 56: Radio (J503) Labels: None
Part No SW: 6RF 035 187 C HW: 6RF 035 187 C
Component: Radio 557 5515
Revision: -------- Serial number: VWZ7Z2R8103103
Coding: 0E000440000010
Shop #: WSC 12345 123 08192
VCID: 4999EB26E0B9040C8F-801C
End-------------------------(Elapsed Time: 02:30)--------------------------
