Retrofitting of Cruise Control by MFS on Polo 6R, T5, T6
Re: Retrofitting of Cruise Control by MFS on Polo 6R, T5, T6
I had a go with this, with the help of spacewalker. There is a MFSW module available for PQ35 (golf 6 platoform) but it was too hard to make the software work for our Polo platform (PQ25). I'm afraid it's a bridge too far at this point. I gave up and went for CC via the stalks again, even though I ended up having the stalks from a Polo AW
Yes I have seen this module but the PQ35 cruise works by a different method, it needs to simulate a physical button press as opposed to a CAN signal.
What are the Polo stalks? I wanted to try and use some Mk7 golf stalks.
- Drives: T5.2 and Polo 9N3
Short Update:
Fittet T6 ACC Radar on my T5.2
Nothing works
But:
- CP and SWAP for Radar are done
- Radar fittet
- Cluster changed
- ABS changed
- Airbag Controller changed
- Stalk changed
- Steering Wheel changed
- BCM changed
==> Only 1 Error in ACC and 1 Error in ABS when ACC is enabled
==> 0 Error with FrontAssist without ACC
FrontAssist is probably working, because with FrontAssist alone the ECU is not involved.
But with ACC enabled there is a CAN Message from ECU missing, or the message is to slow.
Need more digging.
Nothing works
But:
- Radar fittet
- Cluster changed
- ABS changed
- Stalk changed
- BCM changed
Need more digging.
Adam, i finalised my ACC retrofit, contact me if you still like to retrofit your's.Adam87 wrote: ↑Tue Jan 01, 2019 10:10 pm Following with interest, I have a T5.1 (2015) with the aim to fit ACC, I have a T6 ABS unit with look and plug (which I think when I last checked only had a larger + wire), I have a radar, steering wheel with ACC buttons (already installed) and T6 BCM (already installed)
Correct, i finally got this issue solved.
In PQ25 the adapter from Spacewalker is not working because the GRA CAN Messages are not been fransfered by the PQ25 Gateway.
I tried this and failed, like you, thanks to Spacewalker for helping.
So back to the major problem, the Bosch EU5 ECU's can not work with the new behaviour of MFSW GRA behaviour.
Even if correct installed together with newer T6 BCM, the ECU is claiming one Error:
4481 - Cruise Control Switch (E45)
P0568 00 [039] - Implausible Signal
I looked deep into ECU firmware of my EDC17CP20 and was abel to find the configuration which disables this check.
Finally MFSW is working
Proof: Working ACC with EDC17CP20 and MFSW https://www.youtube.com/watch?v=k4CxAbFDsEE
I would assume this fix can be done to any EU5 EDC17xxxx with some effort of finding the right Byte and patching it.
I needed this for my ACC retrofit, but i would assume that normal GRA will now work too.
So:
- If you have the newer BCM from the T6
- and if you are able to read/write your ECU Firmware
- and if you know what a2l Files are
than you can now start patching it.
Just change CrC_swtMainSwtHWEna_C from 0x01 to 0x00
This information is shared free for all.
Greetings
- Drives: VW polo 1.2 TSI
That a good news...btw what is your bcm? And how mich you buy adapter from spacewalker ? May you share your wiring diagram ?
Congratulations! , especially for the research work you have done.dnoermann wrote: ↑Sat Oct 05, 2019 11:38 am So some check algo inside ECU which is doing a two Channel check between GRA Signal and GRA Can Messages is detecting a fault here.
So:
Greetings
Thank you very much for sharing the information.
PQ25
From Stalk GRA to MFSW GRA in EDC17CP20 CFCA (a2l - CrC_swtMainSwtHWEna_C from 0x01 to 0x00)
Can you share the Offset in your ECU BIN file? (for those without ECU programs )
Search for CE FF FF 00 01 01 the last 01 is CrC_swtMainSwtHWEna_C
Super!, thanks a lot.
- Drives: Cross Polo 2010 TSI
dnoermann wrote: ↑Sat Oct 05, 2019 11:38 amCorrect, i finally got this issue solved.
So some check algo inside ECU which is doing a two Channel check between GRA Signal and GRA Can Messages is detecting a fault here.Code: Select all
4481 - Cruise Control Switch (E45) P0568 00 [039] - Implausible Signal Not Confirmed - Tested Since Memory Clear
So:
Greetings
Bravo!!!
