Waiting to be approved before publishing
![Cool 8)](./images/smilies/icon_cool.gif)
Patrik wrote: ↑Tue Oct 01, 2019 7:10 pm Nice Ciclo!
Some questions:
1. When you are talking about the wires i suppose you mean the ones added from headlight connectors to the BCM unit? Yes
2. Is it the same configuration that you explained earlier in this thread? (STEP 2) NO
3. Do i need the extra wires between the instrument cluster and the BCM for CAN lines? No
4. Is there somewhere i can buy the cables needed between headlight connectors and BCM? (like a kit) I do not know.
5. What do you mean by "parameterize your BCM 090B at a VW dealer" ?
For example:
To parameterize is to correct the already established values in the software.
To code is making them work or not.
There is a huge variety of BCMs Max for PQ25 that have different parameters depending on the factory equipments. (Bixenon, Halogen, etc)
Thank you![]()
Patrik wrote: ↑Wed Oct 02, 2019 2:57 am You are the man Ciclo.
Seems pretty much plug and play except for the extra cables for parking lights and additional coding.
More questions:
1. If I use your longcode do i still have to take the car to VW dealer for parameterizing?
Maybe, it depends on the results once you install all the components.
2. When i order my led modules, is it still a must to use this one: 4G0907697F ?
Yes, it must be that.
3. And for the xenon ballast does it matter if it's F or G ?
It must be F.
4. For the headlight itself the correct versions would be 2H1941017/18 correct? YES I have found bi xenon headlights for the amarok second hand but the seller marked them as 2H1941015/16AF.. As far i know this is the halogen ones YES , he must be wrong with the numbers? YES
IMHO, do not buy parts that are not perfectly defined in the sales announcement.
5. What does the extension AF really mean? Is it equipped with AFS maybe.. NO, it is not related. In that case could my amarok handle that?
Sorry for all the questions.
Hey folks !I have read all the topics about swaping the xenon head lights on my vw amarok 2012 model .Yesterday i boughtbeautiful LED headlights!
I'm in a similar process for our Golf.
All lights LEDs, interior & exterior.
