Retrofitting of Cruise Control by MFS on Polo 6R, T5, T6
Re: Retrofitting of Cruise Control by MFS on Polo 6R, T5, T6
I had a go with this, with the help of spacewalker. There is a MFSW module available for PQ35 (golf 6 platoform) but it was too hard to make the software work for our Polo platform (PQ25). I'm afraid it's a bridge too far at this point. I gave up and went for CC via the stalks again, even though I ended up having the stalks from a Polo AW :mrgreen:
Adam87
Drives: T5.2
Post by Adam87 »
Yes I have seen this module but the PQ35 cruise works by a different method, it needs to simulate a physical button press as opposed to a CAN signal.
What are the Polo stalks? I wanted to try and use some Mk7 golf stalks.
dnoermann
Drives: T5.2 and Polo 9N3
Post by dnoermann »
Short Update:
Fittet T6 ACC Radar on my T5.2
Nothing works :shock:
But:
- CP and SWAP for Radar are done
- Radar fittet
- Cluster changed
- ABS changed
- Airbag Controller changed
- Stalk changed
- Steering Wheel changed
- BCM changed
==> Only 1 Error in ACC and 1 Error in ABS when ACC is enabled
==> 0 Error with FrontAssist without ACC
FrontAssist is probably working, because with FrontAssist alone the ECU is not involved.
But with ACC enabled there is a CAN Message from ECU missing, or the message is to slow.
Need more digging.
dnoermann
Post by dnoermann »
Adam87 wrote: Tue Jan 01, 2019 10:10 pm Following with interest, I have a T5.1 (2015) with the aim to fit ACC, I have a T6 ABS unit with look and plug (which I think when I last checked only had a larger + wire), I have a radar, steering wheel with ACC buttons (already installed) and T6 BCM (already installed)
Adam, i finalised my ACC retrofit, contact me if you still like to retrofit your's.
dnoermann
Post by dnoermann »
ciclo wrote: Wed Oct 11, 2017 6:29 pm
iichel wrote: Wed Oct 11, 2017 4:18 pm ...The problem is probably my 1.2 TDI engine,..
yes, related to software for emissions ... Euro5 vs Euro6
Correct, i finally got this issue solved.
In PQ25 the adapter from Spacewalker is not working because the GRA CAN Messages are not been fransfered by the PQ25 Gateway.
I tried this and failed, like you, thanks to Spacewalker for helping.
So back to the major problem, the Bosch EU5 ECU's can not work with the new behaviour of MFSW GRA behaviour.
Even if correct installed together with newer T6 BCM, the ECU is claiming one Error:
4481 - Cruise Control Switch (E45)
          P0568 00 [039] - Implausible Signal
So some check algo inside ECU which is doing a two Channel check between GRA Signal and GRA Can Messages is detecting a fault here.
I looked deep into ECU firmware of my EDC17CP20 and was abel to find the configuration which disables this check.
Finally MFSW is working :D
Proof: Working ACC with EDC17CP20 and MFSW https://www.youtube.com/watch?v=k4CxAbFDsEE
I would assume this fix can be done to any EU5 EDC17xxxx with some effort of finding the right Byte and patching it.
I needed this for my ACC retrofit, but i would assume that normal GRA will now work too.
So:
- If you have the newer BCM from the T6
- and if you are able to read/write your ECU Firmware
- and if you know what a2l Files are
than you can now start patching it.
Just change CrC_swtMainSwtHWEna_C from 0x01 to 0x00
This information is shared free for all.
Greetings
poethardo
Drives: VW polo 1.2 TSI
Post by poethardo »
That a good news...btw what is your bcm? And how mich you buy adapter from spacewalker ? May you share your wiring diagram ?
dnoermann wrote: Sat Oct 05, 2019 11:38 am So some check algo inside ECU which is doing a two Channel check between GRA Signal and GRA Can Messages is detecting a fault here.
So:
Greetings
Congratulations! :D, especially for the research work you have done. 8)
Thank you very much for sharing the information.
PQ25
From Stalk GRA to MFSW GRA in EDC17CP20 CFCA (a2l - CrC_swtMainSwtHWEna_C from 0x01 to 0x00)
Can you share the Offset in your ECU BIN file? (for those without ECU programs :))
dnoermann
Post by dnoermann »
Search for CE FF FF 00 01 01 the last 01 is CrC_swtMainSwtHWEna_C
Super!, thanks a lot.