That’s a great retrofit!
Could you please post your current autoscan?
And why have you changed Airbag controller? How it’s related to ACC?
Airbag Controller is needed by ABS/ESP. I dont really know why, i think it is because of new Feature "Multicollision Breake"
Here is an Autoscan.
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 18 19 22 25 2E 37 3C 55 56 61
69 6C 6E 77 0B
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 019 HM HW: 03L 907 309 L
Component: R4 2,0L EDC H38 8375
Revision: 22H38--- Serial number: 00000000000000
Coding: 0125401A237601080000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ECM20BTD01103L906019HM 003005
ROD: EV_ECM20BTD_003.rod
VCID: 7DA60C6E3D71329FA11-8028
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 011 Q HW: 0BH 927 711 G
Component: DSG DQ500-7A H11 2236
Revision: 00H11V01
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_VW36.rod
VCID: 3C20C16A66EBFB97D6F-8068
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 Q HW: 7E0 907 379 N
Component: ESC H06 0133
Revision: 00000000 Serial number: 43036000000361
Coding: 307E809865__86__0C__01__A6__619378F700
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 40D8B59A0A039F778A7-8014
Serial number: 17041713470217
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA40B6230772987B8B-802A
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E5 907 040 AC HW: 7E5 907 040 AC
Component: ClimatronicT5 H19 0407
Revision: 00001004
Coding: 0000000103
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 698E483E59F9BE3F7D9-803C
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 B HW: 7E5 907 049 B
Component: Heckbedienung H10 0202
Serial number: BHB-0010710130015098
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 088181300
Coding: E0A0393A0A21201301280E716EAB8FD50094660060857851320000020040
VCID: 2B02F23693056C2F4F5-807E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 071013 05 54 0403
Coding: 02252E
Subsystem 2 - Part No SW: 7E0 959 801 J HW: 7E0 959 801 J Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8652
Serial number: KU0KU008101300018609
Coding: 0400A1
Subsystem 3 - Part No SW: 7E0 959 802 J HW: 7E0 959 802 J Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8652
Serial number: KU0KU002101300011203
Coding: 1400A1
Subsystem 4 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29150002355190075477
Coding: B4FFFF
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28261326801945
Coding: 318102
VCID: 3B22C27663E5FCAFDF5-806E
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 08021577030385
Coding: 00005800FE0779
Shop #: WSC 46011 002 1048576
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361_VW32.rod
VCID: 3634D34258C721C720B-8062
Part No SW: 7E0 959 655 H HW: 7E0 959 655 H
Component: VW10Airbag01S H08 0018
Revision: -------- Serial number: 003V40042CZ5
Coding: 000000000000000000000000000000003153
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750_VW12.rod
Serial number: 3495ZRB400250KJKP1GY
Serial number: 3505ZRB400450KJKN9O%
Part No SW: 7E0 920 871 A HW: 7E0 920 871 A
Component: KOMBI H02 2030
Coding: 150F010300
Shop #: WSC 00012 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
VCID: 28080D3A82734737A27-807C
Address 18: Aux. Heat Labels: None
Part No: 7E0 819 008 F
Component: J737__Standheizung 0605
Revision: 00086000 Serial number: 09024901A00000
Coding: 0021332
Shop #: WSC 02757 790 00000
VCID: 2C00F12A9A0B6B1746F-8078
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 042200
VCID: 68884D3A42738737627-803C
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 09N 907 554 B HW: 09N 907 554 B
Component: Haldex 4Motion 6008
Coding: 0000001
Shop #: WSC 02756 790 00000
VCID: 372ADE46534DD8CF3BD-8062
Component: IMMO H02 2030
Serial number:
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8C37325CFFB527743-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7665304253
Coding: 010100
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 7E0 035 680 B HW: 7E0 035 680 B
Component: RNS-MID H09 5274
Revision: AB001001 Serial number: VWZ6Z7N7280058
Coding: 04000402040000A00014
Shop #: WSC 02754 790 00000
VCID: 2410190AFEDBA3578EF-8070
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V16 8536
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 7E0 907 566 B HW: 4L0 907 566 A
Component: J0769 SWA MasterH13 0120
Revision: 00H13000 Serial number: 6PZ 009 014-07
Coding: 0010161
VCID: 2F3AE626AB1D100F63D-807A
Subsystem 1 - Part No: 7E0 907 568 B
Component: J0770 SWA Slave H10 0120
Subsystem 2 - Serial number: 6PZ 009 014-27
Subsystem 3 - Serial number: 5F26.09.1300H10000AMS14437ÿ
Subsystem 4 - Serial number: S14437ÿ
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 028A000001000000
Shop #: WSC 02757 790 50316
VCID: 77AA1E461F4D18CFFBD-8022
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 330B1A73
Shop #: WSC 02762 790 12345
Subsystem 1 - Part No SW: 7E0 915 181 D HW: 7E0 915 181 D
Component: J367-BDM H08 0182
Serial number: 50262E43111931975854
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 G HW: 1K0 907 383 G
Component: Anhaenger H10 0110
Revision: 3B001001 Serial number: 00000194554106
Coding: 410D000101000000
VCID: 313EE05EB12906FF759-8064
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7E0 907 441 HW: 7E0 907 441
Component: J772__Rearview 0040
Revision: 00H12000 Serial number: 525PA8-J390101
Coding: 0030015
Shop #: WSC 18342 003 1048576
VCID: 6596440EB9619A5F591-8030
Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-W2.clb
Part No SW: 7E5 919 037 G HW: 7E5 919 037 G
Component: Dachdisplay H15 0185
Revision: 10100011 Serial number: 308907
Coding: 000203
VCID: 3536D44E45412ADF291-8060
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0971
Revision: -------- Serial number: 35502105055314
Coding: 020101000100000000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi.rod
VCID: 2410190AFE5BA3578EF-8070
Thank you very much for the autoscan!dnoermann wrote: ↑Mon Oct 07, 2019 6:29 pm Airbag Controller is needed by ABS/ESP. I dont really know why, i think it is because of new Feature "Multicollision Breake"
Chassis Type: 7H-VN75 (7E0) Scan: 01 02 03 04 08 09 10 13 15 17 18 19 22 25 2E 37 3C 55 56 61 69 6C 6E 77 0B 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 18-Aux. Heat -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 37-Navigation -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6E-Ctrl Head Roof -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb Part No SW: 03L 906 019 HM HW: 03L 907 309 L Component: R4 2,0L EDC H38 8375 Revision: 22H38--- Serial number: 00000000000000 Coding: 0125401A237601080000 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_ECM20BTD01103L906019HM 003005 ROD: EV_ECM20BTD_003.rod VCID: 7DA60C6E3D71329FA11-8028 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb Part No SW: 0BT 300 011 Q HW: 0BH 927 711 G Component: DSG DQ500-7A H11 2236 Revision: 00H11V01 Coding: 0014 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMDQ500021 001001 ROD: EV_TCMDQ500021_VW36.rod VCID: 3C20C16A66EBFB97D6F-8068 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb Part No SW: 7E0 907 379 Q HW: 7E0 907 379 N Component: ESC H06 0133 Revision: 00000000 Serial number: 43036000000361 Coding: 307E809865__86__0C__01__A6__619378F700 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001 ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod VCID: 40D8B59A0A039F778A7-8014 No fault code found. ------------------------------------------------------------------------------- Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb Part No SW: 6R0 959 654 HW: 6R0 959 654 Component: LENKW.SENSOR H07 0070 Serial number: 17041713470217 Coding: 01 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_LWSKLOVW25X 005001 ROD: EV_LWSKLOVW25X.rod VCID: 7EA40B6230772987B8B-802A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb Part No SW: 7E5 907 040 AC HW: 7E5 907 040 AC Component: ClimatronicT5 H19 0407 Revision: 00001004 Coding: 0000000103 Shop #: WSC 02756 790 50316 ASAM