MaDwArLoCk
Drives: Cross Polo 2010 TSI
Post by MaDwArLoCk »
So:
Greetings
Bravo!!! 👏
That’s a great retrofit!
Could you please post your current autoscan?
And why have you changed Airbag controller? How it’s related to ACC?
dnoermann
Post by dnoermann »
Airbag Controller is needed by ABS/ESP. I dont really know why, i think it is because of new Feature "Multicollision Breake"
Here is an Autoscan.
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 18 19 22 25 2E 37 3C 55 56 61
          69 6C 6E 77 0B
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 019 HM    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 8375
   Revision: 22H38---    Serial number: 00000000000000
   Coding: 0125401A237601080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM20BTD01103L906019HM 003005
   ROD: EV_ECM20BTD_003.rod
   VCID: 7DA60C6E3D71329FA11-8028
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0BT 300 011 Q    HW: 0BH 927 711 G
   Component: DSG DQ500-7A  H11 2236
   Revision: 00H11V01
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 3C20C16A66EBFB97D6F-8068
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 43036000000361
   Coding: 307E809865__86__0C__01__A6__619378F700
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 40D8B59A0A039F778A7-8014
   Serial number: 17041713470217
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA40B6230772987B8B-802A
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E5 907 040 AC    HW: 7E5 907 040 AC
   Component: ClimatronicT5 H19 0407
   Revision: 00001004
   Coding: 0000000103
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 698E483E59F9BE3F7D9-803C
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
   Component: Heckbedienung  H10 0202
   Serial number: BHB-0010710130015098
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 088181300
   Coding: E0A0393A0A21201301280E716EAB8FD50094660060857851320000020040
   VCID: 2B02F23693056C2F4F5-807E
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 071013 05  54  0403
   Coding: 02252E
   Subsystem 2 - Part No SW: 7E0 959 801 J    HW: 7E0 959 801 J  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8652
   Serial number: KU0KU008101300018609
   Coding: 0400A1
   Subsystem 3 - Part No SW: 7E0 959 802 J    HW: 7E0 959 802 J  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8652
   Serial number: KU0KU002101300011203
   Coding: 1400A1
   Subsystem 4 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29150002355190075477
   Coding: B4FFFF
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28261326801945
   Coding: 318102
   VCID: 3B22C27663E5FCAFDF5-806E
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 08021577030385
   Coding: 00005800FE0779
   Shop #: WSC 46011 002 1048576
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 3634D34258C721C720B-8062
   Part No SW: 7E0 959 655 H    HW: 7E0 959 655 H
   Component: VW10Airbag01S H08 0018
   Revision: --------    Serial number: 003V40042CZ5
   Coding: 000000000000000000000000000000003153
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750_VW12.rod
   Serial number: 3495ZRB400250KJKP1GY
   Serial number: 3505ZRB400450KJKN9O%
   Part No SW: 7E0 920 871 A    HW: 7E0 920 871 A
   Component: KOMBI         H02 2030
   Coding: 150F010300
   Shop #: WSC 00012 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   VCID: 28080D3A82734737A27-807C
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 819 008 F
   Component: J737__Standheizung  0605
   Revision: 00086000    Serial number: 09024901A00000
   Coding: 0021332
   Shop #: WSC 02757 790 00000
   VCID: 2C00F12A9A0B6B1746F-8078
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042200
   VCID: 68884D3A42738737627-803C
Address 22: AWD        Labels: 0AY-907-554-V1.clb
   Part No SW: 09N 907 554 B    HW: 09N 907 554 B
   Component: Haldex 4Motion      6008
   Coding: 0000001
   Shop #: WSC 02756 790 00000
   VCID: 372ADE46534DD8CF3BD-8062
   Component: IMMO          H02 2030
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8C37325CFFB527743-803E
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7665304253
   Coding: 010100
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 7E0 035 680 B    HW: 7E0 035 680 B
   Component: RNS-MID       H09 5274
   Revision: AB001001    Serial number: VWZ6Z7N7280058
   Coding: 04000402040000A00014
   Shop #: WSC 02754 790 00000
   VCID: 2410190AFEDBA3578EF-8070
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V16  8536
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH13 0120
   Revision: 00H13000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   VCID: 2F3AE626AB1D100F63D-807A
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H10 0120
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F26.09.1300H10000AMS14437ÿ
   Subsystem 4 - Serial number: S14437ÿ
   Revision: --------    Serial number: --------------
   Coding: 028A000001000000
   Shop #: WSC 02757 790 50316
   VCID: 77AA1E461F4D18CFFBD-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 330B1A73
   Shop #: WSC 02762 790 12345
   Subsystem 1 - Part No SW: 7E0 915 181 D    HW: 7E0 915 181 D
   Component: J367-BDM  H08 0182
   Serial number: 50262E43111931975854
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Anhaenger     H10 0110
   Revision: 3B001001    Serial number: 00000194554106
   Coding: 410D000101000000
   VCID: 313EE05EB12906FF759-8064
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H12000    Serial number: 525PA8-J390101
   Coding: 0030015
   Shop #: WSC 18342 003 1048576
   VCID: 6596440EB9619A5F591-8030
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
   Component: Dachdisplay   H15 0185
   Revision: 10100011    Serial number: 308907
   Coding: 000203
   VCID: 3536D44E45412ADF291-8060
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0971
   Revision: --------    Serial number: 35502105055314
   Coding: 020101000100000000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 2410190AFE5BA3578EF-8070
MaDwArLoCk
dnoermann wrote: Mon Oct 07, 2019 6:29 pm Airbag Controller is needed by ABS/ESP. I dont really know why, i think it is because of new Feature "Multicollision Breake"
          69 6C 6E 77 0B
   Revision: 00H11V01
   Coding: 0014
   Coding: 01
   Revision: 00001004
   Coding: 0000000103
   Slave 1:
   Coding: 02252E
   Coding: 0400A1
   Coding: 1400A1
   Coding: B4FFFF
   Coding: 318102
   Coding: 150F010300
   Coding: 0021332
   Revision: B9082001
   Coding: 042200
   Coding: 0000001
   Serial number:
   Coding: 010100
   Coding: 0010161
   Coding: 330B1A73
   Coding: 0030015
   Coding: 000203
Thank you very much for the autoscan!
You have nice T5: 4WD + DSG and now ACC 👍
So there was fault in your ABS unit about Airbag controller?
I have bought ACC radar from T6 for my experiments))😄
But for 6R it looks more complicated...
dnoermann
Post by dnoermann »
MaDwArLoCk wrote: Tue Oct 08, 2019 9:26 am You have nice T5: 4WD + DSG and now ACC 👍
Thx.
Correct, the Error in ABS with wrong Airbag Controller was:
8229 - Databus
U1121 00 [009] - Missing Message
[ACAN: Airbag_03 frame timeout]
Well since 6R is PQ25, it is possible too, but if you run into the same issue with Airbag Controller, than it will be more complicated because T6 Airbag controller is for shure no fit for a Polo ....
But you only run into this issue while retrofiting the T6 ABS/ESP and this is for shure no fit for a Polo, too ....
          69 6C 6E 77 0B
   Revision: 00H11V01
   Coding: 0014
   Coding: 01
   Revision: 00001004
   Coding: 0000000103
   Slave 1:
   Coding: 02252E
   Coding: 0400A1
   Coding: 1400A1
   Coding: B4FFFF
   Coding: 318102
   Coding: 150F010300
   Coding: 0021332
   Revision: B9082001
   Coding: 042200
   Coding: 0000001
   Serial number:
   Coding: 010100
   Coding: 0010161
   Coding: 330B1A73
   Coding: 0030015
   Coding: 000203
Coding: 0400A1
Coding: 1400A1
BTW, with these WRMs it is possible to get the automatic folding mirrors if you want to expand the great equipment of your Super T5.
Byte02 = A3 HEX in your case.
* Mirrors with folding motors and new wires are necessary if you do not have factory folding mirrors (by Button / Knob - manual function).
MKE ---> viewtopic.php?f=56&t=58703&start=4710#p556790
dnoermann
Post by dnoermann »
ciclo wrote: Tue Oct 08, 2019 8:07 pm BTW, with these WRMs it is possible to get the automatic folding mirrors if you want to expand the great equipment of your Super T5.
Thx, i will try it.