Dataset: EV_ClimatronicT5 A01003 ROD: EV_ClimaAutoT5Basis.rod VCID: 698E483E59F9BE3F7D9-803C Slave 1: Subsystem 1 - Part No SW: 7E5 907 049 B HW: 7E5 907 049 B Component: Heckbedienung H10 0202 Serial number: BHB-0010710130015098 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 C HW: 7E0 937 090 C Component: BCM PQ25 Max4 H82 0752 Revision: B9082001 Serial number: 4000 088181300 Coding: E0A0393A0A21201301280E716EAB8FD50094660060857851320000020040 Shop #: WSC 12345 123 12345 VCID: 2B02F23693056C2F4F5-807E Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 071013 05 54 0403 Coding: 02252E Subsystem 2 - Part No SW: 7E0 959 801 J HW: 7E0 959 801 J Labels: 7E0-959-80X-V2.CLB Component: J386__TSG_FT 003 8652 Serial number: KU0KU008101300018609 Coding: 0400A1 Subsystem 3 - Part No SW: 7E0 959 802 J HW: 7E0 959 802 J Labels: 7E0-959-80X-V2.CLB Component: J387__TSG_BT 003 8652 Serial number: KU0KU002101300011203 Coding: 1400A1 Subsystem 4 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A Labels: 3C8-959-537.CLB Component: E221__MFL-DC1 H02 0103 Serial number: 29150002355190075477 Coding: B4FFFF No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb Part No SW: 7E0 919 475 L HW: 7N0 919 475 Component: PARKHILFE 8K H06 0106 Revision: -------- Serial number: 28261326801945 Coding: 318102 Shop #: WSC 02756 790 50316 ASAM Dataset: EV_VW75XParkAssis8K 001003 ROD: EV_VW75XParkAssis8K_001_VN75.rod VCID: 3B22C27663E5FCAFDF5-806E No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb Part No SW: 7N0 907 572 C HW: 7E0 907 572 Component: ACC Bosch PQx H03 0211 Serial number: 08021577030385 Coding: 00005800FE0779 Shop #: WSC 46011 002 1048576 ASAM Dataset: EV_ACCBEGVW361 001006 ROD: EV_ACCBEGVW361_VW32.rod VCID: 3634D34258C721C720B-8062 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 7E0 959 655 H HW: 7E0 959 655 H Component: VW10Airbag01S H08 0018 Revision: -------- Serial number: 003V40042CZ5 Coding: 000000000000000000000000000000003153 Shop #: WSC 02734 790 50316 ASAM Dataset: EV_AirbaVW10BPAVW12X 001028 ROD: EV_AirbaVW10BPAVN750_VW12.rod VCID: 3B22C27663E5FCAFDF5-806E Crash sensor for side airbag: driver side: Serial number: 3495ZRB400250KJKP1GY Crash sensor for side airbag: front passenger side: Serial number: 3505ZRB400450KJKN9O% No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1 Part No SW: 7E0 920 871 A HW: 7E0 920 871 A Component: KOMBI H02 2030 Serial number: 00000000000000 Coding: 150F010300 Shop #: WSC 00012 790 50316 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736 ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod VCID: 28080D3A82734737A27-807C No fault code found. ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No: 7E0 819 008 F Component: J737__Standheizung 0605 Revision: 00086000 Serial number: 09024901A00000 Coding: 0021332 Shop #: WSC 02757 790 00000 VCID: 2C00F12A9A0B6B1746F-8078 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb Part No SW: 7E0 909 901 HW: 7E0 937 090 C Component: GW-K-CAN TP20 H82 0752 Revision: B9082001 Coding: 042200 Shop #: WSC 12345 123 12345 VCID: 68884D3A42738737627-803C No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 0AY-907-554-V1.clb Part No SW: 09N 907 554 B HW: 09N 907 554 B Component: Haldex 4Motion 6008 Coding: 0000001 Shop #: WSC 02756 790 00000 VCID: 372ADE46534DD8CF3BD-8062 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H02 2030 Serial number: Coding: 000000 Shop #: WSC 00012 790 50316 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710 ROD: EV_Immo_UDS_VDD_RM09.rod VCID: 6A8C37325CFFB527743-803E No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl Part No SW: 5N0 035 342 G HW: 5N0 035 342 G Component: SG EXT.PLAYER H19 0770 Revision: A1001003 Serial number: 7665304253 Coding: 010100 Shop #: WSC 02756 790 00000 VCID: 2B02F23693056C2F4F5-807E No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb Part No SW: 7E0 035 680 B HW: 7E0 035 680 B Component: RNS-MID H09 5274 Revision: AB001001 Serial number: VWZ6Z7N7280058 Coding: 04000402040000A00014 Shop #: WSC 02754 790 00000 VCID: 2410190AFEDBA3578EF-8070 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V16 8536 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: Redir Fail! Part No SW: 7E0 907 566 B HW: 4L0 907 566 A Component: J0769 SWA MasterH13 0120 Revision: 00H13000 Serial number: 6PZ 009 014-07 Coding: 0010161 Shop #: WSC 02756 790 00000 VCID: 2F3AE626AB1D100F63D-807A Subsystem 1 - Part No: 7E0 907 568 B Component: J0770 SWA Slave H10 0120 Subsystem 2 - Serial number: 6PZ 009 014-27 Subsystem 3 - Serial number: 5F26.09.1300H10000AMS14437ÿ Subsystem 4 - Serial number: S14437ÿ No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb Part No SW: 6R0 907 357 HW: 6R0 907 357 Component: LWR-ECU H02 0070 Revision: -------- Serial number: -------------- Coding: 028A000001000000 Shop #: WSC 02757 790 50316 ASAM Dataset: EV_HeadlRegulVWLWRPt 001004 ROD: EV_HeadlRegulVWLWRPt_VW25.rod VCID: 77AA1E461F4D18CFFBD-8022 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels:. 1T0-035-680.clb Part No SW: 7E0 035 680 B HW: 7E0 035 680 B Component: RNS-MID H09 5274 Revision: AB001001 Serial number: VWZ6Z7N7280058 Coding: 04000402040000A00014 Shop #: WSC 02754 790 00000 VCID: 2410190AFEDBA3578EF-8070 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V16 8536 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb Part No SW: 7E0 907 534 HW: 7E0 937 090 C Component: Batt.regelung H82 0752 Serial number: 4000 088181300 Coding: 330B1A73 Shop #: WSC 02762 790 12345 VCID: 68884D3A42738737627-803C Subsystem 1 - Part No SW: 7E0 915 181 D HW: 7E0 915 181 D Component: J367-BDM H08 0182 Serial number: 50262E43111931975854 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb Part No SW: 1K0 907 383 G HW: 1K0 907 383 G Component: Anhaenger H10 0110 Revision: 3B001001 Serial number: 00000194554106 Coding: 410D000101000000 Shop #: WSC 02756 790 00000 VCID: 313EE05EB12906FF759-8064 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 5N0-907-441.clb Part No SW: 7E0 907 441 HW: 7E0 907 441 Component: J772__Rearview 0040 Revision: 00H12000 Serial number: 525PA8-J390101 Coding: 0030015 Shop #: WSC 18342 003 1048576 VCID: 6596440EB9619A5F591-8030 No fault code found. ------------------------------------------------------------------------------- Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-W2.clb Part No SW: 7E5 919 037 G HW: 7E5 919 037 G Component: Dachdisplay H15 0185 Revision: 10100011 Serial number: 308907 Coding: 000203 Shop #: WSC 02756 790 00000 VCID: 3536D44E45412ADF291-8060 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb Part No SW: 3C8 035 730 D HW: 3C8 035 730 D Component: Telefon 022 0971 Revision: -------- Serial number: 35502105055314 Coding: 020101000100000000000101 Shop #: WSC 02756 790 50316 ASAM Dataset: EV_UHVPremi 002709 ROD: EV_UHVPremi.rod VCID: 2410190AFE5BA3578EF-8070 No fault code found.
You have nice T5: 4WD + DSG and now ACC
So there was fault in your ABS unit about Airbag controller?
I have bought ACC radar from T6 for my experiments))
But for 6R it looks more complicated...
Thx.MaDwArLoCk wrote: ↑Tue Oct 08, 2019 9:26 am You have nice T5: 4WD + DSG and now ACC
Correct, the Error in ABS with wrong Airbag Controller was:
8229 - Databus
U1121 00 [009] - Missing Message
[ACAN: Airbag_03 frame timeout]
Well since 6R is PQ25, it is possible too, but if you run into the same issue with Airbag Controller, than it will be more complicated because T6 Airbag controller is for shure no fit for a Polo ....
But you only run into this issue while retrofiting the T6 ABS/ESP and this is for shure no fit for a Polo, too ....
Coding: 0400A1
Coding: 1400A1
BTW, with these WRMs it is possible to get the automatic folding mirrors if you want to expand the great equipment of your Super T5.
Byte02 = A3 HEX in your case.
* Mirrors with folding motors and new wires are necessary if you do not have factory folding mirrors (by Button / Knob - manual function).
MKE ---> viewtopic.php?f=56&t=58703&start=4710#p556790
